[AG-TECH] Is there a Venue Client time out?
Thomas D. Uram
turam at mcs.anl.gov
Wed Oct 4 11:08:07 CDT 2006
Okay, the data transfer issue indicates that you lost not only the
Jabber TCP connection, but also the eventclient TCP connection (the only
two persistent TCP connections in the venue client). Could you send
your venueclient.log file for me to review?
Fwiw, I have left my venueclient running for many days at a time and not
had this problem.
In any case, we'll track it down and fix it.
Tom
On 10/4/06 10:46 AM, Jimmy Miklavcic wrote:
> Yes, it happens every day. I uploaded a file, just now, into the data
> area. The upload monitor displayed its progress and then said it
> uploaded successfully but I did not see the list of files update. I
> tried again and the same thing happened. This time I hit "go" to reenter
> the Argonne Lobby and the file was listed. So, the file was uploaded but
> I had to reenter the venue to get the list updated. However, this does
> not reset the Jabber connection. Closing the client and restarting it
> reconnects the jabber session.
> The network was not lost overnight.
> I agree that a timeout should be a user selectable setting.
> Jimmy
> Jimmy Miklavcic
> Multimedia Specialist
> Jimmy.Miklavcic at utah.edu
> UNIVERSITY OF UTAH
> CTR FOR HIGH PERFORM COMPUTING
> 155 SOUTH 1452 EAST RM 405
> SALT LAKE CITY, UT 84112-0190
> Office: 801.585.9335
> Fax: 801.585.5366
> http://www.anotherlanguage.org
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Thomas D. Uram
> Sent: Wednesday, October 04, 2006 8:28 AM
> To: Jimmy Miklavcic
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Is there a Venue Client time out?
> There is no timeout mechanism built in. You should be able to leave
> your venueclient (ag2 or ag3) parked in a venue indefinitely. If that
> is not possible, it's a bug that we need to fix.
> Does this happen reliably? When it happens, can you try to upload a
> data file and see if it is displayed in the venueclient when the upload
> has finished? (this will test the event client connection).
> Is it possible that network to the machine was temporarily lost
> overnight?
> Tom
> On 10/3/06 11:56 AM, Jimmy Miklavcic wrote:
>> Does the AGtk3.0.x Venue Client have a time-out? I have parked my PIG
>> in the Argonne Lobby over night and in the morning when I type into
>> the jabber client, it tells by that I have to be connected to a venue;
>> video and audio appears to still be working. I'm curious because I'd
>> like initiate an "always on" scenario with the grid but if the system
>> times out at some point that can be problematic. Any insights?
>> Jimmy
