[AG-TECH] AG3: two questions about Bridging/Unicast
Thomas D. Uram
turam at mcs.anl.gov
Mon May 22 13:15:29 CDT 2006
Fabrizio.Berdondini at prototipo.it wrote:
> Hi all,
> following my previous thread about bridging with AG3, I'd like to
> point out it with two questions about bridging and the use of unicast
> under AG3.
> 1) How would be possible to set up a bridge for an AG3 venue server?
> Does it require a config file as for AG2.4? What is a "RegistryClient"?
You can run a bridge like so:
Bridge.py --name NAME --location LOCATION
There are some other options, too, which you can see by running
'Bridge.py -h'. Of particular note is the
bridge port range, which you'll have to ensure is open for clients to be
able to use it.
> 2) AG3 features report that with AG3 bridge/unicast is allowed for
> each room. I tried to enable unicast (here we are not able to reach
> the mbone as far as now) in many public rooms, but nothing seems to
> change. I noticed that the "bridges" option under the "tools" menu of
> the VenueClient is always empty... so I was wondering if a bridge
> inside there is needed in order to switch to unicast inside the room.
A bridge must appear in the list of bridges for a unicast connection to
work. If you see 'No bridges available', you can
send your logfile to me so I can understand what is going wrong.
> OK, I know, just some more than really two questions but... anyway...
> thank you for your support,
> Bye,
> Faber B.
