[AG-TECH] Problems bridging 2.4 venue server with FC4 'compat' AG 2.4
Derek Piper
dcpiper at indiana.edu
Mon Sep 18 10:16:29 CDT 2006
Hi Doug et al,
I have a fedora core 4 machine that I am planning on using as a bridge
server for both AG2.4 and AG3. I've installed the AccessGrid RPMs via
the 'yum' method from Doug's repository at vislab. I am using the
'compat 2.4' .rpm.
I have a Bridge server config file pointing to my AG2.4 venue server
located on an FC5 machine, also running the 3.0 server too. I have
double-checked the ports are correct and I'm not pointing to
incompatible versions.
When running:
BridgeServer24 -d 3 -c iri-av.cfg
I get 'GetVenues :exceptions.AttributeError VenueI instance has no
attribute 'GetVenues'' as an error.
Pertinant output from bridge server:
09/18/06 11:10:25 -1208342848 CertificateManager
CertificateManager.py:1572DEBUG done, success=1
09/18/06 11:10:25 -1208342848 Toolkit Toolkit.py:764 INFO
Initialized Globus.
09/18/06 11:10:25 -1208342848 Toolkit Toolkit.py:782 INFO Service
Initialization Complete.
09/18/06 11:10:25 -1208342848 Toolkit BridgeServer24:157 INFO
BridgeFactory.SetPortMin 20000
09/18/06 11:10:25 -1208342848 Toolkit BridgeServer24:161 INFO
BridgeFactory.SetPortMax 40000
09/18/06 11:10:25 -1208342848 Toolkit BridgeServer24:259 INFO
AddVenueServer: url =
https://iri-av.informatics.indiana.edu:8000/Venues/default
<Fault SOAP-ENV:Client: Method Not Found: Venues:default:GetVenues :
exceptions.AttributeError VenueI instance has no attribute 'GetVenues'
<traceback object at 0xb047e2fc>>
09/18/06 11:10:26 -1208342848 Toolkit BridgeServer24:418 ERROR Error
addingvenue server;
url=https://iri-av.informatics.indiana.edu:8000/Venues/default
Traceback (most recent call last):
File "/usr/bin/BridgeServer24", line 416, in LoadConfig
self.AddVenueServer(url)
File "/usr/bin/BridgeServer24", line 262, in AddVenueServer
venueDescList = VenueServerIW(venueServerUrl).GetVenues()
File
"/usr/lib/python2.4/site-packages/AccessGrid2/AccessGrid/VenueServer.py",
line 1694, in GetVenues
vl = self.proxy.GetVenues()
File "/usr/lib/python2.4/site-packages/SOAPpy/Client.py", line 453,
in __call__
return self.__r_call(*args, **kw)
File "/usr/lib/python2.4/site-packages/SOAPpy/Client.py", line 475,
in __r_call
self.__hd, self.__ma)
File "/usr/lib/python2.4/site-packages/SOAPpy/Client.py", line 389,
in __call
raise p
faultType: <Fault SOAP-ENV:Client: Method Not Found:
Venues:default:GetVenues :exceptions.AttributeError VenueI instance has
no attribute 'GetVenues' <traceback object at 0xb047e2fc>>
Shutting down...
09/18/06 11:10:40 -1208342848 Toolkit BridgeServer24:322 INFO
Method BridgeServer.Shutdown called
My bridge server config file is:
[BridgeServer]
name = Informatics Bridge
location = Indiana University
qbexec = /usr/bin/QuickBridge
BRIDGESERVER = Informatics Bridge
portMin = 20000
portMax = 40000
[https://iri-av.informatics.indiana.edu:8000/Venues/default]
type = VenueServer
That venue URL is correct for my venue server. Any comments/suggestions?
Derek
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
