[AG-TECH] cannot start up nodeservice
Douglas Kosovic
douglask at itee.uq.edu.au
Wed Jun 14 23:22:08 CDT 2006
Hi LiYing,
> i am using agtk2.3 under FC3, but it cannot start up nodeservices. i
> click the item "manage my node......", but it tells me it cannot open the
> nodeservice at http://localhost:11000/nodeservice, then i try to set up a
> node with "Node Setup Wizard", but this doesn't do either, and the
> NodeSetupWizard.log reports errors as follows:
Perhaps the NodeService isn't running. Try starting the VenueClient on the
command-line like so:
VenueClient.py --personalNode
it will automatically startup an instance of the NodeService. You should
then be able to "Manage my Node..." in the VenueClient.
Doug
