[AG-TECH] Problems connecting to AGServiceManager on capture node
Michael Braitmaier
braitmaier at hlrs.de
Wed May 10 01:05:35 CDT 2006
Thanks for claryfing the URL aspect.
While reading your reply I might have discovered my problem, if it is
one at all.
Unfortunately the display machine is located in a different network than
the capture machine, so they are not within the same local subnet,
which I assumed shouldn't be a problem assuming the ports
are opened for the capture machine's subnet (eg. 11000 for the service
manager, and possibly ports for the services). Is this assumption correct?
Michael
Thomas D. Uram schrieb:
> Hi Michael:
> The combo box should be populated with service managers discovered on
> the local network. If you
> don't see this initially, it may be a problem particular to FC or the
> FC packaging. Doug will be able
> to speak to that.
> The service manager and node service use http, not https. Given that
> the URL is in the combobox,
> it must have been discovered, and absolutely should not have been
> discovered as 'https'. Looking
> at the code, I have found that, if you type in something less than the
> full url, it builds the whole url
> for you, but does so incorrectly (using https instead of http); I have
> fixed that in cvs today.
> A workaround would be to change the discovered url to use http instead
> of https.
> Thanks,
> Tom
> Michael Braitmaier wrote:
>> Hello everyone!
>> I finally got AG3 isntalled on a FC3 and FC5 system. The FC3 system
>> is the display system used for controlling the session.
>> The FC5 system acts as capture node. Both installations seem to be
>> fine and I can join the ANL vv3 VenueServer.
>> However I seem not to be able to connect from my FC3 system to the
>> servcie manager of the FC5 system.
>> I get the attached error on the FC3 system when trying to add the
>> service manager.
>> Did the format of specifying the service manager in the node
>> management change?
>> I used <IP>:<Port>.
>> The first time I drop down the combo box it is empty. Then enetering
>> the IP and port also gives me an error and
>> when I then click the drop-down box I se an entry
>> https://<IP>:<Port>/ServiceManager
>> I think this might be wrong?
>> The service manager on the capture node tells me it is started on
>> http://<IP>:<Port>/ServiceManager (without the "s")
>> Someone has an idea, what I am doing wrong?
>> Thanks in advance
>> Michael
>> 05/09/2006 05:27:10 PM -1208514336 NodeManagementUIClasses
>> NodeManagementUIClasses.py:870 ERROR Exception in AddHost
>> Traceback (most recent call last):
>> File
>> "/usr/lib/python2.3/site-packages/AccessGrid/NodeManagementUIClasses.py",
>> line 865, in AddHost
>> self.nodeServiceHandle.AddServiceManager( url )
>> File
>> "/usr/lib/python2.3/site-packages/AccessGrid/AGNodeService.py", line
>> 207, in AddServiceManager
>> serviceManagerDescription = AGServiceManagerIW( serviceManagerUrl
>> ).GetDescription()
>> File
>> "/usr/lib/python2.3/site-packages/AccessGrid/interfaces/AGServiceManager_client.py",
>> line 71, in GetDescription
>> self.binding.Send(None, None, request,
>> soapaction="urn:#GetDescription", **kw)
>> File "/usr/lib/python2.3/site-packages/ZSI/client.py", line 254, in
>> Send
>> self.h.connect()
>> File "/usr/lib/python2.3/httplib.py", line 985, in connect
>> ssl = socket.ssl(sock, self.key_file, self.cert_file)
>> File "/usr/lib/python2.3/socket.py", line 73, in ssl
>> return _realssl(sock, keyfile, certfile)
>> sslerror: (1, 'error:140770FC:SSL
>> routines:SSL23_GET_SERVER_HELLO:unknown protocol')
Dipl.-Inf. Michael Braitmaier
HLRS - Visualization / Video Conferencing
University of Stuttgart
Germany
Phone: ++49 711 685 65996
Fax : ++49 711 682 357
Website: http://www.hlrs.de/people/braitmaier/
