Rif: Re: [AG-TECH] Troubles entering the venues...
Thomas D. Uram
turam at mcs.anl.gov
Mon May 8 12:05:53 CDT 2006
You can also use the IP address. How you set it depends on the shell
you use:
For bash:
export GLOBUS_HOSTNAME=140.10.10.10
For csh:
set GLOBUS_HOSTNAME 140.10.10.10
Tom
Fabrizio.Berdondini at prototipo.it wrote:
> Thank you Thomas, just 2 questions: our server machine as far as now
> doesn't have a public hostname, just a public IP. Could this be a
> problem? Second: how can I set the globus_hostname variable for a SUSE
> 10 machine?
> Thank you as always for your help.
> Bye,
> Faber B.
> "Thomas D. Uram" <turam at mcs.anl.gov> scritti il 08/05/2006 18.50.55
> > Entering a venue requires a SOAP call and an event client
> connection. I
> > expect that the
> > SOAP call is being made to the public hsotname, but the event client
> > connection is
> > being attempted on the internal hostname. You can force the use of a
> > particular hostname
> > by setting the GLOBUS_HOSTNAME environment variable before running the
> > VenueServer. In your case, I would set it to the public hostname.
> > If problems persist, let us know.
> > Tom
> > > Hello all,
> > > i'm having some problems with permissions (i guess so) while
> trying to
> > > enter the venues on a AG 2.4 VenueServer. I'm going to explain better
> > > what's happening. We had first configurated the venue server/clients
> > > inside our LAN and tested it for quite two months. After that we put
> > > our server onto a public IP (without changing anything in the server
> > > configuration). From this moment onwards we are no more able to reach
> > > the venues: on the client we receive a message saying that we are not
> > > able to connect to the lobby venue. We tried to launch a venue client
> > > onto the same machine running the venueserver and we successfully
> > > connected it to the lobby venue on the server. After this we tried
> > > again to connect the other clients to the lobby on the venue server:
> > > we received the same error, but looking inside the venue with the
> only
> > > venueclient connected to it (the one running on the same machine that
> > > runs the venueserver) we saw as many instances of the client as the
> > > number of trials we did to log to that venue.
> > > How could we solve this problem?
> > > Thank you in advance,
> > > Faber B.
