Rif: Re: [AG-TECH] AG3: two questions about Bridging/Unicast
Thomas D. Uram
turam at mcs.anl.gov
Tue May 23 09:26:35 CDT 2006
Sorry, I forgot to include something:
You need to do this instead:
cd c:\program files\agtk-3\bin
runag3.py Bridge3.py --name NAME --location LOCATION
Let us know if you run into problems with that.
As to the logfile, I would need the VenueClient.log file,
which you'll find in C:\Documents and Settings\<you>\Application
Data\AccessGrid3\Logs
(or similar in your Italian version of Windows).
Tom
Fabrizio.Berdondini at prototipo.it wrote:
> When trying to launch
> Bridge3.py --name (name) --location (location)
> I get the following error
> Traceback (most recent call last):
> File "C:\Programmi\AGTk-3\bin\Bridge3.py", line 15,
> from AccessGrid.Registry.RegistryClient import Re
> ImportError: No module named Registry.RegistryClient
> For what concerns the second question, which logs should you need in
> order to be able to understand the abnormal behaviour of my AG3 client?
> I'll clean them up then do some try and then i'll post them to you.
> Thank you,
> Faber B.
> owner-ag-tech at mcs.anl.gov scritti il 22/05/2006 20.15.29
> > > Hi all,
> > > following my previous thread about bridging with AG3, I'd like to
> > > point out it with two questions about bridging and the use of unicast
> > > under AG3.
> > > 1) How would be possible to set up a bridge for an AG3 venue server?
> > > Does it require a config file as for AG2.4? What is a
> "RegistryClient"?
> > You can run a bridge like so:
> > Bridge.py --name NAME --location LOCATION
> > There are some other options, too, which you can see by running
> > 'Bridge.py -h'. Of particular note is the
> > bridge port range, which you'll have to ensure is open for clients
> to be
> > able to use it.
> > > 2) AG3 features report that with AG3 bridge/unicast is allowed for
> > > each room. I tried to enable unicast (here we are not able to reach
> > > the mbone as far as now) in many public rooms, but nothing seems to
> > > change. I noticed that the "bridges" option under the "tools" menu of
> > > the VenueClient is always empty... so I was wondering if a bridge
> > > inside there is needed in order to switch to unicast inside the room.
> > A bridge must appear in the list of bridges for a unicast connection to
> > work. If you see 'No bridges available', you can
> > send your logfile to me so I can understand what is going wrong.
> > > OK, I know, just some more than really two questions but... anyway...
> > > thank you for your support,
> > > Bye,
> > > Faber B.
