[AG-TECH] rat settings
    Colin Perkins
    csp at csperkins.org
    Sat Jun  3 04:59:37 CDT 2006
Changing the default to '-f PCMU/PCMU' would use no more bandwidth,
sound 99% as good, and degrade much better in the presence of network
problems.
Colin
On 3 Jun 2006, at 02:50, Andrew Sharpe wrote:
> It's in AudioService.py
> I've found that if I remove the '-f L16' from the arguments then
> rat starts up with the last settings it had when shutdown nicely
> (on linux at least).  Alternatively you can just change L16 to the
> codec you want so that it's forced to use that on each start.
> HTH, Andrew
> Rosario Lombardo wrote:
>> Hi,
>> I'd like to have rat always use the same codec (and loss
>> protection) settings every time it is started.
>> I tried setting the registry keys, but unless the codec is
>> linear16 (which is not apropriate for the clients i need the
>> feature for), rat transmits... something at 4kb or resets to
>> linear16, and manual configuration is required.
>> If there is not any config file or registry key suitable for my
>> needs, should I edit the the .py files of the venue client? If yes
>> which one?
>> Thank you,
>> \\Rosario
>> Rosario Lombardo   »«
>> Information Science and Technology Institute (ISTI) - Cnr, Italy
>> mailto: rosario.lombardo at isti.cnr.it <#>
>> web: http://hpc.isti.cnr.it/~lombardo <#>
>> tel : +39 (0)50-315-3076
>> fax: +39 (0)50-313-8091
>> Information Science and Technology Institute "Alessandro
>> Faedo" (ISTI-CNR) <http://www.isti.cnr.it/>
>> National Research Council <http://www.cnr.it/>
>> Area della Ricerca CNR di Pisa <http://www.area.pi.cnr.it/>
>> Via Giuseppe Moruzzi, 1
>> I-56126 Pisa <http://www.comune.pisa.it/> Italy
>> e-mail: rosario.lombardo at isti.cnr.it
>> <mailto:rosario.lombardo at isti.cnr.it>
>> web: http://hpc.isti.cnr.it/~lombardo <http://hpc.isti.cnr.it/%
>> 7Elombardo>
> Andrew Sharpe
> APAC Project Officer
> James Cook University Townsville
> ph: +61 7 4781 4084
