[AG-TECH] Re: AG3b1 network hang on WinXP SP2
Rosario Lombardo
rosario.lombardo at isti.cnr.it
Mon Jan 30 12:56:31 CST 2006
Tom,
changing the thread title.
I followed these steps:
unistalled wxPython2.5/2.6 and installed wxPython2.6 required for AG3b1:
ok, both UI display fine, AG3 stops network connections as before.
Complete unistall of every single package related to AG, *including*
ActiveState Python.
Reboot.
Installation of the following in order:
Python-2.3.5.exe
pywin32-207.win32-py2.3.exe
wxPython2.6-win32-unicode-2.6.2.1-py23.exe
BonjourSetup.exe
Restart as requested
BonjourSDKSetup.exe
AGTk-2.4-Final1-Py-2.3.exe
Connect AGTk2.4 to NCSA Lobby: everything Ok!
noticed the wxPython look change
AGTk-3.0-beta1-Py-2.3.exe
Run AG3b1: Audio service already available, but impossible to add
Video services (my first try before complete reinstall was filling in
only the personal info without any further configuration)
Connect AGTk3.0 to AG3 Beta Lobby:
- seems much slower than previous version
- connected, but immediately hang (Not Responding in title bar):
seen exists NCSA, vv2 and only me in participants
- after a while the AG3 window has been unresponsive, all network
connections of each program were shutdown: as before a blind node.
- restart (sigh!)
Connect AGTk2.4 to NCSA Lobby and ANL Lobby: everything Ok!
Fear to start over AG3b1 :-)
You find attached full logs since the very first AG3 installation
Hope this can help troubleshooting.
\\Rosario
Rosario Lombardo
Information Science and Technology Institute (ISTI) - Cnr, Italy
<mailto:rosario.lombardo at isti.cnr.it> *-* http://hpc.isti.cnr.it/~lombardo
<http://hpc.isti.cnr.it/%7Elombardo>
phone: +39 050-315-3076
Thomas D. Uram wrote:
> On 1/30/06 8:13 AM, Rosario Lombardo wrote:
>> I tried the Toolkit on Windows XP SP2.
>> I installed all the prerequisite software except Python 2.3 because
>> I'm using the same version used for AGTk2.4.
>> Here are the troubles :)
>> - Started the client, I noticed a mis arrangement of the graphical
>> controls (the address bar is squeezed by top toolbar and the Venue
>> name)
> I expect you're using wxPython 2.5, which will cause problems like
> this. You
> can upgrade to wxPython2.6 and that will fix the UI problems; I've
> done this
> and it hasn't (yet) caused a problem with my AG2 install.
>> - Starting the client makes the network unreacheable (no other net
>> app works!!) and is worthless repairing or disabling-enabling the
>> connection, nor ending running process: RESTART is required!
>> - I tried 3 times always with same results: errors in log relate to
>> + ZSI
>> + servicecontainer.py
>> + 'rtpDefaultsFile' referenced before assignment
>> + Audio/Video services
>> - Let me know if you need the full logs
>> - I get a can't connect to vv3 server error (of course, as network
>> appears disconnected)
> I'd be interested in seeing the logfiles to better understand what is
> going
> wrong on your system. I don't think the AG software can account for
> that problem, but if it's not working, it's something we need to look at.
> Grazie,
> Tom
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060130/d6500262/attachment.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060130/d6500262/attachment.diff>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060130/d6500262/attachment-0001.diff>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060130/d6500262/attachment-0002.diff>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060130/d6500262/attachment-0003.diff>
