[AG-TECH] Please remove AG3 bridge at se88.ssees.ac.uk
Todd Zimmerman
toddz at sfu.ca
Mon Oct 30 14:27:58 CST 2006
Can one of the developers comment on whether this is a good solution or whether we'll run into other
compatibility issues between the CVS RegistryClient.py and the release RegistryClient.py? I'd like
to offer this solution to our users.
Cheers,
Todd
Andrew A Rowley wrote:
> Hi,
> I think there was a bug-fix for this that allowed the calls to timeout. I believe this is in the ANL CVS, so this is not released yet, but if you are having problems, it may be worth doing the update. The files are at:
> http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/AccessGrid/AccessGrid/Registry/RegistryClient.py?view=log
> If you right-click and "save as..." on the "download" link next to revision 1.26 (or 1.27 if you want the most up-to-date). This file will replace, on Windows, "C:\Python23\Lib\site-packages\AccessGrid3\AccessGrid\Registry\RegistryClient.py", or on Linux, "/usr/lib/python2.4/site-packages/AccessGrid/Registry/RegistryClient.py".
> I have been using this on Windows for a while now, and it appears stable. I tried it just now and it took about 5 seconds to load the bridges, which is not bad. I have no experience of doing the same thing on Linux - Linux users should be aware that the CVS is for the ANL release, which is usually Windows and Mac.
> Andrew :)
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
>> -----Original Message-----
>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>> Behalf Of Christoph Willing
>> Sent: 30 October 2006 05:51
>> To: AG-TECH list
>> Subject: [AG-TECH] Please remove AG3 bridge at se88.ssees.ac.uk
>> Could the responsible person please shut down the bridge at
>> 194.66.92.88 (se88.sses.ac.uk) please. It appears to be behind a
>> firewall which results in an excutiatingly long start up time for AG3
>> VenueClients everywhere.
>> chris
>> Christoph Willing +61 7 3365 8350
>> QCiF/QPSF Access Grid Manager
>> University of Queensland
