[AG-TECH] Please remove AG3 bridge at se88.ssees.ac.uk
Thomas D. Uram
turam at mcs.anl.gov
Mon Oct 30 15:34:21 CST 2006
The CVS RegistryClient.py can safely be used; there are no compatibility
issues with the released service.
As for whether you should use the CVS code, apply this rule of thumb:
If you are experienced enough to understand the code changes, and how to
apply them and remove them if necessary, and report problems that may
occur, you can use the CVS code. Otherwise, please don't. It
complicates our efforts in supporting the code when the user has
modified this or that code from what we would expect to see in a release.
Tom
On 10/30/06 2:27 PM, Todd Zimmerman wrote:
> Can one of the developers comment on whether this is a good solution or whether we'll run into other
> compatibility issues between the CVS RegistryClient.py and the release RegistryClient.py? I'd like
> to offer this solution to our users.
> Cheers,
> Todd
> Andrew A Rowley wrote:
>> Hi,
>> I think there was a bug-fix for this that allowed the calls to timeout. I believe this is in the ANL CVS, so this is not released yet, but if you are having problems, it may be worth doing the update. The files are at:
>> http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/AccessGrid/AccessGrid/Registry/RegistryClient.py?view=log
>> If you right-click and "save as..." on the "download" link next to revision 1.26 (or 1.27 if you want the most up-to-date). This file will replace, on Windows, "C:\Python23\Lib\site-packages\AccessGrid3\AccessGrid\Registry\RegistryClient.py", or on Linux, "/usr/lib/python2.4/site-packages/AccessGrid/Registry/RegistryClient.py".
>> I have been using this on Windows for a while now, and it appears stable. I tried it just now and it took about 5 seconds to load the bridges, which is not bad. I have no experience of doing the same thing on Linux - Linux users should be aware that the CVS is for the ANL release, which is usually Windows and Mac.
>> Andrew :)
>> Access Grid Support Centre,
>> RSS Group,
>> Manchester Computing,
>> Kilburn Building,
>> University of Manchester,
>> Oxford Road,
>> Manchester,
>> M13 9PL,
>> UK
>> Tel: +44(0)161-275 0685
>> Email: Andrew.Rowley at manchester.ac.uk
>>> -----Original Message-----
>>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>>> Behalf Of Christoph Willing
>>> Sent: 30 October 2006 05:51
>>> To: AG-TECH list
>>> Subject: [AG-TECH] Please remove AG3 bridge at se88.ssees.ac.uk
>>> Could the responsible person please shut down the bridge at
>>> 194.66.92.88 (se88.sses.ac.uk) please. It appears to be behind a
>>> firewall which results in an excutiatingly long start up time for AG3
>>> VenueClients everywhere.
>>> chris
>>> Christoph Willing +61 7 3365 8350
>>> QCiF/QPSF Access Grid Manager
>>> University of Queensland
