[AG-TECH] Capture cards problems, URGENT
Thomas D. Uram
turam at mcs.anl.gov
Tue Jun 20 12:26:53 CDT 2006
Hi Natalia:
I have used two WinTV cards under WinXP. With AG2, you have to use the
VFW drivers. With AG 3.0.1, you should use WDM (the next release will
support
the use of either VFW or WDM).
There's a long history of success using multiple WinTV cards in Linux, so
that should not be any problem.
I have not used the Pinnacle PCTV card; maybe someone else can comment
there.
Tom
On 6/20/06 12:23 PM, Natalia Costas wrote:
> Hi everybody,
> We are in such a hurry for a new demo!.. We are intalling a demo AG
> node with all the borrowed hardware we could found (dont ask why). The
> point is we need some information:
> Has anyone tested the installation of 2 WinTV cards (878 chip) under
> WindowsXP? (i've read that with WDM drivers it doesnt work, is it
> true? does it work under Linux?).
> I had problems with the Pinnacle PCTV 110i (it's not detected by the
> Node Setup Wizard), i think the chip might be 779. Has anyone get it
> to work under WinXP?
> Thanx a lot in advance!!
> Kind regards,
