[AG-TECH] SharedBrowser
Thomas D. Uram
turam at mcs.anl.gov
Fri Mar 3 13:09:27 CST 2006
The info we'd need is in SharedBrowser.log. I suspect that
you have a more recent wxPython installed, wherein the
module has changed to not include one of the components
used by SharedBrowser. Confirm this (by sending the log)
and we'll look at fixing it.
On 3/3/06 12:48 PM, Rosario Lombardo wrote:
> Hi everybody!
> My SharedBrowser stopped to work!
> On two winXP neither SharedBrowser can be started: selecting Open(/for
> all) nothing happens, on both machines.
> On one of them I'm also running a VenueServer, so here is what I did:
> - reinstalled SharedBrowser (agpm -u/-p)-> didn't work
> - reinstalled AGtk, deleting also per-user AccessGrid dir -> didn't work
> - tried again inside NCSA Lobby: -> didn't work
> - synchronized sever and client with the same ntp server and restarted
> both AGTk
> - here posting relevant server/client logs ;)
> Many thanks,
> \\Rosario
> Rosario Lombardo
> Information Science and Technology Institute (ISTI) - Cnr, Italy
> rosario.lombardo at isti.cnr.it
> <mailto:rosario.lombardo at isti.cnr.it> *-* http://hpc.isti.cnr.it/~lombardo
> <http://hpc.isti.cnr.it/%7Elombardo>
> phone: +39 050-315-3076
> 03/03/06 19:38:48 1492 VenueClient venueclientui.py:3176 INFO Got commands: (application/x-ag-shared-browser) {'Open': 'C:\\Python23\\python.exe SharedBrowser.py -a %(appUrl)s'}
> 03/03/06 19:38:48 1492 VenueClientController venueclientcontroller.py:1167 INFO StartCmd starting command: C:\Python23\python.exe SharedBrowser.py -a https://venues.ncsa.uiuc.edu:9000/Venues/default/apps/00000109bcd301c6008d008e000600116b1
> 03/03/06 19:38:48 1492 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\python.exe SharedBrowser.py -a https://venues.ncsa.uiuc.edu:9000/Venues/default/apps/00000109bcd301c6008d008e000600116b1
> 03/03/06 19:38:48 1492 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1176>, <PyHANDLE:960>, 2236, 2676)
> 03/03/06 19:38:59 1492 VenueClientController venueclientcontroller.py:535 DEBUG VenueClientFrame.StartApp: Creating application: Shared Browser
> 03/03/06 19:39:01 2412 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_30c21e02_p_globus_io_handle_t result=(0, None, None) n=4
> 03/03/06 19:39:01 2412 EventClient eventclient.py:229 DEBUG Freeing callback _30db1a02_p_callbackStruct within callback
> 03/03/06 19:39:01 2412 EventClient eventclient.py:238 DEBUG Have new callback handle _30db1a02_p_callbackStruct
> 03/03/06 19:39:01 2412 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_30c21e02_p_globus_io_handle_t result=(0, None, None) n=581
> 03/03/06 19:39:01 2412 EventClient eventclient.py:218 DEBUG finally read enough data, wait=581 buflen=581
> 03/03/06 19:39:01 2412 EventClient eventclient.py:253 DEBUG Invoking callback <bound method VenueClient.AddApplicationEvent of <AccessGrid.VenueClient.VenueClient instance at 0x01EDCC10>>...
> 03/03/06 19:39:01 2412 EventClient eventclient.py:259 DEBUG Invoking callback <bound method VenueClient.AddApplicationEvent of <AccessGrid.VenueClient.VenueClient instance at 0x01EDCC10>>...done
> 03/03/06 19:39:01 500 VenueClient venueclient.py:553 DEBUG AddApplicationEvent: Got Add Application Event
> 03/03/06 19:39:01 2412 EventClient eventclient.py:261 INFO No callback for Add application!
> 03/03/06 19:39:01 500 VenueClient venueclientui.py:1799 DEBUG EVENT - Add application: Shared Browser - 07:38:59 PM March 03, 2006, Mime Type: application/x-ag-shared-browser
> 03/03/06 19:39:01 2412 EventClient eventclient.py:329 INFO Got callback for Add application event!
> 03/03/06 19:39:01 2412 EventClient eventclient.py:224 DEBUG handleData returns
> 03/03/06 19:39:05 1492 VenueClient venueclientui.py:3176 INFO Got commands: (application/x-ag-shared-browser) {'Open': 'C:\\Python23\\python.exe SharedBrowser.py -a %(appUrl)s'}
> 03/03/06 19:39:06 1492 VenueClientController venueclientcontroller.py:1167 INFO StartCmd starting command: C:\Python23\python.exe SharedBrowser.py -a https://venues.ncsa.uiuc.edu:9000/Venues/default/apps/00000109c167da58008d008e00060011b0a
> 03/03/06 19:39:06 1492 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\python.exe SharedBrowser.py -a https://venues.ncsa.uiuc.edu:9000/Venues/default/apps/00000109c167da58008d008e00060011b0a
> 03/03/06 19:39:06 1492 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1200>, <PyHANDLE:1180>, 2264, 2432)
> 03/03/06 19:19:15 1576 VenueClientController venueclientcontroller.py:535 DEBUG VenueClientFrame.StartApp: Creating application: Shared Browser
> 03/03/06 19:19:17 3660 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_20112002_p_globus_io_handle_t result=(0, None, None) n=4
> 03/03/06 19:19:17 3660 EventClient eventclient.py:229 DEBUG Freeing callback _60c32302_p_callbackStruct within callback
> 03/03/06 19:19:17 3660 EventClient eventclient.py:238 DEBUG Have new callback handle _60c32302_p_callbackStruct
> 03/03/06 19:19:17 3660 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_20112002_p_globus_io_handle_t result=(0, None, None) n=611
> 03/03/06 19:19:17 3660 EventClient eventclient.py:218 DEBUG finally read enough data, wait=611 buflen=611
> 03/03/06 19:19:17 3660 EventClient eventclient.py:253 DEBUG Invoking callback <bound method VenueClient.AddApplicationEvent of <AccessGrid.VenueClient.VenueClient instance at 0x01EDCC10>>...
> 03/03/06 19:19:17 3660 EventClient eventclient.py:259 DEBUG Invoking callback <bound method VenueClient.AddApplicationEvent of <AccessGrid.VenueClient.VenueClient instance at 0x01EDCC10>>...done
> 03/03/06 19:19:17 808 VenueClient venueclient.py:553 DEBUG AddApplicationEvent: Got Add Application Event
> 03/03/06 19:19:17 808 VenueClient venueclientui.py:1799 DEBUG EVENT - Add application: Shared Browser - 07:19:15 PM March 03, 2006, Mime Type: application/x-ag-shared-browser
> 03/03/06 19:19:17 3660 EventClient eventclient.py:261 INFO No callback for Add application!
> 03/03/06 19:19:17 3660 EventClient eventclient.py:329 INFO Got callback for Add application event!
> 03/03/06 19:19:17 3660 EventClient eventclient.py:224 DEBUG handleData returns
> 03/03/06 19:19:18 1576 VenueClient venueclientui.py:3176 INFO Got commands: (application/x-ag-shared-browser) {'Open': 'C:\\Python23\\python.exe SharedBrowser.py -a %(appUrl)s'}
> 03/03/06 19:19:19 1576 VenueClientController venueclientcontroller.py:1167 INFO StartCmd starting command: C:\Python23\python.exe SharedBrowser.py -a https://accessgrid.isti.cnr.it:8000/Venues/00000109c0de7b6500920030005200200e4/apps/00000109c155c5e50092003000520020acd
> 03/03/06 19:19:19 1576 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\python.exe SharedBrowser.py -a https://accessgrid.isti.cnr.it:8000/Venues/00000109c0de7b6500920030005200200e4/apps/00000109c155c5e50092003000520020acd
> 03/03/06 19:19:19 1576 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1160>, <PyHANDLE:1204>, 2516, 772)
> 03/03/06 19:19:23 1576 VenueClient venueclientui.py:3176 INFO Got commands: (application/x-ag-shared-browser) {'Open': 'C:\\Python23\\python.exe SharedBrowser.py -a %(appUrl)s'}
> 03/03/06 19:19:24 3660 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_20112002_p_globus_io_handle_t result=(0, None, None) n=4
> 03/03/06 19:19:24 3660 EventClient eventclient.py:229 DEBUG Freeing callback _60c32302_p_callbackStruct within callback
> 03/03/06 19:19:24 3660 EventClient eventclient.py:238 DEBUG Have new callback handle _60c32302_p_callbackStruct
> 03/03/06 19:19:24 3660 EventClient eventclient.py:177 DEBUG Read Callback called arg=None handle=_20112002_p_globus_io_handle_t result=(0, None, None) n=2389
> 03/03/06 19:19:24 3660 EventClient eventclient.py:218 DEBUG finally read enough data, wait=2389 buflen=2389
> 03/03/06 19:19:24 3660 EventClient eventclient.py:253 DEBUG Invoking callback <bound method VenueClient.OpenAppEvent of <AccessGrid.VenueClient.VenueClient instance at 0x01EDCC10>>...
> 03/03/06 19:19:24 3660 EventClient eventclient.py:259 DEBUG Invoking callback <bound method VenueClient.OpenAppEvent of <AccessGrid.VenueClient.VenueClient instance at 0x01EDCC10>>...done
> 03/03/06 19:19:24 808 VenueClient venueclient.py:647 DEBUG OpenAppEvent: Got Start App Event ApplicationDescription: {'mimeType': 'application/x-ag-shared-browser', 'description': 'Started by Ross at 07:19:15 PM March 03, 2006', 'name': 'Shared Browser - 07:19:15 PM March 03, 2006', 'id': '00000109c155c5e50092003000520020acd', 'uri': 'https://accessgrid.isti.cnr.it:8000/Venues/00000109c0de7b6500920030005200200e4/apps/00000109c155c5e50092003000520020acd', 'startable': 1} None Open
> 03/03/06 19:19:24 3660 EventClient eventclient.py:261 INFO No callback for Start application!
> 03/03/06 19:19:24 3660 EventClient eventclient.py:329 INFO Got callback for Start application event!
> 03/03/06 19:19:24 3660 EventClient eventclient.py:224 DEBUG handleData returns
> 03/03/06 19:19:24 1576 VenueClientController venueclientcontroller.py:1167 INFO StartCmd starting command: C:\Python23\python.exe SharedBrowser.py -a https://accessgrid.isti.cnr.it:8000/Venues/00000109c0de7b6500920030005200200e4/apps/00000109c155c5e50092003000520020acd
> 03/03/06 19:19:24 1576 ProcessManager processmanager.py:59 DEBUG Creating process: C:\Python23\python.exe SharedBrowser.py -a https://accessgrid.isti.cnr.it:8000/Venues/00000109c0de7b6500920030005200200e4/apps/00000109c155c5e50092003000520020acd
> 03/03/06 19:19:24 1576 ProcessManager processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:920>, <PyHANDLE:1252>, 568, 3144)
> 03/03/06 19:19:16 1940 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 00000109c154f9180092003000520020161_00000109c154f91800920030005200206b1 at 1141409956.0.
> 03/03/06 19:19:16 1940 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 00000109c0fa0cc00092003000520059444 at 1141409956.74.
> 03/03/06 19:19:17 3400 VenueServer venue.py:2308 DEBUG Authorizing () _SOAPContext
> 03/03/06 19:19:17 3400 VenueServer venue.py:2316 INFO Authorizing action: CreateApplication for subject /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=isti.cnr.it/CN=Rosario Lombardo
> 03/03/06 19:19:17 3400 VenueServer venue.py:1997 DEBUG CreateApplication: name=Shared Browser - 07:19:15 PM March 03, 2006 description=Started by Ross at 07:19:15 PM March 03, 2006
> 03/03/06 19:19:17 3400 SharedApplication sharedapplication.py:429 DEBUG Returning channel_id='00000109c155c5e500920030005200200d9' loc='('accessgrid.isti.cnr.it', 8002)'
> 03/03/06 19:19:17 3400 VenueServer venue.py:2033 DEBUG CreateApplication: Created id=00000109c155c5e50092003000520020acd handle=https://accessgrid.isti.cnr.it:8000/Venues/00000109c0de7b6500920030005200200e4/apps/00000109c155c5e50092003000520020acd
> 03/03/06 19:19:20 1940 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 00000109c0fa0cc00092003000520059444 at 1141409960.98.
> 03/03/06 19:19:21 1940 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 00000109c154f9180092003000520020161_00000109c154f91800920030005200206b1 at 1141409961.03.
> 03/03/06 19:19:22 1940 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 00000109c0fa0cc00092003000520059444 at 1141409962.69.
> 03/03/06 19:19:26 1940 VenueServer venue.py:731 DEBUG Got Client Heartbeat for 00000109c154f9180092003000520020161_00000109c154f91800920030005200206b1 at 1141409966.03.
