Rif: Re: Rif: Re: [AG-TECH] Troubles entering the venues...
Fabrizio.Berdondini at prototipo.it
Mon May 8 12:25:24 CDT 2006
I tried to set the variable with the bash command but no luck, I got again
the same behaviour... In fact I forgot to tell you a thing: we also have
an AG 3.0 venueserver/client with the same subnet/configuration: the 2.4
server has ip xxx.xxx.xxx.50, the 3.0 server xxx.xxx.xxx.51, but with the
AG 3.0 venueserver all seems working well... Which could be the problem
with the 2.4? Some authentication problem? (I tried with both Identity and
Service certificates, but no luck.
I also tried to use in my client the same certificate that I use for the
server, but again i wasn't able to connect to venue lobby).
I have no clue at this time....
"Thomas D. Uram" <turam at mcs.anl.gov> scritti il 08/05/2006 19.05.53
> You can also use the IP address. How you set it depends on the shell
> you use:
> For bash:
> export GLOBUS_HOSTNAME=140.10.10.10
> For csh:
> set GLOBUS_HOSTNAME 140.10.10.10
> Tom
> Fabrizio.Berdondini at prototipo.it wrote:
> > Thank you Thomas, just 2 questions: our server machine as far as now
> > doesn't have a public hostname, just a public IP. Could this be a
> > problem? Second: how can I set the globus_hostname variable for a SUSE
> > 10 machine?
> > Thank you as always for your help.
> > Bye,
> > Faber B.
> > "Thomas D. Uram" <turam at mcs.anl.gov> scritti il 08/05/2006 18.50.55
> > > Entering a venue requires a SOAP call and an event client
> > connection. I
> > > expect that the
> > > SOAP call is being made to the public hsotname, but the event client
> > > connection is
> > > being attempted on the internal hostname. You can force the use of
a
> > > particular hostname
> > > by setting the GLOBUS_HOSTNAME environment variable before running
the
> > > VenueServer. In your case, I would set it to the public hostname.
> > > If problems persist, let us know.
> > > Tom
> > > > Hello all,
> > > > i'm having some problems with permissions (i guess so) while
> > trying to
> > > > enter the venues on a AG 2.4 VenueServer. I'm going to explain
better
> > > > what's happening. We had first configurated the venue
server/clients
> > > > inside our LAN and tested it for quite two months. After that we
put
> > > > our server onto a public IP (without changing anything in the
server
> > > > configuration). From this moment onwards we are no more able to
reach
> > > > the venues: on the client we receive a message saying that we are
not
> > > > able to connect to the lobby venue. We tried to launch a venue
client
> > > > onto the same machine running the venueserver and we successfully
> > > > connected it to the lobby venue on the server. After this we tried
> > > > again to connect the other clients to the lobby on the venue
server:
> > > > we received the same error, but looking inside the venue with the
> > only
> > > > venueclient connected to it (the one running on the same machine
that
> > > > runs the venueserver) we saw as many instances of the client as
the
> > > > number of trials we did to log to that venue.
> > > > How could we solve this problem?
> > > > Thank you in advance,
> > > > Faber B.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060508/a8057769/attachment.htm>
