[AG-TECH] AG2.4 setup error
Zephyr Zhangbo Liu
zephyr at cs.ubc.ca
Wed Jun 21 14:03:21 CDT 2006
Hi Doug,
Try the following:
> rpmbuild --rebuild globus-accessgrid-2.4.3-1.fc3.src.rpm
> rpm -i /usr/src/suse/x86_64/globus-accessgrid-2.4.3-1.x86_64.rpm
> then
> rpmbuild --rebuild pyGlobus-1.0.10-2.fc3.src.rpm
Perfect. pyGlobus is then correctly setuped.
> For the other two components, pyOpenSSL_AG needs elinks and SOAPpy needs
> > python-abi and the procedure of installing them are both problematic.
> You could remove elinks from the dependency and comment out the
> pyOpenSSL-elinks.patch lines. Later versions of Fedora don't come with
> lynx,
> hence the elinks patch.
Done.
The python-abi dependency could also be removed. On Fedora, python-abi is
> set to the Python version (e.g. 2.3 or 2.4, it's to prevent a RPM built
> against Python 2.4 being installed on a Python 2.3 based Fedora, etc)
I didn't find the spec file of the SOAPpy in /usr/src/packages/SPECS. I only
found the query of python-abi in AccessGrid.spec and
compat-AccessGrid.specbut after I commented them on I couldn't build
them coz they were just
asking for SOAPpy.
Now running
rpmbuild -ba compat-AccessGrid.spec
SOAPpy is the only component that is needed.
Where can I modify its dependency of python-abi?
Zephyr
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060621/dbeb6e54/attachment.htm>
