[AG-TECH] SharedBrowser
    Rosario Lombardo
    rosario.lombardo at isti.cnr.it
    Mon Mar  6 07:53:18 CST 2006
Ah, of course...
I forgot to say that the now, in the newly installed AG2.4,
SharedBrowser.log is not created anymore.
And yes, as suggested in a previous message in this list, I replaced the
old wxPython 2.5 with the new 2.6 required by AG3 and supposed to also
support AG2.4.
Should I revert back to the old libraries? Is it then possible to have
both toolkits on the same pc?
Thanks again,
\\Rosario
Rosario Lombardo
Information Science and Technology Institute (ISTI) - Cnr, Italy
<mailto:rosario.lombardo at isti.cnr.it>   *-*   http://hpc.isti.cnr.it/~lombardo
<http://hpc.isti.cnr.it/%7Elombardo>
phone: +39 050-315-3076
Thomas D. Uram wrote:
> The info we'd need is in SharedBrowser.log.  I suspect that
> you have a more recent wxPython installed, wherein the
> module has changed to not include one of the components
> used by SharedBrowser.  Confirm this (by sending the log)
> and we'll look at fixing it.
> On 3/3/06 12:48 PM, Rosario Lombardo wrote:
>> Hi everybody!
>> My SharedBrowser stopped to work!
>> On two winXP neither SharedBrowser can be started: selecting
>> Open(/for all) nothing happens, on both machines.
>> On one of them I'm also running a VenueServer, so here is what I did:
>> - reinstalled SharedBrowser (agpm -u/-p)-> didn't work
>> - reinstalled AGtk, deleting also per-user AccessGrid dir -> didn't work
>> - tried again inside NCSA Lobby: -> didn't work
>> - synchronized sever and client with the same ntp server and
>> restarted both AGTk
>> - here posting relevant server/client logs ;)
>> Many thanks,
>> \\Rosario
>> Rosario Lombardo
>> rosario.lombardo at isti.cnr.it <mailto:rosario.lombardo at isti.cnr.it>
>> 03/03/06 19:38:48 1492 VenueClient     venueclientui.py:3176 INFO
>> Got commands: (application/x-ag-shared-browser) {'Open':
>> 'C:\\Python23\\python.exe SharedBrowser.py -a %(appUrl)s'}
>> 03/03/06 19:38:48 1492 VenueClientController
>> venueclientcontroller.py:1167 INFO  StartCmd starting command:
>> C:\Python23\python.exe SharedBrowser.py -a
>> https://venues.ncsa.uiuc.edu:9000/Venues/default/apps/00000109bcd301c6008d008e000600116b1
>> 03/03/06 19:38:48 1492 ProcessManager     processmanager.py:59 DEBUG
>> Creating process: C:\Python23\python.exe SharedBrowser.py -a
>> 03/03/06 19:38:48 1492 ProcessManager     processmanager.py:72 DEBUG
>> Create process returns: (<PyHANDLE:1176>, <PyHANDLE:960>, 2236, 2676)
>> 03/03/06 19:38:59 1492 VenueClientController
>> venueclientcontroller.py:535 DEBUG VenueClientFrame.StartApp:
>> Creating application: Shared Browser
>> 03/03/06 19:39:01 2412 EventClient     eventclient.py:177 DEBUG Read
>> Callback called arg=None handle=_30c21e02_p_globus_io_handle_t
>> result=(0, None, None)  n=4
>> 03/03/06 19:39:01 2412 EventClient     eventclient.py:229 DEBUG
>> Freeing callback _30db1a02_p_callbackStruct within callback
>> 03/03/06 19:39:01 2412 EventClient     eventclient.py:238 DEBUG Have
>> new callback handle _30db1a02_p_callbackStruct
>> result=(0, None, None)  n=581
>> 03/03/06 19:39:01 2412 EventClient     eventclient.py:218 DEBUG
>> finally read enough data, wait=581 buflen=581
>> 03/03/06 19:39:01 2412 EventClient     eventclient.py:253 DEBUG
>> Invoking callback <bound method VenueClient.AddApplicationEvent of
>> <AccessGrid.VenueClient.VenueClient instance at 0x01EDCC10>>...
>> 03/03/06 19:39:01 2412 EventClient     eventclient.py:259 DEBUG
>> <AccessGrid.VenueClient.VenueClient instance at 0x01EDCC10>>...done
>> 03/03/06 19:39:01 500 VenueClient     venueclient.py:553 DEBUG
>> AddApplicationEvent: Got Add Application Event
>> 03/03/06 19:39:01 2412 EventClient     eventclient.py:261 INFO  No
>> callback for Add application!
>> 03/03/06 19:39:01 500 VenueClient     venueclientui.py:1799 DEBUG
>> EVENT - Add application: Shared Browser - 07:38:59 PM March 03, 2006,
>> Mime Type: application/x-ag-shared-browser
>> 03/03/06 19:39:01 2412 EventClient     eventclient.py:329 INFO  Got
>> callback for Add application event!
>> 03/03/06 19:39:01 2412 EventClient     eventclient.py:224 DEBUG
>> handleData returns
>> 03/03/06 19:39:05 1492 VenueClient     venueclientui.py:3176 INFO
>> 03/03/06 19:39:06 1492 VenueClientController
>> https://venues.ncsa.uiuc.edu:9000/Venues/default/apps/00000109c167da58008d008e00060011b0a
>> 03/03/06 19:39:06 1492 ProcessManager     processmanager.py:59 DEBUG
>> 03/03/06 19:39:06 1492 ProcessManager     processmanager.py:72 DEBUG
>> Create process returns: (<PyHANDLE:1200>, <PyHANDLE:1180>, 2264, 2432)
>> 03/03/06 19:19:15 1576 VenueClientController
>> 03/03/06 19:19:17 3660 EventClient     eventclient.py:177 DEBUG Read
>> Callback called arg=None handle=_20112002_p_globus_io_handle_t
>> 03/03/06 19:19:17 3660 EventClient     eventclient.py:229 DEBUG
>> Freeing callback _60c32302_p_callbackStruct within callback
>> 03/03/06 19:19:17 3660 EventClient     eventclient.py:238 DEBUG Have
>> new callback handle _60c32302_p_callbackStruct
>> result=(0, None, None)  n=611
>> 03/03/06 19:19:17 3660 EventClient     eventclient.py:218 DEBUG
>> finally read enough data, wait=611 buflen=611
>> 03/03/06 19:19:17 3660 EventClient     eventclient.py:253 DEBUG
>> 03/03/06 19:19:17 3660 EventClient     eventclient.py:259 DEBUG
>> 03/03/06 19:19:17 808 VenueClient     venueclient.py:553 DEBUG
>> 03/03/06 19:19:17 808 VenueClient     venueclientui.py:1799 DEBUG
>> EVENT - Add application: Shared Browser - 07:19:15 PM March 03, 2006,
>> 03/03/06 19:19:17 3660 EventClient     eventclient.py:261 INFO  No
>> 03/03/06 19:19:17 3660 EventClient     eventclient.py:329 INFO  Got
>> 03/03/06 19:19:17 3660 EventClient     eventclient.py:224 DEBUG
>> handleData returns
>> 03/03/06 19:19:18 1576 VenueClient     venueclientui.py:3176 INFO
>> 03/03/06 19:19:19 1576 VenueClientController
>> https://accessgrid.isti.cnr.it:8000/Venues/00000109c0de7b6500920030005200200e4/apps/00000109c155c5e50092003000520020acd
>> 03/03/06 19:19:19 1576 ProcessManager     processmanager.py:59 DEBUG
>> 03/03/06 19:19:19 1576 ProcessManager     processmanager.py:72 DEBUG
>> Create process returns: (<PyHANDLE:1160>, <PyHANDLE:1204>, 2516, 772)
>> 03/03/06 19:19:23 1576 VenueClient     venueclientui.py:3176 INFO
>> 03/03/06 19:19:24 3660 EventClient     eventclient.py:177 DEBUG Read
>> 03/03/06 19:19:24 3660 EventClient     eventclient.py:229 DEBUG
>> 03/03/06 19:19:24 3660 EventClient     eventclient.py:238 DEBUG Have
>> result=(0, None, None)  n=2389
>> 03/03/06 19:19:24 3660 EventClient     eventclient.py:218 DEBUG
>> finally read enough data, wait=2389 buflen=2389
>> 03/03/06 19:19:24 3660 EventClient     eventclient.py:253 DEBUG
>> Invoking callback <bound method VenueClient.OpenAppEvent of
>> 03/03/06 19:19:24 3660 EventClient     eventclient.py:259 DEBUG
>> 03/03/06 19:19:24 808 VenueClient     venueclient.py:647 DEBUG
>> OpenAppEvent: Got Start App Event ApplicationDescription:
>> {'mimeType': 'application/x-ag-shared-browser', 'description':
>> 'Started by Ross at 07:19:15 PM March 03, 2006', 'name': 'Shared
>> Browser - 07:19:15 PM March 03, 2006', 'id':
>> '00000109c155c5e50092003000520020acd', 'uri':
>> 'https://accessgrid.isti.cnr.it:8000/Venues/00000109c0de7b6500920030005200200e4/apps/00000109c155c5e50092003000520020acd',
>> 'startable': 1} None Open
>> 03/03/06 19:19:24 3660 EventClient     eventclient.py:261 INFO  No
>> callback for Start application!
>> 03/03/06 19:19:24 3660 EventClient     eventclient.py:329 INFO  Got
>> callback for Start application event!
>> 03/03/06 19:19:24 3660 EventClient     eventclient.py:224 DEBUG
>> handleData returns
>> 03/03/06 19:19:24 1576 VenueClientController
>> 03/03/06 19:19:24 1576 ProcessManager     processmanager.py:59 DEBUG
>> 03/03/06 19:19:24 1576 ProcessManager     processmanager.py:72 DEBUG
>> Create process returns: (<PyHANDLE:920>, <PyHANDLE:1252>, 568, 3144)
>> 03/03/06 19:19:16 1940 VenueServer     venue.py:731 DEBUG Got Client
>> Heartbeat for
>> 00000109c154f9180092003000520020161_00000109c154f91800920030005200206b1
>> at 1141409956.0.
>> Heartbeat for 00000109c0fa0cc00092003000520059444 at 1141409956.74.
>> 03/03/06 19:19:17 3400 VenueServer     venue.py:2308 DEBUG
>> Authorizing () _SOAPContext
>> 03/03/06 19:19:17 3400 VenueServer     venue.py:2316 INFO
>> Authorizing action: CreateApplication for subject /O=Access
>> Grid/OU=agdev-ca.mcs.anl.gov/OU=isti.cnr.it/CN=Rosario Lombardo
>> 03/03/06 19:19:17 3400 VenueServer     venue.py:1997 DEBUG
>> CreateApplication: name=Shared Browser - 07:19:15 PM March 03, 2006
>> description=Started by Ross at 07:19:15 PM March 03, 2006
>> 03/03/06 19:19:17 3400 SharedApplication     sharedapplication.py:429
>> DEBUG Returning channel_id='00000109c155c5e500920030005200200d9'
>> loc='('accessgrid.isti.cnr.it', 8002)'
>> 03/03/06 19:19:17 3400 VenueServer     venue.py:2033 DEBUG
>> CreateApplication: Created id=00000109c155c5e50092003000520020acd
>> handle=https://accessgrid.isti.cnr.it:8000/Venues/00000109c0de7b6500920030005200200e4/apps/00000109c155c5e50092003000520020acd
>> 03/03/06 19:19:20 1940 VenueServer     venue.py:731 DEBUG Got Client
>> Heartbeat for 00000109c0fa0cc00092003000520059444 at 1141409960.98.
>> 03/03/06 19:19:21 1940 VenueServer     venue.py:731 DEBUG Got Client
>> Heartbeat for
>> at 1141409961.03.
>> 03/03/06 19:19:22 1940 VenueServer     venue.py:731 DEBUG Got Client
>> Heartbeat for 00000109c0fa0cc00092003000520059444 at 1141409962.69.
>> 03/03/06 19:19:26 1940 VenueServer     venue.py:731 DEBUG Got Client
>> Heartbeat for
>> at 1141409966.03.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060306/a7a4a845/attachment.htm>
