[AG-TECH] Scaling the multicast mountain - Part 2: what do I need to ask the NOC
Jennifer Teig von Hoffman
jtvh at bu.edu
Tue May 23 11:12:49 CDT 2006
Hi Thad,
Yup, I'm sure the ability to ping off-campus will be a step in the right direction! ;)
You might want to take a look at this document, and/or send it along to your networking staff:
http://www.accessgrid.org/?q=node/20
You're right that just asking for multicast isn't enough detail -- there are real issues with port access that will likely be an issue if you're behind a firewall. Many of us end up in the DMZ as a result, though there are other successful approaches.
Cheers,
Jennifer
Thad Sze wrote:
> So I think we've established that the reason that I can't see the list
> of bridges is that I can't ping off campus.
> Now, so far as multicast, I have to figure out exactly what I need to
> ask the NOC for, who have said that they might be able to configure
> multicast on some of our subnets. I'm worried that just asking for
> multicast to be turned on may not be detailed enough. Should I, for
> instance, ask for any of the following:
> access to mbone, or just multicast routing to Abilene?
> any specific multicast address space or all of it?
> anything else that those of you who have had to ask your NOCs to enable
> multicast before ran into because you didn't know to ask for it initially?
> Thanks,
> Thad
