[AG-TECH] Bridge FC5 3.0.1
Fred Dech
fdech at uchicago.edu
Tue Jun 20 11:37:36 CDT 2006
Greetings.
I've been test running a Bridge on an FC5 system. I can consistently
get it to fail after connecting, leaving, connecting, etc.
I'm using a fairly narrow port range (5610 5640). After spawning its 3
QuickBridge processes, upon subsequent Bridge connects the BridgeFactory
allocates additional ports until it seems that the Bridge fails to allow
any further connections because it can't allocate any more ports inside the
range. I was always under the impression that the unicast
ports were only allocated to the initial QuickBridge processes, and as long
as those processes remained, no new unicast ports were allocated.
I've attached the tail end of my Bridge.log file. I could use some advice,
please.
Thanks.
--fred
06/20/06 10:34:06 -1208944960 Toolkit Toolkit.py:648 INFO Service init: have profile None
06/20/06 10:34:06 -1208944960 Toolkit Toolkit.py:673 INFO Service Initialization Complete.
06/20/06 10:35:09 -1208355136 Toolkit Config.py:559 DEBUG System hostname of fig.uchicago.edu is valid
06/20/06 10:35:09 -1208355136 Toolkit Toolkit.py:109 DEBUG Initializing AG Toolkit version 3.0.1
06/20/06 10:35:09 -1208355136 Toolkit Toolkit.py:110 INFO Command and arguments: ['/usr/bin/Bridge', '-r', '5610', '5640', '-n', 'UofC', '-l', 'fig.uchicago.edu']
06/20/06 10:35:09 -1208355136 VenueClient Preferences.py:180 DEBUG Preferences.LoadPreferences: open file
06/20/06 10:35:09 -1208355136 Toolkit Toolkit.py:159 INFO Logfile Name: Bridge.log
06/20/06 10:35:10 -1208355136 Toolkit Toolkit.py:648 INFO Service init: have profile None
06/20/06 10:35:10 -1208355136 Toolkit Toolkit.py:673 INFO Service Initialization Complete.
06/20/06 10:35:10 -1208355136 Toolkit BridgeFactory.py:81 INFO Allocator using port range: (5610, 5640)
06/20/06 10:35:10 -1208355136 Toolkit BridgeFactory.py:89 INFO BridgeFactory.SetPortMin 5610
06/20/06 10:35:10 -1208355136 Toolkit BridgeFactory.py:93 INFO BridgeFactory.SetPortMax 5640
06/20/06 10:35:24 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.167.7 61084
06/20/06 10:35:24 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:35:24 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5610
06/20/06 10:35:24 -1208355136 Toolkit BridgeFactory.py:131 INFO - creating new bridge
06/20/06 10:35:24 -1208355136 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
06/20/06 10:35:24 -1208355136 Toolkit BridgeFactory.py:41 INFO Starting bridge:
06/20/06 10:35:24 -1208355136 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 224.2.167.7 61084 127
06/20/06 10:35:24 -1208355136 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = fig.uchicago.edu 5610
06/20/06 10:35:24 -1208355136 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.167.7', '-m', '61084', '-u', '5610', '-i', '600']
06/20/06 10:35:25 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.194.115 55568
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5624
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:131 INFO - creating new bridge
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:38 INFO Method Bridge.Start called
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:41 INFO Starting bridge:
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 224.2.194.115 55568 127
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = fig.uchicago.edu 5624
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.194.115', '-m', '55568', '-u', '5624', '-i', '600']
06/20/06 10:35:25 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.209.27 49262
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5634
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:43 INFO [maddr,mport,mttl] = 224.2.209.27 49262 127
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:45 INFO [uaddr,uport] = fig.uchicago.edu 5634
06/20/06 10:35:25 -1208355136 Toolkit BridgeFactory.py:54 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.209.27', '-m', '49262', '-u', '5634', '-i', '600']
06/20/06 10:36:05 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.167.7 61084
06/20/06 10:36:05 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:36:05 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5628
06/20/06 10:36:05 -1208355136 Toolkit BridgeFactory.py:121 INFO - using existing bridge
06/20/06 10:36:05 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.194.115 55568
06/20/06 10:36:05 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5612
06/20/06 10:36:05 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.209.27 49262
06/20/06 10:36:05 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5636
06/20/06 10:37:53 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.167.7 61084
06/20/06 10:37:53 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:37:53 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5632
06/20/06 10:37:53 -1208355136 Toolkit BridgeFactory.py:121 INFO - using existing bridge
06/20/06 10:37:53 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.194.115 55568
06/20/06 10:37:53 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5618
06/20/06 10:37:53 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.209.27 49262
06/20/06 10:37:53 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5626
06/20/06 10:41:55 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.167.7 61084
06/20/06 10:41:55 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:41:55 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5630
06/20/06 10:41:55 -1208355136 Toolkit BridgeFactory.py:121 INFO - using existing bridge
06/20/06 10:41:55 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.194.115 55568
06/20/06 10:41:55 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5614
06/20/06 10:41:55 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.209.27 49262
06/20/06 10:41:55 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5640
06/20/06 10:43:20 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.167.7 61084
06/20/06 10:43:20 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:43:20 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5622
06/20/06 10:43:20 -1208355136 Toolkit BridgeFactory.py:121 INFO - using existing bridge
06/20/06 10:43:20 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.194.115 55568
06/20/06 10:43:20 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5638
06/20/06 10:43:20 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.209.27 49262
06/20/06 10:43:20 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5616
06/20/06 10:46:47 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.167.7 61084
06/20/06 10:46:47 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:46:47 -1208355136 Toolkit BridgeFactory.py:114 INFO Allocated port = 5620
06/20/06 10:46:47 -1208355136 Toolkit BridgeFactory.py:121 INFO - using existing bridge
06/20/06 10:46:47 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.194.115 55568
06/20/06 10:47:46 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.167.7 61084
06/20/06 10:47:46 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:56:26 -1208355136 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=1768
06/20/06 10:56:26 -1208355136 RegistryClient RegistryClient.py:50 INFO No bridge registry peers reachable
06/20/06 10:57:37 -1208355136 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=1445
06/20/06 10:57:45 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.167.7 61084
06/20/06 10:57:45 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:58:24 -1208355136 Toolkit Bridge:54 INFO Bridge request: mcast 224.2.167.7 61084
06/20/06 10:58:24 -1208355136 Toolkit BridgeFactory.py:108 INFO Method CreateBridge called
06/20/06 10:59:39 -1208355136 ProcessManager ProcessManager.py:42 INFO Got sigchild for unexpected process pid=1446
