Rif: Re: [AG-TECH] Troubles entering the venues...
Fabrizio.Berdondini at prototipo.it
Mon May 8 11:57:14 CDT 2006
Thank you Thomas, just 2 questions: our server machine as far as now
doesn't have a public hostname, just a public IP. Could this be a problem?
Second: how can I set the globus_hostname variable for a SUSE 10 machine?
Thank you as always for your help.
Bye,
Faber B.
"Thomas D. Uram" <turam at mcs.anl.gov> scritti il 08/05/2006 18.50.55
> Entering a venue requires a SOAP call and an event client connection. I
> expect that the
> SOAP call is being made to the public hsotname, but the event client
> connection is
> being attempted on the internal hostname. You can force the use of a
> particular hostname
> by setting the GLOBUS_HOSTNAME environment variable before running the
> VenueServer. In your case, I would set it to the public hostname.
> If problems persist, let us know.
> Tom
> Fabrizio.Berdondini at prototipo.it wrote:
> > Hello all,
> > i'm having some problems with permissions (i guess so) while trying to
> > enter the venues on a AG 2.4 VenueServer. I'm going to explain better
> > what's happening. We had first configurated the venue server/clients
> > inside our LAN and tested it for quite two months. After that we put
> > our server onto a public IP (without changing anything in the server
> > configuration). From this moment onwards we are no more able to reach
> > the venues: on the client we receive a message saying that we are not
> > able to connect to the lobby venue. We tried to launch a venue client
> > onto the same machine running the venueserver and we successfully
> > connected it to the lobby venue on the server. After this we tried
> > again to connect the other clients to the lobby on the venue server:
> > we received the same error, but looking inside the venue with the only
> > venueclient connected to it (the one running on the same machine that
> > runs the venueserver) we saw as many instances of the client as the
> > number of trials we did to log to that venue.
> > How could we solve this problem?
> > Thank you in advance,
> > Faber B.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060508/988b9af6/attachment.htm>
