[AG-TECH] Can't open Node Management in AG2.4
Thomas D. Uram
turam at mcs.anl.gov
Mon Jul 24 16:02:56 CDT 2006
I suspect that you ran the VenueClient without the '--personalNode'
option. If you
use this option, the NodeService and ServiceManager are run internal to
the VenueClient,
and you should not have this problem.
Tom
On 7/24/06 1:53 PM, Zephyr Zhangbo Liu wrote:
> Hi all,
> I met a problem in running Node Management. I have two X86_64
> machines, one is on SUSE 10.1 and the other in on XP. When I ran
> NodeManagement24 on SUSE, the window showed up with most of its
> feature disabled and the error message was:
> <Fault SOAP-ENV:Client: Method Not Found: NodeService:IsValid :
> exceptions.KeyError 'NodeService' <traceback object at 0x2aaaaf65c5a8>>
> Then I ran Venue Client and selected Preference->Manage My Node. It
> said could not open node management at the given URL.
> Could anyone tell me how to solve this problem.
> Thanks,
> Zephyr
