[AG-TECH] Can't open Node Management in AG2.4
Zephyr Zhangbo Liu
zephyr at cs.ubc.ca
Mon Jul 24 17:39:01 CDT 2006
Hi Tom,
You are right. With '--personalNode' option now the Node Management is
running. But now my question is: I need two machines to compose one node. If
I use this option on both of them, are they able to find and connect with
each other?
Second, can the machines stay behind the firewall? If they stay outside,
then their IPs will be dynamically allocated so that it is hard to assign
them permanent host names that binding with their IPs.
Zephyr
On 7/24/06, Thomas D. Uram <turam at mcs.anl.gov> wrote:
> I suspect that you ran the VenueClient without the '--personalNode'
> option. If you
> use this option, the NodeService and ServiceManager are run internal to
> the VenueClient,
> and you should not have this problem.
> Tom
> On 7/24/06 1:53 PM, Zephyr Zhangbo Liu wrote:
> > Hi all,
> > I met a problem in running Node Management. I have two X86_64
> > machines, one is on SUSE 10.1 and the other in on XP. When I ran
> > NodeManagement24 on SUSE, the window showed up with most of its
> > feature disabled and the error message was:
> > <Fault SOAP-ENV:Client: Method Not Found: NodeService:IsValid :
> > exceptions.KeyError 'NodeService' <traceback object at 0x2aaaaf65c5a8>>
> > Then I ran Venue Client and selected Preference->Manage My Node. It
> > said could not open node management at the given URL.
> > Could anyone tell me how to solve this problem.
> > Thanks,
> > Zephyr
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060724/aea5939c/attachment.htm>
