[AG-TECH] cannot start up nodeservice
    liying
    liying at vrlab.buaa.edu.cn
    Thu Jun 15 02:47:21 CDT 2006
Douglas Kosovic wrote:
> Hi LiYing,
>>     i am using agtk2.3 under FC3, but it cannot start up
>> nodeservices.  i click the item "manage my node......", but it tells
>> me  it cannot open the nodeservice at
>> http://localhost:11000/nodeservice, then i try to set up a node with
>> "Node Setup Wizard", but this doesn't do either, and the
>> NodeSetupWizard.log reports errors as follows:
> Perhaps the NodeService isn't running. Try starting the VenueClient on
> the command-line like so:
>   VenueClient.py --personalNode
> it will automatically startup an instance of the NodeService. You
> should then be able to "Manage my Node..." in the VenueClient.
> Doug
it is all right now, thank you very much!^-^
