[AG-TECH] Re: AG3b1 network hang on WinXP SP2
    Thomas D. Uram
    turam at mcs.anl.gov
    Mon Jan 30 13:06:09 CST 2006
Rosario:
Thanks so much for this feedback.  We're going to face some difficulties, and
detailed reporting will help us overcome them.  We'll be looking at your
logfiles and get back to you as soon as possible.
Tom
On 1/30/06 12:56 PM, Rosario Lombardo wrote:
> Tom,
> changing the thread title.
> I followed these steps:
> unistalled wxPython2.5/2.6 and installed wxPython2.6 required for AG3b1:
> ok, both UI display fine, AG3 stops network connections as before.
> Complete unistall of every single package related to AG, *including*
> ActiveState Python.
> Reboot.
> Installation of the following in order:
> Python-2.3.5.exe
> pywin32-207.win32-py2.3.exe
> wxPython2.6-win32-unicode-2.6.2.1-py23.exe
> BonjourSetup.exe
>    Restart as requested
> BonjourSDKSetup.exe
> AGTk-2.4-Final1-Py-2.3.exe
>   Connect AGTk2.4 to NCSA Lobby: everything Ok!
>                                  noticed the wxPython look change
> AGTk-3.0-beta1-Py-2.3.exe
>   Run AG3b1: Audio service already available, but impossible to add
> Video services (my first try before complete reinstall was filling in
> only the personal info without any further configuration)
>   Connect AGTk3.0 to AG3 Beta Lobby:
>     - seems much slower than previous version
>     - connected, but immediately hang (Not Responding in title bar):
> seen exists NCSA, vv2 and only me in participants
>     - after a while the AG3 window has been unresponsive, all network
> connections of each program were shutdown: as before a blind node.
>     - restart (sigh!)
>   Connect AGTk2.4 to NCSA Lobby and ANL Lobby: everything Ok!
>   Fear to start over AG3b1 :-)
> You find attached full logs since the very first AG3 installation
> Hope this can help troubleshooting.
> Regards,
> \\Rosario
> Rosario Lombardo
> Information Science and Technology Institute (ISTI) - Cnr, Italy
> rosario.lombardo at isti.cnr.it
> <mailto:rosario.lombardo at isti.cnr.it>   *-*   http://hpc.isti.cnr.it/~lombardo
> <http://hpc.isti.cnr.it/%7Elombardo>
> phone: +39 050-315-3076
> Thomas D. Uram wrote:
>> On 1/30/06 8:13 AM, Rosario Lombardo wrote:
>>> I tried the Toolkit on Windows XP SP2.
>>> I installed all the prerequisite software except Python 2.3 because
>>> I'm using the same version used for AGTk2.4.
>>> Here are the troubles :)
>>> - Started the client, I noticed a mis arrangement of the graphical
>>> controls (the address bar is squeezed  by top toolbar and the Venue
>>> name)
>> I expect you're using wxPython 2.5, which will cause problems like
>> this.  You
>> can upgrade to wxPython2.6 and that will fix the UI problems; I've
>> done this
>> and it hasn't (yet) caused a problem with my AG2 install.
>>> - Starting the client makes the network unreacheable (no other net
>>> app works!!) and is worthless repairing or disabling-enabling the
>>> connection, nor ending running process: RESTART is required!
>>> - I tried 3 times always with same results: errors in log relate to
>>>     + ZSI
>>>     + servicecontainer.py
>>>     + 'rtpDefaultsFile' referenced before assignment
>>>     + Audio/Video services
>>> - Let me know if you need the full logs
>>> - I get a can't connect to vv3 server error (of course, as network
>>> appears disconnected)
>> I'd be interested in seeing the logfiles to better understand what is
>> going
>> wrong on your system.  I don't think the AG software can account for
>> that problem, but if it's not working, it's something we need to look at.
>> Grazie,
>> Tom
> 01/30/06 18:41:54 3556 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 18:41:54 3556 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 18:41:54 3556 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoProducerService\\VideoProducerService.py', '--port', '59533', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580e0802d731b90baecc6ac0d9']
> 01/30/06 18:41:54 3556 Toolkit     videoproducerservice.py:557 INFO  Using vfwscan to get devices
> 01/30/06 18:41:54 3556 Toolkit     videoproducerservice.py:558 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-3\bin\vfwscan.exe
> 01/30/06 18:41:55 3556 Toolkit     videoproducerservice.py:563 DEBUG vfwscan filelines = ['Microsoft WDM Image Capture (Win32)\n']
> 01/30/06 18:41:55 3556 Toolkit     videoproducerservice.py:580 INFO  Using wdmscan to get devices
> 01/30/06 18:41:55 3556 Toolkit     videoproducerservice.py:581 DEBUG wdmscanexe = C:\PROGRA~1\AGTk-3\bin\wdmscan.exe
> 01/30/06 18:41:56 3556 Toolkit     videoproducerservice.py:586 DEBUG wdmscan filelines = ['Logitech QuickCam Pro 5000\n']
> 01/30/06 18:41:56 3556 Toolkit     videoproducerservice.py:618 INFO  GetResources: ['Microsoft WDM Image Capture (Win32)', 'Logitech QuickCam Pro 5000']
> 01/30/06 18:41:56 3556 Toolkit     config.py:562 INFO  Found 2 processors; setting affinity
> 01/30/06 18:41:57 3556 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 18:41:57 3556 Toolkit     toolkit.py:156 INFO  Logfile Name: VideoProducerService.log
> 01/30/06 18:41:57 3556 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 18:41:57 3556 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 18:41:57 3556 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:59533/Services/VideoProducerService.923052580b7802d735d277087f66ffc5
> 01/30/06 18:41:57 3556 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/29/06 17:00:16 3732 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/29/06 17:00:16 3732 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/29/06 17:00:16 3732 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', '56257', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580908024a0e8f3780f685351c']
> 01/29/06 17:00:16 3732 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/29/06 17:00:16 3732 Toolkit     toolkit.py:156 INFO  Logfile Name: AudioService.log
> 01/29/06 17:00:16 3732 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/29/06 17:00:16 3732 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/29/06 17:00:16 3732 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:56257/Services/AudioService.923052580a0c024a10d232f9bca66ada
> 01/29/06 17:00:16 3732 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/29/06 17:00:17 1824 Toolkit     agservice.py:153 INFO  SetConfiguration: Unrecognized parameter ignored: Force AC97
> 01/29/06 17:00:17 1824 Toolkit     audioservice.py:367 INFO  SetIdentity: <Insert Name Here> <Insert Email Address Here>
> 01/30/06 10:46:34 1088 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 10:46:34 1088 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 10:46:34 1088 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', '55084', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '92305258063802ababd68403a54c38f9']
> 01/30/06 10:46:37 1088 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 10:46:37 1088 Toolkit     toolkit.py:156 INFO  Logfile Name: AudioService.log
> 01/30/06 10:46:37 1088 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 10:46:37 1088 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 10:46:37 1088 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:55084/Services/AudioService.9230525803f002abb113ea94cafde55f
> 01/30/06 10:46:37 1088 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 14:37:40 3432 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 14:37:40 3432 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 14:37:40 3432 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', '65049', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '9230525808a002c0d5676ef12021c65e']
> 01/30/06 14:37:41 3432 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 14:37:41 3432 Toolkit     toolkit.py:156 INFO  Logfile Name: AudioService.log
> 01/30/06 14:37:41 3432 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 14:37:41 3432 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 14:37:41 3432 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:65049/Services/AudioService.9230525803c802c0d8beb2fe1f104835
> 01/30/06 14:37:41 3432 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 14:37:41 152 Toolkit     agservice.py:153 INFO  SetConfiguration: Unrecognized parameter ignored: Force AC97
> 01/30/06 14:37:41 152 Toolkit     audioservice.py:367 INFO  SetIdentity: Rosario Lombardo rosario.lombardo at isti.cnr.it
> 01/30/06 14:43:19 2388 Toolkit     agservice.py:238 INFO  Shut service down
> 01/30/06 14:43:19 2388 Toolkit     audioservice.py:313 INFO  Stop service
> 01/30/06 14:43:19 2388 Toolkit     audioservice.py:324 INFO  Executing rat-kill
> 01/30/06 14:43:19 2388 ProcessManager     processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
> 01/30/06 14:43:19 2388 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:680>, <PyHANDLE:684>, 332, 764)
> 01/30/06 18:39:42 3304 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 18:39:42 3304 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 18:39:42 3304 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', '59910', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580e0802d6fe6ef837f081840d']
> 01/30/06 18:39:44 3304 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 18:39:44 3304 Toolkit     toolkit.py:156 INFO  Logfile Name: AudioService.log
> 01/30/06 18:39:44 3304 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 18:39:44 3304 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 18:39:44 3304 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:59910/Services/AudioService.923052580d5402d701c3f366df7be34a
> 01/30/06 18:39:44 3304 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 18:39:44 4036 Toolkit     agservice.py:153 INFO  SetConfiguration: Unrecognized parameter ignored: Force AC97
> 01/30/06 18:39:44 4036 Toolkit     audioservice.py:367 INFO  SetIdentity: Rosario Lombardo rosario.lombardo at isti.cnr.it
> 01/30/06 18:44:01 3132 Toolkit     agservice.py:238 INFO  Shut service down
> 01/30/06 18:44:01 3132 Toolkit     audioservice.py:313 INFO  Stop service
> 01/30/06 18:44:01 3132 Toolkit     audioservice.py:324 INFO  Executing rat-kill
> 01/30/06 18:44:01 3132 ProcessManager     processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
> 01/30/06 18:44:01 3132 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:680>, <PyHANDLE:684>, 3624, 2824)
> 01/30/06 18:44:01 3132 ProcessManager     processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:680>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
> Traceback (most recent call last):
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\Platform\win32\ProcessManager.py", line 128, in TerminateProcess
>     win32api.PostThreadMessage(self.threadid[pid], 18, 0, 0)
> error: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
> 01/30/06 18:44:01 3132 ProcessManager     processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:680>: (5, 'TerminateProcess', 'Access is denied.')
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\Platform\win32\ProcessManager.py", line 139, in TerminateProcess
>     win32process.TerminateProcess(pid, 0)
> error: (5, 'TerminateProcess', 'Access is denied.')
> 01/30/06 19:21:18 2088 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 19:21:18 2088 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 19:21:18 2088 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', '55525', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '92305258067802dacdb597224e1bd37d']
> 01/30/06 19:21:18 2088 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 19:21:18 2088 Toolkit     toolkit.py:156 INFO  Logfile Name: AudioService.log
> 01/30/06 19:21:18 2088 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 19:21:18 2088 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 19:21:18 2088 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:55525/Services/AudioService.923052580b9802dad04ac8ec218d7ce7
> 01/30/06 19:21:18 2088 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 19:21:19 3372 Toolkit     agservice.py:153 INFO  SetConfiguration: Unrecognized parameter ignored: Force AC97
> 01/30/06 19:21:19 3372 Toolkit     audioservice.py:367 INFO  SetIdentity: Rosario Lombardo rosario.lombardo at isti.cnr.it
> 01/30/06 19:23:06 1988 Toolkit     agservice.py:171 INFO  SetStream: [consumer, audio, 923052580b9802dacfed01939b1d5f7e, L16, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, L16, 8000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, L8, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, L8, 8000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, PCMU, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, PCMU, 8000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, GSM, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, GSM, 8000, 1, producer, audio, 923052580b9802dacfed01939b1d5f7e, L16, 16000, 1] 224.2.240.117 52374
> 01/30/06 19:23:06 1988 Toolkit     audioservice.py:313 INFO  Stop service
> 01/30/06 19:23:06 1988 Toolkit     audioservice.py:324 INFO  Executing rat-kill
> 01/30/06 19:23:06 1988 ProcessManager     processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
> 01/30/06 19:23:06 1988 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:688>, <PyHANDLE:692>, 3792, 2224)
> 01/30/06 19:23:06 1988 ProcessManager     processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:688>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
> 01/30/06 19:23:06 1988 ProcessManager     processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:688>: (5, 'TerminateProcess', 'Access is denied.')
> 01/30/06 19:23:06 1988 Toolkit     audioservice.py:298 INFO  Starting AudioService
> 01/30/06 19:23:06 1988 Toolkit     audioservice.py:299 INFO   executable = C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\AudioService\rat.exe
> 01/30/06 19:23:06 1988 Toolkit     audioservice.py:301 INFO   options = ['-C', u'AG3 Beta Lobby', '-f', 'L16-16K-Mono', '-t', '127', u'224.2.240.117/52374']
> 01/30/06 19:23:06 1988 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C "AG3 Beta Lobby" -f L16-16K-Mono -t 127 224.2.240.117/52374
> 01/30/06 19:23:06 1988 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:672>, <PyHANDLE:696>, 2812, 3328)
> 01/30/06 19:28:26 4068 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 19:28:26 4068 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 19:28:26 4068 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', '63401', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580eb802db759f41cd5681921f']
> 01/30/06 19:28:27 4068 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 19:28:27 4068 Toolkit     toolkit.py:156 INFO  Logfile Name: AudioService.log
> 01/30/06 19:28:27 4068 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 19:28:27 4068 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 19:28:27 4068 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:63401/Services/AudioService.9230525806ac02db77c9b410731af5fd
> 01/30/06 19:28:27 4068 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 19:28:27 2848 Toolkit     agservice.py:153 INFO  SetConfiguration: Unrecognized parameter ignored: Force AC97
> 01/30/06 19:28:27 2848 Toolkit     audioservice.py:367 INFO  SetIdentity: Rosario Lombardo rosario.lombardo at isti.cnr.it
> 01/30/06 19:30:04 3784 Toolkit     agservice.py:238 INFO  Shut service down
> 01/30/06 19:30:04 3784 Toolkit     audioservice.py:313 INFO  Stop service
> 01/30/06 19:30:04 3784 Toolkit     audioservice.py:324 INFO  Executing rat-kill
> 01/30/06 19:30:04 3784 ProcessManager     processmanager.py:59 DEBUG Creating process: .\rat-kill.exe
> 01/30/06 19:30:04 3784 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:680>, <PyHANDLE:684>, 2348, 3092)
> 01/30/06 19:30:04 3784 ProcessManager     processmanager.py:135 ERROR couldn't shutdown process <PyHANDLE:680>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
> 01/30/06 19:30:04 3784 ProcessManager     processmanager.py:142 ERROR couldn't terminate process <PyHANDLE:680>: (5, 'TerminateProcess', 'Access is denied.')
> 01/29/06 17:00:09 628 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/29/06 17:00:09 628 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/29/06 17:00:09 628 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient.py', '--personalNode=1']
> 01/29/06 17:00:09 628 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/29/06 17:00:09 628 Toolkit     toolkit.py:156 INFO  Logfile Name: VenueClient.log
> 01/29/06 17:00:10 628 Toolkit     venueclient.py:80 INFO  wx version is: 2.5.1.5
> 01/29/06 17:00:10 628 VenueClient     venueclient.py:329 DEBUG __StartWebService: venueclient: http://sharker.isti.cnr.it:11000/VenueClient
> 01/29/06 17:00:10 628 VenueClient     venueclient.py:340 DEBUG __StartWebService: service manager: http://sharker.isti.cnr.it:11000/ServiceManager
> 01/29/06 17:00:10 628 VenueClient     venueclient.py:354 DEBUG __StartWebService: node service: http://sharker.isti.cnr.it:11000/NodeService
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:517 INFO  NodeService.GetConfigurations
> 01/29/06 17:00:10 628 VenueClient     venueclient.py:156 DEBUG Loading default node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x026E0990>
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:257 INFO  NodeService.LoadConfiguration
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:276 INFO  Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:284 DEBUG section: node
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   servicemanagers : servicemanager0
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:284 DEBUG section: service1
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   packageName : VideoConsumerService.zip
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:284 DEBUG section: service0
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   packageName : AudioService.zip
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   serviceConfig : serviceconfig0
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:284 DEBUG section: servicemanager0
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   services : service0 service1
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   builtin : 1
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   name :
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   url :
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:284 DEBUG section: serviceconfig0
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   Force AC97 : False
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   Silence Suppression : Off
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   Output Gain : 50
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   Talk : Off
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:286 DEBUG   Input Gain : 50
> 01/29/06 17:00:10 628 NodeService     agnodeservice.py:361 DEBUG using builtin service manager at http://sharker.isti.cnr.it:11000/ServiceManager
> 01/29/06 17:00:10 2184 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/29/06 17:00:10 3996 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/29/06 17:00:10 3996 ServiceManager     agservicemanager.py:130 INFO  Extracting service package to C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\AudioService
> 01/29/06 17:00:11 3996 ServiceManager     agservicemanager.py:371 DEBUG Executing service AudioService
> 01/29/06 17:00:11 3996 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 56257, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580908024a0e8f3780f685351c']
> 01/29/06 17:00:11 3996 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 56257 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 923052580908024a0e8f3780f685351c
> 01/29/06 17:00:11 3996 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:948>, <PyHANDLE:936>, 2572, 3732)
> 01/29/06 17:00:17 3996 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:56257/Services/AudioService.923052580a0c024a10d232f9bca66ada 923052580908024a0e8f3780f685351c
> 01/29/06 17:00:17 3036 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/29/06 17:00:17 3036 ServiceManager     agservicemanager.py:130 INFO  Extracting service package to C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService
> 01/29/06 17:00:17 3036 ServiceManager     agservicemanager.py:371 DEBUG Executing service VideoConsumerService
> 01/29/06 17:00:17 3036 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', 55419, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580908024a113b17db4af3369c']
> 01/29/06 17:00:17 3036 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py" --port 55419 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 923052580908024a113b17db4af3369c
> 01/29/06 17:00:17 3036 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1056>, <PyHANDLE:960>, 2384, 2144)
> 01/29/06 17:00:23 3036 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:55419/Services/VideoConsumerService.923052580950024a1363bf4ee1bb6c89 923052580908024a113b17db4af3369c
> 01/29/06 17:00:23 3036 Hosting     servicecontainer.py:16 ERROR Processing Failure
> ZSI:FaultException
> Processing Failure
> exceptions:UnboundLocalError
> local variable 'rtpDefaultsFile' referenced before assignment
> [trace: C:\Python23\Lib\site-packages\ZSI\ServiceContainer.py:107:_Dispatch
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\AGService_interface.py:1187:soap_SetPackageFile
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\AGService.py:277:SetPackageFile
> C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py:183:SetIdentity
> C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py:71:__SetRTPDefaults]
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\AGServiceManager_interface.py:821:soap_AddServiceByName
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\AGServiceManager.py:94:AddServiceByName
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\AGServiceManager.py:148:AddService
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\AGService_client.py:238:SetPackageFile
> C:\Python23\Lib\site-packages\ZSI\client.py:415:Receive]
> 01/29/06 17:00:23 628 NodeService     agnodeservice.py:396 ERROR Exception adding service VideoConsumerService.zip
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\AGNodeService.py", line 393, in LoadConfiguration
>     prefs.GetProfile())
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\AGServiceManager_client.py", line 62, in AddServiceByName
>     response = self.binding.Receive(AddServiceByNameResponse.typecode)
>   File "C:\Python23\Lib\site-packages\ZSI\client.py", line 415, in Receive
>     raise FaultException(msg)
> FaultException: Processing Failure
> ZSI:FaultException
> Processing Failure
> 01/29/06 17:00:23 628 VenueClient     venueclient.py:162 ERROR Error loading default configuration
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\VenueClient.py", line 157, in __init__
>     self.nodeService.LoadConfiguration(defaultConfig)
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\AGNodeService.py", line 400, in LoadConfiguration
>     raise Exception(exceptionText)
> Exception: Couldn't add service VideoConsumerService.zip
> 01/29/06 17:00:26 628 VenueClientController     venueclientcontroller.py:1265 DEBUG There is no personal venues file to load.
> 01/29/06 17:00:26 628 VenueClient     venueclientui.py:203 DEBUG the profile is the default profile - open profile dialog
> 01/29/06 17:00:27 628 VenueClient     venueclientui.py:4357 DEBUG VenueClientUI.py: Set editable in successfully dialog
> 01/29/06 17:00:27 628 VenueClient     venueclientui.py:4437 DEBUG ProfileDialog.SetProfile: Set profile information successfully in dialog
> 01/29/06 17:01:18 628 VenueClient     venueclientui.py:4416 DEBUG ProfileDialog.GetNewProfile: Got profile information from dialog
> 01/29/06 17:01:18 628 VenueClient     preferences.py:151 DEBUG Preferences.StorePreferences: open file
> 01/29/06 17:01:18 628 VenueClient     venueclient.py:1210 DEBUG VenueClient.UpdateClientProfile
> 01/29/06 17:01:18 628 VenueClientController     venueclientcontroller.py:642 ERROR bin.VenueClient::ChangeProfile: Error occured when trying to update profile
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\VenueClientController.py", line 640, in ChangeProfile
>     self.__venueClient.UpdateClientProfile(profile)
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\VenueClient.py", line 1212, in UpdateClientProfile
>     if self.__venueClient.GetVenue() != None:
> AttributeError: VenueClient instance has no attribute '_VenueClient__venueClient'
> 01/29/06 17:01:57 628 VenueClientController     venueclientcontroller.py:385 DEBUG VenueClientController calling Venue.EnterVenue
> 01/29/06 17:01:57 628 VenueClient     venueclient.py:933 DEBUG EnterVenue; url=https://vv3.mcs.anl.gov:8000/Venues/default
> 01/29/06 17:01:57 628 NodeService     agnodeservice.py:540 INFO  NodeService.GetCapabilities
> 01/29/06 17:01:57 628 NodeService     agnodeservice.py:139 INFO  NodeService.GetServices
> 01/29/06 17:01:57 2052 ServiceManager     agservicemanager.py:219 INFO  AGServiceManager.GetServices
> 01/29/06 17:01:57 628 VenueClient     venueclient.py:955 DEBUG calling __EnterVenue
> 01/29/06 17:01:57 628 VenueClient     venueclient.py:742 DEBUG EnterVenue: Invoke Venue.Enter
> 01/29/06 17:01:57 628 VenueClient     venueclient.py:963 ERROR EnterVenue: failed
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\VenueClient.py", line 956, in EnterVenue
>     self.__EnterVenue(URL)
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\VenueClient.py", line 743, in __EnterVenue
>     self.profile.connectionId = self.__venueProxy.Enter( self.profile )
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\Venue_client.py", line 38, in Enter
>     self.binding.Send(None, None, request, soapaction="urn:#Enter", **kw)
>   File "C:\Python23\Lib\site-packages\ZSI\client.py", line 251, in Send
>     self.h.connect()
>   File "C:\Python23\lib\httplib.py", line 961, in connect
>     ssl = socket.ssl(sock, self.key_file, self.cert_file)
> AttributeError: 'module' object has no attribute 'ssl'
> 01/29/06 17:01:57 628 VenueClient     venueclientui.py:2416 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv3.mcs.anl.gov:8000/Venues/default
> 01/29/06 17:01:57 628 VenueClient     venueclientui.py:2432 DEBUG warningString:
> 01/29/06 17:01:57 628 VenueClientController     venueclientcontroller.py:387 DEBUG VenueClientController after Venue.EnterVenue
> 01/30/06 10:29:06 628 VenueClient     venueclientui.py:2036 INFO  --------- END VenueClient
> 01/30/06 10:29:06 628 ServiceManager     agservicemanager.py:69 INFO  AGServiceManager.Shutdown
> 01/30/06 10:29:06 628 ServiceManager     agservicemanager.py:70 INFO  Remove services
> 01/30/06 10:29:06 628 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 10:29:06 628 ServiceManager     agservicemanager.py:161 INFO  AGServiceManager.RemoveService
> 01/30/06 10:29:07 628 ServiceManager     agservicemanager.py:179 ERROR Error shutting down service AudioService
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\AGServiceManager.py", line 177, in RemoveService
>     AGServiceIW( service.uri ).Shutdown()
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\AGService_client.py", line 295, in Shutdown
>     self.binding.Send(None, None, request, soapaction="urn:#Shutdown", **kw)
>     self.h.connect()
>   File "C:\Python23\lib\httplib.py", line 548, in connect
>     raise socket.error, msg
> error: (10061, 'Connection refused')
> 01/30/06 10:29:07 628 ProcessManager     processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:948> cleanly (258)
> 01/30/06 10:29:07 628 ServiceManager     agservicemanager.py:72 INFO  Stop network interface
> 01/30/06 10:46:22 3400 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 10:46:22 3400 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 10:46:22 3400 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient.py', '--personalNode=1']
> 01/30/06 10:46:22 3400 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 10:46:22 3400 Toolkit     toolkit.py:156 INFO  Logfile Name: VenueClient.log
> 01/30/06 10:46:22 3400 Toolkit     venueclient.py:80 INFO  wx version is: 2.5.1.5
> 01/30/06 10:46:22 3400 VenueClient     venueclient.py:329 DEBUG __StartWebService: venueclient: http://sharker.isti.cnr.it:11000/VenueClient
> 01/30/06 10:46:22 3400 VenueClient     venueclient.py:340 DEBUG __StartWebService: service manager: http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 10:46:22 3400 VenueClient     venueclient.py:354 DEBUG __StartWebService: node service: http://sharker.isti.cnr.it:11000/NodeService
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:517 INFO  NodeService.GetConfigurations
> 01/30/06 10:46:22 3400 VenueClient     venueclient.py:156 DEBUG Loading default node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x02A27918>
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:257 INFO  NodeService.LoadConfiguration
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:276 INFO  Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:284 DEBUG section: node
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   servicemanagers : servicemanager0
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:284 DEBUG section: service1
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   packageName : VideoConsumerService.zip
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:284 DEBUG section: service0
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   packageName : AudioService.zip
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   serviceConfig : serviceconfig0
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:284 DEBUG section: servicemanager0
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   services : service0 service1
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   builtin : 1
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   name :
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   url :
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:284 DEBUG section: serviceconfig0
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   Force AC97 : False
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   Silence Suppression : Off
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   Output Gain : 50
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   Talk : Off
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:286 DEBUG   Input Gain : 50
> 01/30/06 10:46:22 3400 NodeService     agnodeservice.py:361 DEBUG using builtin service manager at http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 10:46:23 996 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 10:46:23 944 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 10:46:23 944 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 10:46:23 944 ServiceManager     agservicemanager.py:371 DEBUG Executing service AudioService
> 01/30/06 10:46:23 944 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 55084, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '92305258063802ababd68403a54c38f9']
> 01/30/06 10:46:23 944 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 55084 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 92305258063802ababd68403a54c38f9
> 01/30/06 10:46:24 944 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1132>, <PyHANDLE:1136>, 1008, 1088)
> 01/30/06 10:46:34 944 ServiceManager     agservicemanager.py:417 INFO  Service failed to register: 92305258063802ababd68403a54c38f9
> 01/30/06 10:46:34 944 Hosting     servicecontainer.py:16 ERROR Processing Failure
> exceptions:Exception
> Service failed to become reachable
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\AGServiceManager.py:145:AddService
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\AGServiceManager.py:418:__ExecuteService]
> 01/30/06 10:46:34 3400 NodeService     agnodeservice.py:396 ERROR Exception adding service AudioService.zip
>     prefs.GetProfile())
> 01/30/06 10:46:34 772 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 10:46:34 772 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 10:46:34 772 ServiceManager     agservicemanager.py:371 DEBUG Executing service VideoConsumerService
> 01/30/06 10:46:34 772 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', 51864, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '92305258063802abb0352cb7dc5906ab']
> 01/30/06 10:46:34 772 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py" --port 51864 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 92305258063802abb0352cb7dc5906ab
> 01/30/06 10:46:34 772 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:12>, <PyHANDLE:1084>, 2560, 2564)
> 01/30/06 10:46:37 772 ServiceManager     agservicemanager.py:415 INFO  Service registered: None 92305258063802abb0352cb7dc5906ab
> 01/30/06 10:46:37 772 Hosting     servicecontainer.py:16 ERROR Processing Failure
> exceptions:AttributeError
> 'NoneType' object has no attribute 'find'
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\AGService_client.py:236:SetPackageFile
> C:\Python23\Lib\site-packages\ZSI\client.py:235:Send
> C:\Python23\lib\urlparse.py:49:urlparse
> C:\Python23\lib\urlparse.py:79:urlsplit]
> 01/30/06 10:46:37 3400 NodeService     agnodeservice.py:396 ERROR Exception adding service VideoConsumerService.zip
>     prefs.GetProfile())
> 01/30/06 10:46:37 3400 VenueClient     venueclient.py:162 ERROR Error loading default configuration
> Exception: Couldn't add service AudioService.zipCouldn't add service VideoConsumerService.zip
> 01/30/06 10:46:40 3400 VenueClientController     venueclientcontroller.py:1265 DEBUG There is no personal venues file to load.
> 01/30/06 10:47:31 3400 VenueClientController     venueclientcontroller.py:385 DEBUG VenueClientController calling Venue.EnterVenue
> 01/30/06 10:47:31 3400 VenueClient     venueclient.py:933 DEBUG EnterVenue; url=https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 10:47:31 3400 NodeService     agnodeservice.py:540 INFO  NodeService.GetCapabilities
> 01/30/06 10:47:31 3400 NodeService     agnodeservice.py:139 INFO  NodeService.GetServices
> 01/30/06 10:47:31 2208 ServiceManager     agservicemanager.py:219 INFO  AGServiceManager.GetServices
> 01/30/06 10:47:31 3400 VenueClient     venueclient.py:955 DEBUG calling __EnterVenue
> 01/30/06 10:47:31 3400 VenueClient     venueclient.py:742 DEBUG EnterVenue: Invoke Venue.Enter
> 01/30/06 10:47:31 3400 VenueClient     venueclient.py:963 ERROR EnterVenue: failed
>     self.h.connect()
> 01/30/06 10:47:31 3400 VenueClient     venueclientui.py:2416 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 10:47:31 3400 VenueClient     venueclientui.py:2432 DEBUG warningString:
> 01/30/06 10:47:31 3400 VenueClientController     venueclientcontroller.py:387 DEBUG VenueClientController after Venue.EnterVenue
> 01/30/06 10:48:30 3400 VenueClientController     venueclientcontroller.py:385 DEBUG VenueClientController calling Venue.EnterVenue
> 01/30/06 10:48:30 3400 VenueClient     venueclient.py:933 DEBUG EnterVenue; url=https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 10:48:30 3400 NodeService     agnodeservice.py:540 INFO  NodeService.GetCapabilities
> 01/30/06 10:48:30 3400 NodeService     agnodeservice.py:139 INFO  NodeService.GetServices
> 01/30/06 10:48:30 688 ServiceManager     agservicemanager.py:219 INFO  AGServiceManager.GetServices
> 01/30/06 10:48:30 3400 VenueClient     venueclient.py:955 DEBUG calling __EnterVenue
> 01/30/06 10:48:30 3400 VenueClient     venueclient.py:742 DEBUG EnterVenue: Invoke Venue.Enter
> 01/30/06 10:48:30 3400 VenueClient     venueclient.py:963 ERROR EnterVenue: failed
>     self.h.connect()
> 01/30/06 10:48:30 3400 VenueClient     venueclientui.py:2416 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 10:48:30 3400 VenueClient     venueclientui.py:2432 DEBUG warningString:
> 01/30/06 10:48:30 3400 VenueClientController     venueclientcontroller.py:387 DEBUG VenueClientController after Venue.EnterVenue
> 01/30/06 10:55:30 3400 VenueClient     venueclientui.py:2036 INFO  --------- END VenueClient
> 01/30/06 10:55:30 3400 ServiceManager     agservicemanager.py:69 INFO  AGServiceManager.Shutdown
> 01/30/06 10:55:30 3400 ServiceManager     agservicemanager.py:70 INFO  Remove services
> 01/30/06 10:55:30 3400 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 10:55:30 3400 ServiceManager     agservicemanager.py:72 INFO  Stop network interface
> 01/30/06 14:37:30 3700 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 14:37:30 3700 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 14:37:30 3700 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient.py', '--personalNode=1']
> 01/30/06 14:37:30 3700 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 14:37:30 3700 Toolkit     toolkit.py:156 INFO  Logfile Name: VenueClient.log
> 01/30/06 14:37:30 3700 Toolkit     venueclient.py:80 INFO  wx version is: 2.5.1.5
> 01/30/06 14:37:31 3700 VenueClient     venueclient.py:329 DEBUG __StartWebService: venueclient: http://sharker.isti.cnr.it:11000/VenueClient
> 01/30/06 14:37:31 3700 VenueClient     venueclient.py:340 DEBUG __StartWebService: service manager: http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 14:37:31 3700 VenueClient     venueclient.py:354 DEBUG __StartWebService: node service: http://sharker.isti.cnr.it:11000/NodeService
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:517 INFO  NodeService.GetConfigurations
> 01/30/06 14:37:31 3700 VenueClient     venueclient.py:156 DEBUG Loading default node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x02A27918>
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:257 INFO  NodeService.LoadConfiguration
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:276 INFO  Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:284 DEBUG section: node
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   servicemanagers : servicemanager0
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:284 DEBUG section: service1
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   packageName : VideoConsumerService.zip
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:284 DEBUG section: service0
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   packageName : AudioService.zip
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   serviceConfig : serviceconfig0
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:284 DEBUG section: servicemanager0
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   services : service0 service1
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   builtin : 1
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   name :
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   url :
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:284 DEBUG section: serviceconfig0
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   Force AC97 : False
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   Silence Suppression : Off
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   Output Gain : 50
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   Talk : Off
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:286 DEBUG   Input Gain : 50
> 01/30/06 14:37:31 3700 NodeService     agnodeservice.py:361 DEBUG using builtin service manager at http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 14:37:32 2980 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 14:37:32 1172 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 14:37:32 1172 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 14:37:32 1172 ServiceManager     agservicemanager.py:371 DEBUG Executing service AudioService
> 01/30/06 14:37:32 1172 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 65049, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '9230525808a002c0d5676ef12021c65e']
> 01/30/06 14:37:32 1172 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 65049 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 9230525808a002c0d5676ef12021c65e
> 01/30/06 14:37:32 1172 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1056>, <PyHANDLE:1084>, 968, 3432)
> 01/30/06 14:37:41 1172 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:65049/Services/AudioService.9230525803c802c0d8beb2fe1f104835 9230525808a002c0d5676ef12021c65e
> 01/30/06 14:37:42 2304 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 14:37:42 2304 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 14:37:42 2304 ServiceManager     agservicemanager.py:371 DEBUG Executing service VideoConsumerService
> 01/30/06 14:37:42 2304 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', 54270, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '9230525808a002c0d93eea7cdb530405']
> 01/30/06 14:37:42 2304 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py" --port 54270 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 9230525808a002c0d93eea7cdb530405
> 01/30/06 14:37:42 2304 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1100>, <PyHANDLE:1032>, 3608, 2068)
> 01/30/06 14:37:50 2304 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:54270/Services/VideoConsumerService.923052580e1802c0dc50107a8f304c05 9230525808a002c0d93eea7cdb530405
> 01/30/06 14:37:50 2304 Hosting     servicecontainer.py:16 ERROR Processing Failure
> ZSI:FaultException
> Processing Failure
> 01/30/06 14:37:50 3700 NodeService     agnodeservice.py:396 ERROR Exception adding service VideoConsumerService.zip
>     prefs.GetProfile())
> ZSI:FaultException
> Processing Failure
> 01/30/06 14:37:50 3700 VenueClient     venueclient.py:162 ERROR Error loading default configuration
> 01/30/06 14:37:53 3700 VenueClientController     venueclientcontroller.py:1265 DEBUG There is no personal venues file to load.
> 01/30/06 14:42:32 3700 NodeService     agnodeservice.py:517 INFO  NodeService.GetConfigurations
> 01/30/06 14:42:33 3700 VenueClient     preferencesui.py:459 DEBUG VenueClientUI.py: Set editable in successfully dialog
> 01/30/06 14:42:33 3700 VenueClient     preferencesui.py:525 DEBUG ProfileDialog.SetProfile: Set profile information successfully in dialog
> 01/30/06 14:43:18 3700 VenueClient     venueclientui.py:2036 INFO  --------- END VenueClient
> 01/30/06 14:43:18 3700 ServiceManager     agservicemanager.py:69 INFO  AGServiceManager.Shutdown
> 01/30/06 14:43:18 3700 ServiceManager     agservicemanager.py:70 INFO  Remove services
> 01/30/06 14:43:18 3700 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 14:43:18 3700 ServiceManager     agservicemanager.py:161 INFO  AGServiceManager.RemoveService
> 01/30/06 14:43:20 3700 ProcessManager     processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:1056> cleanly (258)
> 01/30/06 14:43:20 3700 ServiceManager     agservicemanager.py:72 INFO  Stop network interface
> 01/30/06 18:39:32 476 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 18:39:32 476 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 18:39:32 476 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient.py', '--personalNode=1']
> 01/30/06 18:39:32 476 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 18:39:32 476 Toolkit     toolkit.py:156 INFO  Logfile Name: VenueClient.log
> 01/30/06 18:39:32 476 Toolkit     venueclient.py:80 INFO  wx version is: 2.6.2.1
> 01/30/06 18:39:32 476 VenueClient     venueclient.py:329 DEBUG __StartWebService: venueclient: http://sharker.isti.cnr.it:11000/VenueClient
> 01/30/06 18:39:32 476 VenueClient     venueclient.py:340 DEBUG __StartWebService: service manager: http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 18:39:33 476 VenueClient     venueclient.py:354 DEBUG __StartWebService: node service: http://sharker.isti.cnr.it:11000/NodeService
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:517 INFO  NodeService.GetConfigurations
> 01/30/06 18:39:33 476 VenueClient     venueclient.py:156 DEBUG Loading default node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x02C3B2B0>
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:257 INFO  NodeService.LoadConfiguration
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:276 INFO  Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:284 DEBUG section: node
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   servicemanagers : servicemanager0
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:284 DEBUG section: service1
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   packageName : VideoConsumerService.zip
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:284 DEBUG section: service0
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   packageName : AudioService.zip
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   serviceConfig : serviceconfig0
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:284 DEBUG section: servicemanager0
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   services : service0 service1
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   builtin : 1
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   name :
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   url :
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:284 DEBUG section: serviceconfig0
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   Force AC97 : False
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   Silence Suppression : Off
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   Output Gain : 50
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   Talk : Off
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:286 DEBUG   Input Gain : 50
> 01/30/06 18:39:33 476 NodeService     agnodeservice.py:361 DEBUG using builtin service manager at http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 18:39:34 1896 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 18:39:35 3492 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 18:39:35 3492 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 18:39:35 3492 ServiceManager     agservicemanager.py:371 DEBUG Executing service AudioService
> 01/30/06 18:39:35 3492 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 59910, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580e0802d6fe6ef837f081840d']
> 01/30/06 18:39:35 3492 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 59910 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 923052580e0802d6fe6ef837f081840d
> 01/30/06 18:39:35 3492 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1132>, <PyHANDLE:1136>, 3412, 3304)
> 01/30/06 18:39:44 3492 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:59910/Services/AudioService.923052580d5402d701c3f366df7be34a 923052580e0802d6fe6ef837f081840d
> 01/30/06 18:39:44 776 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 18:39:44 776 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 18:39:44 776 ServiceManager     agservicemanager.py:371 DEBUG Executing service VideoConsumerService
> 01/30/06 18:39:44 776 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', 64486, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580e0802d7020ff78af2cd2634']
> 01/30/06 18:39:44 776 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py" --port 64486 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 923052580e0802d7020ff78af2cd2634
> 01/30/06 18:39:44 776 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1088>, <PyHANDLE:1056>, 4000, 2068)
> 01/30/06 18:39:53 776 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:64486/Services/VideoConsumerService.923052580fa002d705383f942f08cce8 923052580e0802d7020ff78af2cd2634
> 01/30/06 18:39:53 776 Hosting     servicecontainer.py:16 ERROR Processing Failure
> ZSI:FaultException
> Processing Failure
> 01/30/06 18:39:53 476 NodeService     agnodeservice.py:396 ERROR Exception adding service VideoConsumerService.zip
>     prefs.GetProfile())
> ZSI:FaultException
> Processing Failure
> 01/30/06 18:39:53 476 VenueClient     venueclient.py:162 ERROR Error loading default configuration
> 01/30/06 18:39:56 476 VenueClientController     venueclientcontroller.py:1265 DEBUG There is no personal venues file to load.
> 01/30/06 18:40:47 476 VenueClientController     venueclientcontroller.py:385 DEBUG VenueClientController calling Venue.EnterVenue
> 01/30/06 18:40:47 476 VenueClient     venueclient.py:933 DEBUG EnterVenue; url=https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 18:40:47 476 NodeService     agnodeservice.py:540 INFO  NodeService.GetCapabilities
> 01/30/06 18:40:47 476 NodeService     agnodeservice.py:139 INFO  NodeService.GetServices
> 01/30/06 18:40:47 3164 ServiceManager     agservicemanager.py:219 INFO  AGServiceManager.GetServices
> 01/30/06 18:40:48 476 VenueClient     venueclient.py:955 DEBUG calling __EnterVenue
> 01/30/06 18:40:48 476 VenueClient     venueclient.py:742 DEBUG EnterVenue: Invoke Venue.Enter
> 01/30/06 18:40:48 476 VenueClient     venueclient.py:963 ERROR EnterVenue: failed
>     self.h.connect()
> 01/30/06 18:40:48 476 VenueClient     venueclientui.py:2416 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 18:40:48 476 VenueClient     venueclientui.py:2432 DEBUG warningString:
> 01/30/06 18:40:48 476 VenueClientController     venueclientcontroller.py:387 DEBUG VenueClientController after Venue.EnterVenue
> 01/30/06 18:41:24 476 VenueClient     venueclientui.py:1198 DEBUG VenueClientFrame.ManageNodeCB: open node management
> 01/30/06 18:41:24 476 VenueClient     venueclientui.py:1199 DEBUG nodeservice url: <AccessGrid.AGNodeService.AGNodeService instance at 0x02C34F30>
> 01/30/06 18:41:24 476 NodeService     agnodeservice.py:130 INFO  NodeService.GetServiceManagers
> 01/30/06 18:41:24 3852 ServiceManager     agservicemanager.py:219 INFO  AGServiceManager.GetServices
> 01/30/06 18:41:45 3316 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 18:41:46 3316 ServiceManager     agservicemanager.py:130 INFO  Extracting service package to C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoProducerService
> 01/30/06 18:41:46 3316 ServiceManager     agservicemanager.py:371 DEBUG Executing service VideoProducerService
> 01/30/06 18:41:46 3316 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoProducerService\\VideoProducerService.py', '--port', 59533, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580e0802d731b90baecc6ac0d9']
> 01/30/06 18:41:46 3316 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoProducerService\VideoProducerService.py" --port 59533 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 923052580e0802d731b90baecc6ac0d9
> 01/30/06 18:41:46 3316 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:900>, <PyHANDLE:888>, 2936, 3556)
> 01/30/06 18:41:56 3316 ServiceManager     agservicemanager.py:417 INFO  Service failed to register: 923052580e0802d731b90baecc6ac0d9
> 01/30/06 18:41:56 3316 Hosting     servicecontainer.py:16 ERROR Processing Failure
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\AGServiceManager_interface.py:804:soap_AddService
> 01/30/06 18:41:56 476 NodeManagementUIClasses     nodemanagementuiclasses.py:965 ERROR Add Service failed:VideoProducerService
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\NodeManagementUIClasses.py", line 929, in AddService
>     self.app.GetPreferences().GetProfile())
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\AGServiceManager_client.py", line 43, in AddService
>     response = self.binding.Receive(AddServiceResponse.typecode)
> 01/30/06 18:42:06 980 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 18:42:06 980 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 18:42:06 980 ServiceManager     agservicemanager.py:371 DEBUG Executing service VideoConsumerService
> 01/30/06 18:42:06 980 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', 56228, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580e0802d73956d0218c11e7c0']
> 01/30/06 18:42:06 980 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py" --port 56228 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 923052580e0802d73956d0218c11e7c0
> 01/30/06 18:42:06 980 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1136>, <PyHANDLE:884>, 732, 1232)
> 01/30/06 18:42:14 980 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:56228/Services/VideoConsumerService.9230525802dc02d73c364c7723140f80 923052580e0802d73956d0218c11e7c0
> 01/30/06 18:42:14 980 Hosting     servicecontainer.py:16 ERROR Processing Failure
> ZSI:FaultException
> Processing Failure
> 01/30/06 18:42:14 476 NodeManagementUIClasses     nodemanagementuiclasses.py:965 ERROR Add Service failed:VideoConsumerService
> ZSI:FaultException
> Processing Failure
> 01/30/06 18:42:39 476 VenueClientController     venueclientcontroller.py:385 DEBUG VenueClientController calling Venue.EnterVenue
> 01/30/06 18:42:39 476 VenueClient     venueclient.py:933 DEBUG EnterVenue; url=https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 18:42:39 476 NodeService     agnodeservice.py:540 INFO  NodeService.GetCapabilities
> 01/30/06 18:42:39 476 NodeService     agnodeservice.py:139 INFO  NodeService.GetServices
> 01/30/06 18:42:39 3908 ServiceManager     agservicemanager.py:219 INFO  AGServiceManager.GetServices
> 01/30/06 18:42:39 476 VenueClient     venueclient.py:955 DEBUG calling __EnterVenue
> 01/30/06 18:42:39 476 VenueClient     venueclient.py:742 DEBUG EnterVenue: Invoke Venue.Enter
> 01/30/06 18:43:00 476 VenueClient     venueclient.py:963 ERROR EnterVenue: failed
>     self.h.connect()
>   File "C:\Python23\lib\httplib.py", line 960, in connect
>     sock.connect((self.host, self.port))
>   File "<string>", line 1, in connect
> error: (10060, 'Operation timed out')
> 01/30/06 18:43:00 476 VenueClient     venueclientui.py:2416 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 18:43:00 476 VenueClient     venueclientui.py:2432 DEBUG warningString:
> 01/30/06 18:43:00 476 VenueClientController     venueclientcontroller.py:387 DEBUG VenueClientController after Venue.EnterVenue
> 01/30/06 18:44:01 476 VenueClient     venueclientui.py:2036 INFO  --------- END VenueClient
> 01/30/06 18:44:01 476 ServiceManager     agservicemanager.py:69 INFO  AGServiceManager.Shutdown
> 01/30/06 18:44:01 476 ServiceManager     agservicemanager.py:70 INFO  Remove services
> 01/30/06 18:44:01 476 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 18:44:01 476 ServiceManager     agservicemanager.py:161 INFO  AGServiceManager.RemoveService
> 01/30/06 18:44:02 476 ProcessManager     processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:1132> cleanly (258)
> 01/30/06 18:44:02 476 ServiceManager     agservicemanager.py:72 INFO  Stop network interface
> 01/30/06 19:21:11 2208 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 19:21:11 2208 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 19:21:11 2208 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient.py', '--personalNode=1']
> 01/30/06 19:21:11 2208 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 19:21:11 2208 Toolkit     toolkit.py:156 INFO  Logfile Name: VenueClient.log
> 01/30/06 19:21:11 2208 Toolkit     venueclient.py:80 INFO  wx version is: 2.6.2.1
> 01/30/06 19:21:11 2208 VenueClient     venueclient.py:329 DEBUG __StartWebService: venueclient: http://sharker.isti.cnr.it:11000/VenueClient
> 01/30/06 19:21:11 2208 VenueClient     venueclient.py:340 DEBUG __StartWebService: service manager: http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 19:21:11 2208 VenueClient     venueclient.py:354 DEBUG __StartWebService: node service: http://sharker.isti.cnr.it:11000/NodeService
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:517 INFO  NodeService.GetConfigurations
> 01/30/06 19:21:11 2208 VenueClient     venueclient.py:156 DEBUG Loading default node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x029A97B0>
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:257 INFO  NodeService.LoadConfiguration
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:276 INFO  Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:284 DEBUG section: node
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   servicemanagers : servicemanager0
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:284 DEBUG section: service1
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   packageName : VideoConsumerService.zip
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:284 DEBUG section: service0
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   packageName : AudioService.zip
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   serviceConfig : serviceconfig0
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:284 DEBUG section: servicemanager0
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   services : service0 service1
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   builtin : 1
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   name :
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   url :
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:284 DEBUG section: serviceconfig0
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   Force AC97 : False
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   Silence Suppression : Off
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   Output Gain : 50
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   Talk : Off
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:286 DEBUG   Input Gain : 50
> 01/30/06 19:21:11 2208 NodeService     agnodeservice.py:361 DEBUG using builtin service manager at http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 19:21:12 3244 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 19:21:12 1428 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 19:21:12 1428 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 19:21:12 1428 ServiceManager     agservicemanager.py:371 DEBUG Executing service AudioService
> 01/30/06 19:21:12 1428 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 55525, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '92305258067802dacdb597224e1bd37d']
> 01/30/06 19:21:12 1428 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 55525 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 92305258067802dacdb597224e1bd37d
> 01/30/06 19:21:12 1428 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:944>, <PyHANDLE:932>, 2968, 2088)
> 01/30/06 19:21:19 1428 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:55525/Services/AudioService.923052580b9802dad04ac8ec218d7ce7 92305258067802dacdb597224e1bd37d
> 01/30/06 19:21:19 2400 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 19:21:19 2400 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 19:21:19 2400 ServiceManager     agservicemanager.py:371 DEBUG Executing service VideoConsumerService
> 01/30/06 19:21:19 2400 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', 50172, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '92305258067802dad0813283ec7df66b']
> 01/30/06 19:21:19 2400 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py" --port 50172 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 92305258067802dad0813283ec7df66b
> 01/30/06 19:21:19 2400 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1092>, <PyHANDLE:1052>, 3924, 2996)
> 01/30/06 19:21:26 2400 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:50172/Services/VideoConsumerService.923052580f5402dad31711606ae38340 92305258067802dad0813283ec7df66b
> 01/30/06 19:21:26 2400 Hosting     servicecontainer.py:16 ERROR Processing Failure
> ZSI:FaultException
> Processing Failure
> [trace: C:\Python23\lib\site-packages\ZSI\ServiceContainer.py:107:_Dispatch
> C:\Python23\lib\site-packages\ZSI\client.py:415:Receive]
> 01/30/06 19:21:26 2208 NodeService     agnodeservice.py:396 ERROR Exception adding service VideoConsumerService.zip
>     prefs.GetProfile())
>   File "C:\Python23\lib\site-packages\ZSI\client.py", line 415, in Receive
> ZSI:FaultException
> Processing Failure
> 01/30/06 19:21:26 2208 VenueClient     venueclient.py:162 ERROR Error loading default configuration
> 01/30/06 19:21:28 2208 VenueClientController     venueclientcontroller.py:1265 DEBUG There is no personal venues file to load.
> 01/30/06 19:21:48 2208 VenueClientController     venueclientcontroller.py:385 DEBUG VenueClientController calling Venue.EnterVenue
> 01/30/06 19:21:48 2208 VenueClient     venueclient.py:933 DEBUG EnterVenue; url=https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 19:21:48 2208 NodeService     agnodeservice.py:540 INFO  NodeService.GetCapabilities
> 01/30/06 19:21:48 2208 NodeService     agnodeservice.py:139 INFO  NodeService.GetServices
> 01/30/06 19:21:48 3524 ServiceManager     agservicemanager.py:219 INFO  AGServiceManager.GetServices
> 01/30/06 19:21:48 2208 VenueClient     venueclient.py:955 DEBUG calling __EnterVenue
> 01/30/06 19:21:48 2208 VenueClient     venueclient.py:742 DEBUG EnterVenue: Invoke Venue.Enter
> 01/30/06 19:21:52 2208 VenueClient     venueclient.py:744 DEBUG after Venue.Enter
> 01/30/06 19:21:52 2208 VenueClient     venueclient.py:746 DEBUG EnterVenue: Invoke Venue.getstate
> 01/30/06 19:21:53 2208 VenueClient     venueclient.py:748 DEBUG EnterVenue: done Venue.getstate
> 01/30/06 19:21:55 2208 VenueClient     venueclient.py:770 DEBUG Setting isInVenue flag.
> 01/30/06 19:21:55 2208 VenueClient     venueclient.py:957 DEBUG after __EnterVenue
> 01/30/06 19:21:55 2208 VenueClient     venueclientui.py:2416 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 19:21:55 2208 VenueClient     venueclientui.py:2526 DEBUG Entered venue
> 01/30/06 19:21:55 2208 VenueClientController     venueclientcontroller.py:387 DEBUG VenueClientController after Venue.EnterVenue
> 01/30/06 19:21:55 2208 VenueClient     venueclientui.py:3109 DEBUG ContentListPanel.AddParticipant:: AddParticipant Rosario Lombardo (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
> 01/30/06 19:21:55 2288 JabberClient     jabberclient.py:31 INFO  Connecting to Jabber Server 'jabber.mcs.anl.gov' ...
> 01/30/06 19:21:56 2288 JabberClient     jabberclient.py:146 INFO  Registering the user '8cdd0b2c382802dadf0ede5944286481 at jabber.mcs.anl.gov/default' in jabber server ...
> 01/30/06 19:21:57 2288 JabberClient     jabberclient.py:155 INFO  Attempting to log in as 8cdd0b2c382802dadf0ede5944286481 at jabber.mcs.anl.gov/default ...
> 01/30/06 19:21:58 2288 JabberClient     jabberclient.py:70 DEBUG Sending the presence to 'AG3-Beta-Lobby(vv3.mcs.anl.gov)@conference.mcs.anl.gov/Rosario Lombardo' of type 'available'...
> 01/30/06 19:21:58 2288 VenueClient     venueclient.py:881 INFO  VenueClient.StartBeacon: Address 224.2.160.68/56818
> 01/30/06 19:21:58 2288 RTPBeacon     rtpbeacon.py:278 DEBUG Called Start.
> 01/30/06 19:21:58 2288 VenueClient     venueclient.py:1089 DEBUG UpdateNodeService: Method UpdateNodeService called
> 01/30/06 19:22:32 2288 VenueClient     venueclient.py:1102 DEBUG profile has not changed, not updating services
> 01/30/06 19:22:32 2288 VenueClient     venueclient.py:1113 DEBUG Setting node service streams
> 01/30/06 19:22:32 2288 NodeService     agnodeservice.py:210 INFO  NodeService.SetStreams
> 01/30/06 19:22:32 2288 NodeService     agnodeservice.py:139 INFO  NodeService.GetServices
> 01/30/06 19:22:32 2928 JabberClient     jabberclient.py:117 DEBUG jabber.mcs.anl.gov: Welcome to the Access Grid Jabber server @ jabber.mcs.anl.gov -- we hope you enjoy this service! For information about how to use Jabber, visit the Jabber User's Guide at http://jabbermanual.jabberstudio.org/
> 01/30/06 19:22:32 2928 JabberClient     jabberclient.py:129 DEBUG ag3-beta-lobby(vv3.mcs.anl.gov)@conference.mcs.anl.gov/Rosario Lombardo is available (None / None)
> 01/30/06 19:22:32 3124 ServiceManager     agservicemanager.py:219 INFO  AGServiceManager.GetServices
> 01/30/06 19:22:32 2928 JabberClient     jabberclient.py:117 DEBUG ag3-beta-lobby(vv3.mcs.anl.gov)@conference.mcs.anl.gov: ag3-beta-lobby(vv3.mcs.anl.gov)
> 01/30/06 19:22:32 2288 NodeService     agnodeservice.py:577 INFO  NodeService.__SendStreamsToService
> 01/30/06 19:23:06 2928 JabberClient     jabberclient.py:117 DEBUG ag3-beta-lobby(vv3.mcs.anl.gov)@conference.mcs.anl.gov: This room supports the MUC protocol.
> 01/30/06 19:23:06 2928 JabberClient     jabberclient.py:129 DEBUG ag3-beta-lobby(vv3.mcs.anl.gov)@conference.mcs.anl.gov/Tom is available (None / None)
> 01/30/06 19:23:06 2288 NodeService     agnodeservice.py:581 DEBUG service capabilities: [consumer, audio, 923052580b9802dacfed01939b1d5f7e, L16, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, L16, 8000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, L8, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, L8, 8000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, PCMU, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, PCMU, 8000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, GSM, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, GSM, 8000, 1, producer, audio, 923052580b9802dacfed01939b1d5f7e, L16, 16000, 1]
> 01/30/06 19:23:06 2288 NodeService     agnodeservice.py:595 INFO  Sending stream (type=[consumer, audio, 923052580b9802dacfed01939b1d5f7e, L16, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, L16, 8000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, L8, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, L8, 8000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, PCMU, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, PCMU, 8000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, GSM, 16000, 1, consumer, audio, 923052580b9802dacfed01939b1d5f7e, GSM, 8000, 1, producer, audio, 923052580b9802dacfed01939b1d5f7e, L16, 16000, 1]) to service: http://sharker.isti.cnr.it:55525/Services/AudioService.923052580b9802dad04ac8ec218d7ce7
> 01/30/06 19:23:06 2928 JabberClient     jabberclient.py:129 DEBUG ag3-beta-lobby(vv3.mcs.anl.gov)@conference.mcs.anl.gov/turam is available (None / None)
> 01/30/06 19:23:40 2928 JabberClient     jabberclient.py:129 DEBUG ag3-beta-lobby(vv3.mcs.anl.gov)@conference.mcs.anl.gov/Tom Uram is available (None / None)
> 01/30/06 19:23:40 2288 VenueClient     venueclient.py:845 DEBUG Updating client profile cache.
> 01/30/06 19:23:40 2288 VenueClient     venueclient.py:1181 INFO  UpdateProfileCache: InvalidProfile when storing a venue user's profile in the cache.
> 01/30/06 19:24:13 1456 VenueClient     venueclient.py:415 ERROR Error sending heartbeat, reconnecting.
> Traceback (most recent call last):
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\VenueClient.py", line 406, in Heartbeat
>     self.nextTimeout = self.__venueProxy.UpdateLifetime(
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\Venue_client.py", line 294, in UpdateLifetime
>     self.binding.Send(None, None, request, soapaction="urn:#UpdateLifetime", **kw)
>   File "C:\Python23\lib\site-packages\ZSI\client.py", line 251, in Send
>     self.h.connect()
>   File "C:\Python23\Lib\httplib.py", line 987, in connect
> 01/30/06 19:28:21 2512 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 19:28:21 2512 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 19:28:21 2512 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient.py', '--personalNode=1']
> 01/30/06 19:28:21 2512 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 19:28:21 2512 Toolkit     toolkit.py:156 INFO  Logfile Name: VenueClient.log
> 01/30/06 19:28:21 2512 Toolkit     venueclient.py:80 INFO  wx version is: 2.6.2.1
> 01/30/06 19:28:21 2512 VenueClient     venueclient.py:329 DEBUG __StartWebService: venueclient: http://sharker.isti.cnr.it:11000/VenueClient
> 01/30/06 19:28:21 2512 VenueClient     venueclient.py:340 DEBUG __StartWebService: service manager: http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 19:28:21 2512 VenueClient     venueclient.py:354 DEBUG __StartWebService: node service: http://sharker.isti.cnr.it:11000/NodeService
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:517 INFO  NodeService.GetConfigurations
> 01/30/06 19:28:21 2512 VenueClient     venueclient.py:156 DEBUG Loading default node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x02CD5A08>
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:257 INFO  NodeService.LoadConfiguration
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:276 INFO  Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:284 DEBUG section: node
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   servicemanagers : servicemanager0
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:284 DEBUG section: service1
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   packageName : VideoConsumerService.zip
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:284 DEBUG section: service0
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   packageName : AudioService.zip
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   serviceConfig : serviceconfig0
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:284 DEBUG section: servicemanager0
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   services : service0 service1
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   builtin : 1
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   name :
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   url :
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:284 DEBUG section: serviceconfig0
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   Force AC97 : False
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   Silence Suppression : Off
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   Output Gain : 50
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   Talk : Off
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:286 DEBUG   Input Gain : 50
> 01/30/06 19:28:21 2512 NodeService     agnodeservice.py:361 DEBUG using builtin service manager at http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 19:28:21 3044 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 19:28:22 4072 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 19:28:22 4072 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 19:28:22 4072 ServiceManager     agservicemanager.py:371 DEBUG Executing service AudioService
> 01/30/06 19:28:22 4072 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 63401, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580eb802db759f41cd5681921f']
> 01/30/06 19:28:22 4072 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 63401 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 923052580eb802db759f41cd5681921f
> 01/30/06 19:28:22 4072 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:944>, <PyHANDLE:932>, 1708, 4068)
> 01/30/06 19:28:27 4072 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:63401/Services/AudioService.9230525806ac02db77c9b410731af5fd 923052580eb802db759f41cd5681921f
> 01/30/06 19:28:28 2396 ServiceManager     agservicemanager.py:101 INFO  AGServiceManager.AddService
> 01/30/06 19:28:28 2396 ServiceManager     agservicemanager.py:336 INFO  Installed service version: 3.0, package version: 3.0
> 01/30/06 19:28:28 2396 ServiceManager     agservicemanager.py:371 DEBUG Executing service VideoConsumerService
> 01/30/06 19:28:28 2396 ServiceManager     agservicemanager.py:403 INFO  Running Service; options: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', 64166, '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580eb802db77fd9714d60f0b0e']
> 01/30/06 19:28:28 2396 ProcessManager     processmanager.py:59 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py" --port 64166 --serviceManagerUri http://sharker.isti.cnr.it:11000/ServiceManager --token 923052580eb802db77fd9714d60f0b0e
> 01/30/06 19:28:28 2396 ProcessManager     processmanager.py:72 DEBUG Create process returns: (<PyHANDLE:1040>, <PyHANDLE:1084>, 2196, 2276)
> 01/30/06 19:28:33 2396 ServiceManager     agservicemanager.py:415 INFO  Service registered: http://sharker.isti.cnr.it:64166/Services/VideoConsumerService.92305258089402db7a05d88053eb7713 923052580eb802db77fd9714d60f0b0e
> 01/30/06 19:28:33 2396 Hosting     servicecontainer.py:16 ERROR Processing Failure
> ZSI:FaultException
> Processing Failure
> 01/30/06 19:28:33 2512 NodeService     agnodeservice.py:396 ERROR Exception adding service VideoConsumerService.zip
>     prefs.GetProfile())
> ZSI:FaultException
> Processing Failure
> 01/30/06 19:28:33 2512 VenueClient     venueclient.py:162 ERROR Error loading default configuration
> 01/30/06 19:28:54 2512 VenueClient     venueclient.py:223 ERROR __LoadBridges: Can not connect to bridge registry http://www.accessgrid.org/registry/peers.txt
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\VenueClient.py", line 218, in __LoadBridges
>     bridgeList = self.registryClient.LookupBridge(10)
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\Registry\RegistryClient.py", line 74, in LookupBridge
>     self._connectToRegistry()
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\Registry\RegistryClient.py", line 24, in _connectToRegistry
>     self.registryPeers = self._readPeerList(url=self.url)
>   File "c:\python23\lib\site-packages\accessgrid3\AccessGrid\Registry\RegistryClient.py", line 119, in _readPeerList
>     f = opener.open(url)
>   File "C:\Python23\Lib\urllib.py", line 181, in open
>     return getattr(self, name)(url)
>   File "C:\Python23\Lib\urllib.py", line 297, in open_http
>     h.endheaders()
>   File "C:\Python23\Lib\httplib.py", line 715, in endheaders
>     self._send_output()
>   File "C:\Python23\Lib\httplib.py", line 600, in _send_output
>     self.send(msg)
>   File "C:\Python23\Lib\httplib.py", line 567, in send
>     self.connect()
>   File "C:\Python23\Lib\httplib.py", line 551, in connect
> IOError: [Errno socket error] (10060, 'Operation timed out')
> 01/30/06 19:28:54 2512 VenueClientController     venueclientcontroller.py:1265 DEBUG There is no personal venues file to load.
> 01/30/06 19:29:39 2512 VenueClientController     venueclientcontroller.py:385 DEBUG VenueClientController calling Venue.EnterVenue
> 01/30/06 19:29:39 2512 VenueClient     venueclient.py:933 DEBUG EnterVenue; url=https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 19:29:39 2512 NodeService     agnodeservice.py:540 INFO  NodeService.GetCapabilities
> 01/30/06 19:29:39 2512 NodeService     agnodeservice.py:139 INFO  NodeService.GetServices
> 01/30/06 19:29:39 1380 ServiceManager     agservicemanager.py:219 INFO  AGServiceManager.GetServices
> 01/30/06 19:29:40 2512 VenueClient     venueclient.py:955 DEBUG calling __EnterVenue
> 01/30/06 19:29:40 2512 VenueClient     venueclient.py:742 DEBUG EnterVenue: Invoke Venue.Enter
> 01/30/06 19:30:01 2512 VenueClient     venueclient.py:963 ERROR EnterVenue: failed
>     self.h.connect()
> 01/30/06 19:30:01 2512 VenueClient     venueclientui.py:2416 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv3.mcs.anl.gov:8000/Venues/default
> 01/30/06 19:30:01 2512 VenueClient     venueclientui.py:2432 DEBUG warningString:
> 01/30/06 19:30:01 2512 VenueClientController     venueclientcontroller.py:387 DEBUG VenueClientController after Venue.EnterVenue
> 01/30/06 19:30:04 2512 VenueClient     venueclientui.py:2036 INFO  --------- END VenueClient
> 01/30/06 19:30:04 2512 ServiceManager     agservicemanager.py:69 INFO  AGServiceManager.Shutdown
> 01/30/06 19:30:04 2512 ServiceManager     agservicemanager.py:70 INFO  Remove services
> 01/30/06 19:30:04 2512 ServiceManager     agservicemanager.py:209 INFO  AGServiceManager.RemoveServices
> 01/30/06 19:30:04 2512 ServiceManager     agservicemanager.py:161 INFO  AGServiceManager.RemoveService
> 01/30/06 19:30:05 2512 ProcessManager     processmanager.py:133 WARNING Couldn't terminate process <PyHANDLE:944> cleanly (258)
> 01/30/06 19:30:05 2512 ServiceManager     agservicemanager.py:72 INFO  Stop network interface
> 01/29/06 17:00:22 2144 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/29/06 17:00:22 2144 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/29/06 17:00:22 2144 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', '55419', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580908024a113b17db4af3369c']
> 01/29/06 17:00:22 2144 Toolkit     config.py:562 INFO  Found 2 processors; setting affinity
> 01/29/06 17:00:23 2144 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/29/06 17:00:23 2144 Toolkit     toolkit.py:156 INFO  Logfile Name: VideoConsumerService.log
> 01/29/06 17:00:23 2144 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/29/06 17:00:23 2144 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/29/06 17:00:23 2144 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:55419/Services/VideoConsumerService.923052580950024a1363bf4ee1bb6c89
> 01/29/06 17:00:23 2144 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/29/06 17:00:23 1392 Toolkit     videoconsumerservice.py:181 INFO  SetIdentity: <Insert Name Here> <Insert Email Address Here>
> 01/29/06 17:00:23 1392 Hosting     servicecontainer.py:16 ERROR Processing Failure
> exceptions:UnboundLocalError
> local variable 'rtpDefaultsFile' referenced before assignment
> [trace: C:\Python23\Lib\site-packages\ZSI\ServiceContainer.py:107:_Dispatch
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\interfaces\AGService_interface.py:1187:soap_SetPackageFile
> c:\python23\lib\site-packages\accessgrid3\AccessGrid\AGService.py:277:SetPackageFile
> C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py:183:SetIdentity
> C:\Documents and Settings\Ross\Application Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py:71:__SetRTPDefaults]
> 01/30/06 10:46:42 2564 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 10:46:42 2564 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 10:46:42 2564 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', '51864', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '92305258063802abb0352cb7dc5906ab']
> 01/30/06 10:46:42 2564 Toolkit     config.py:562 INFO  Found 2 processors; setting affinity
> 01/30/06 10:46:44 2564 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 10:46:44 2564 Toolkit     toolkit.py:156 INFO  Logfile Name: VideoConsumerService.log
> 01/30/06 10:46:44 2564 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 10:46:44 2564 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 10:46:44 2564 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:51864/Services/VideoConsumerService.923052580a0002abb3e917a0d47bebff
> 01/30/06 10:46:44 2564 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 14:37:49 2068 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 14:37:49 2068 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 14:37:49 2068 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', '54270', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '9230525808a002c0d93eea7cdb530405']
> 01/30/06 14:37:49 2068 Toolkit     config.py:562 INFO  Found 2 processors; setting affinity
> 01/30/06 14:37:50 2068 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 14:37:50 2068 Toolkit     toolkit.py:156 INFO  Logfile Name: VideoConsumerService.log
> 01/30/06 14:37:50 2068 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 14:37:50 2068 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 14:37:50 2068 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:54270/Services/VideoConsumerService.923052580e1802c0dc50107a8f304c05
> 01/30/06 14:37:50 2068 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 14:37:50 1744 Toolkit     videoconsumerservice.py:181 INFO  SetIdentity: Rosario Lombardo rosario.lombardo at isti.cnr.it
> 01/30/06 14:37:50 1744 Hosting     servicecontainer.py:16 ERROR Processing Failure
> 01/30/06 18:39:51 2068 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 18:39:51 2068 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 18:39:51 2068 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', '64486', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580e0802d7020ff78af2cd2634']
> 01/30/06 18:39:51 2068 Toolkit     config.py:562 INFO  Found 2 processors; setting affinity
> 01/30/06 18:39:52 2068 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 18:39:52 2068 Toolkit     toolkit.py:156 INFO  Logfile Name: VideoConsumerService.log
> 01/30/06 18:39:52 2068 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 18:39:52 2068 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 18:39:52 2068 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:64486/Services/VideoConsumerService.923052580fa002d705383f942f08cce8
> 01/30/06 18:39:52 2068 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 18:39:53 3020 Toolkit     videoconsumerservice.py:181 INFO  SetIdentity: Rosario Lombardo rosario.lombardo at isti.cnr.it
> 01/30/06 18:39:53 3020 Hosting     servicecontainer.py:16 ERROR Processing Failure
> 01/30/06 18:42:12 1232 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 18:42:12 1232 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 18:42:12 1232 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', '56228', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580e0802d73956d0218c11e7c0']
> 01/30/06 18:42:12 1232 Toolkit     config.py:562 INFO  Found 2 processors; setting affinity
> 01/30/06 18:42:13 1232 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 18:42:13 1232 Toolkit     toolkit.py:156 INFO  Logfile Name: VideoConsumerService.log
> 01/30/06 18:42:13 1232 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 18:42:13 1232 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 18:42:13 1232 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:56228/Services/VideoConsumerService.9230525802dc02d73c364c7723140f80
> 01/30/06 18:42:13 1232 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 18:42:14 3044 Toolkit     videoconsumerservice.py:181 INFO  SetIdentity: Rosario Lombardo rosario.lombardo at isti.cnr.it
> 01/30/06 18:42:14 3044 Hosting     servicecontainer.py:16 ERROR Processing Failure
> 01/30/06 19:21:25 2996 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 19:21:25 2996 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 19:21:25 2996 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', '50172', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '92305258067802dad0813283ec7df66b']
> 01/30/06 19:21:25 2996 Toolkit     config.py:562 INFO  Found 2 processors; setting affinity
> 01/30/06 19:21:26 2996 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 19:21:26 2996 Toolkit     toolkit.py:156 INFO  Logfile Name: VideoConsumerService.log
> 01/30/06 19:21:26 2996 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 19:21:26 2996 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 19:21:26 2996 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:50172/Services/VideoConsumerService.923052580f5402dad31711606ae38340
> 01/30/06 19:21:26 2996 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 19:21:26 2276 Toolkit     videoconsumerservice.py:181 INFO  SetIdentity: Rosario Lombardo rosario.lombardo at isti.cnr.it
> 01/30/06 19:21:26 2276 Hosting     servicecontainer.py:16 ERROR Processing Failure
> 01/30/06 19:28:32 2276 Toolkit     config.py:559 DEBUG System hostname of sharker.isti.cnr.it is valid
> 01/30/06 19:28:32 2276 Toolkit     toolkit.py:106 DEBUG Initializing AG Toolkit version 3.0
> 01/30/06 19:28:32 2276 Toolkit     toolkit.py:107 INFO  Command and arguments: ['C:\\Documents and Settings\\Ross\\Application Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', '64166', '--serviceManagerUri', 'http://sharker.isti.cnr.it:11000/ServiceManager', '--token', '923052580eb802db77fd9714d60f0b0e']
> 01/30/06 19:28:32 2276 Toolkit     config.py:562 INFO  Found 2 processors; setting affinity
> 01/30/06 19:28:33 2276 VenueClient     preferences.py:174 DEBUG Preferences.LoadPreferences: open file
> 01/30/06 19:28:33 2276 Toolkit     toolkit.py:156 INFO  Logfile Name: VideoConsumerService.log
> 01/30/06 19:28:33 2276 Toolkit     toolkit.py:639 INFO  Service init: have profile None
> 01/30/06 19:28:33 2276 Toolkit     toolkit.py:664 INFO  Service Initialization Complete.
> 01/30/06 19:28:33 2276 Toolkit     agservice.py:363 INFO  Starting Service URI: http://sharker.isti.cnr.it:64166/Services/VideoConsumerService.92305258089402db7a05d88053eb7713
> 01/30/06 19:28:33 2276 Toolkit     agservice.py:373 DEBUG Registering with service manager; url=http://sharker.isti.cnr.it:11000/ServiceManager
> 01/30/06 19:28:33 1348 Toolkit     videoconsumerservice.py:181 INFO  SetIdentity: Rosario Lombardo rosario.lombardo at isti.cnr.it
> 01/30/06 19:28:33 1348 Hosting     servicecontainer.py:16 ERROR Processing Failure
