[AG-TECH] Access Grid Toolkit 2.4 and 3.0.1
Rosario Lombardo
rosario.lombardo at isti.cnr.it
Sat Jul 22 09:36:43 CDT 2006
I also wanted to have all so I'm building a customized installer.
Meanwhile you may have SharedBrowser, AG2.4 and AG3.0 just installing
everything in the order you will find here:
http://hpc.isti.cnr.it/accessgrid/software/1_AccessGrid/AG_v3.0_and_v2.4/
Please read Howto-install.txt for further info.
VenueClient3.py is modified to use the correct version of wx2.6.
The install-time customiziable installer is being tested in our
institution and I'll post here its features when will pass the beta stage.
\\Rosario
Rosario Lombardo
Information Science and Technology Institute (ISTI) - Cnr, Italy
mailto: rosario.lombardo at isti.cnr.it tel :+39 050-315-3076
web: http://hpc.isti.cnr.it/~lombardo fax:+39 050-315-2040
Thomas D. Uram wrote:
> You can have both versions installed on the same machine.
> The requirement of wxPython 2.6 for AG3 is not absolutely
> necessary, but we have moved to it because it is regarded
> as the stable version (wx2.5 releases were all development
> releases).
> AG2.4 will work with wx2.6, with one exception: the
> SharedBrowser application included with AG2.4 will not
> start. If that doesn't concern you, then you should be all set.
> Tom
> On 7/21/06 2:22 PM, Tanner, Kenneth wrote:
>> I have loaded AG Toolkit 3.0.1 but need to access some sites running
>> 2.4. Can you have both 3.0.1 and 2.4 installed on the same machine.
>> What about wxPython 2.6. Will AGT 2.4 operate with wxP 2.6?
>> Thanks,
>> Kenneth
>> Access Grid Toolkit 3.0.1 - Windows Installation
>> Python 2.3
>> Python win32 Extensions
>> wxPython 2.6
>> Bonjour
>> AccessGrid Toolkit 3.0.1
>> Access Grid Toolkit 2.4 - Windows Installation
>> Python 2.3
>> wxPython 2.5
>> Kenneth Tanner
>> LSU Health Sciences Center - Shreveport
>> Dept. of Bioinformatics & Computational Biology
>> 1501 Kings Highway
>> Shreveport La. 71130
>> Phone #: 318-675-4645
>> Email: mailto:ktanne1 at lsuhsc.edu
>> "Think of the poorest person you have ever seen and ask if your next act
>> will be of any use to him"
>> Mohandas Karamchand Gandhi
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060722/c543b19c/attachment.htm>
