[AG-TECH] rat settings
Andrew Sharpe
andrew.sharpe1 at jcu.edu.au
Fri Jun 2 20:50:50 CDT 2006
It's in AudioService.py
I've found that if I remove the '-f L16' from the arguments then rat
starts up with the last settings it had when shutdown nicely (on linux
at least). Alternatively you can just change L16 to the codec you want
so that it's forced to use that on each start.
HTH, Andrew
Rosario Lombardo wrote:
> Hi,
> I'd like to have rat always use the same codec (and loss protection)
> settings every time it is started.
> I tried setting the registry keys, but unless the codec is linear16
> (which is not apropriate for the clients i need the feature for), rat
> transmits... something at 4kb or resets to linear16, and manual
> configuration is required.
> If there is not any config file or registry key suitable for my needs,
> should I edit the the .py files of the venue client? If yes which one?
> Thank you,
> \\Rosario
> Rosario Lombardo »«
> Information Science and Technology Institute (ISTI) - Cnr, Italy
> mailto: rosario.lombardo at isti.cnr.it <#>
> web: http://hpc.isti.cnr.it/~lombardo <#>
> tel : +39 (0)50-315-3076
> fax: +39 (0)50-313-8091
> Information Science and Technology Institute "Alessandro Faedo"
> (ISTI-CNR) <http://www.isti.cnr.it/>
> National Research Council <http://www.cnr.it/>
> Area della Ricerca CNR di Pisa <http://www.area.pi.cnr.it/>
> Via Giuseppe Moruzzi, 1
> I-56126 Pisa <http://www.comune.pisa.it/> Italy
> e-mail: rosario.lombardo at isti.cnr.it <mailto:rosario.lombardo at isti.cnr.it>
> <http://hpc.isti.cnr.it/%7Elombardo>
Andrew Sharpe
APAC Project Officer
James Cook University Townsville
ph: +61 7 4781 4084
