[AG-TECH] viewing H.261 VIC/RAT streams using QuickTime
    Laurence Kirchmeier
    laurie at merit.edu
    Sun Jun  4 21:38:16 CDT 2006
Merit is offering a VIC/RAT multicast stream of the NANOG 37
conference which is currently being held in San Jose,CA. NANOG is the
North American Network Operators Group and hold meetings around the
US 3 times a year.
I am wondering whether anyone has put together an SDP file for VIC/
RAT streams that QuickTime Player could use to display the stream.
We are using Internet2's VIC/RAT server to encode and broadcast the
stream for us - I don't know details of that server and whether it
can could create an SDP file describing the streams.
Any pointers or ideas of how to accomplish this would be much
appreciated.
Cheers
Laurie
_________________________________
Laurence Kirchmeier
Senior Engineer, Networking R&D
Merit Network Inc.              Tel. 734 936 9703
Email: laurie at merit.edu     Fax. 734 647 3185
On Jun 3, 2006, at 5:59 AM, Colin Perkins wrote:
> Changing the default to '-f PCMU/PCMU' would use no more bandwidth,
> sound 99% as good, and degrade much better in the presence of
> network problems.
> Colin
> On 3 Jun 2006, at 02:50, Andrew Sharpe wrote:
>> It's in AudioService.py
>> I've found that if I remove the '-f L16' from the arguments then
>> rat starts up with the last settings it had when shutdown nicely
>> (on linux at least).  Alternatively you can just change L16 to the
>> codec you want so that it's forced to use that on each start.
>> HTH, Andrew
>> Rosario Lombardo wrote:
>>> Hi,
>>> I'd like to have rat always use the same codec (and loss
>>> protection) settings every time it is started.
>>> I tried setting the registry keys, but unless the codec is
>>> linear16 (which is not apropriate for the clients i need the
>>> feature for), rat transmits... something at 4kb or resets to
>>> linear16, and manual configuration is required.
>>> If there is not any config file or registry key suitable for my
>>> needs, should I edit the the .py files of the venue client? If
>>> yes which one?
>>> Thank you,
>>> \\Rosario
>>> Rosario Lombardo   »«
>>> Information Science and Technology Institute (ISTI) - Cnr, Italy
>>> mailto: rosario.lombardo at isti.cnr.it <#>
>>> web: http://hpc.isti.cnr.it/~lombardo <#>
>>> tel : +39 (0)50-315-3076
>>> fax: +39 (0)50-313-8091
>>> Information Science and Technology Institute "Alessandro
>>> Faedo" (ISTI-CNR) <http://www.isti.cnr.it/>
>>> National Research Council <http://www.cnr.it/>
>>> Area della Ricerca CNR di Pisa <http://www.area.pi.cnr.it/>
>>> Via Giuseppe Moruzzi, 1
>>> I-56126 Pisa <http://www.comune.pisa.it/> Italy
>>> e-mail: rosario.lombardo at isti.cnr.it
>>> <mailto:rosario.lombardo at isti.cnr.it>
>>> web: http://hpc.isti.cnr.it/~lombardo <http://hpc.isti.cnr.it/%
>>> 7Elombardo>
>> Andrew Sharpe
>> APAC Project Officer
>> James Cook University Townsville
>> ph: +61 7 4781 4084
