[AG-TECH] Osprey 300 capture card vic woes
Niall Moran
niall.moran at ichec.ie
Mon Feb 27 14:20:06 CST 2006
Thanks for the reply. The Microsoft WDM Image Capture (Win32) is the
only option present in this configuration menu.
Think I will just format one of the client machines and reinstall
everything the way it was done on the working nodes. This should verify
( or not ) that using the driver installer was what caused the problem.
It just seems weird that it would affect the vic and not any other
capture software.
Thanks again,
Niall.
| Niall Moran
| Systems Administrator
| Irish Centre for High-End Computing
\niall.moran at ichec.ie
On Mon, Feb 27, 2006 at 12:38:12PM -0600, monika.k.rabarison at ccaix.jsums.edu wrote:
> Hey,
> I had a similar issue on Windows. Not sure if this is
> exactly the case for you though. When I select the capture
> card driver as the resource in the VideoService
> Configuration, vic crashes. Selecting "Microsoft WDM Image
> Capture (Win32)" instead, made vic works smoothly.
> -Monika
> > Hi,
> > I am trying to setup an access grid system. We are using a
> > linux machine to host the venue server and windows XP
> > machines for the access grid clients. Each machine is
> > identical and has the same specs.
> > * Pentium 4 3.0Ghz
> > * 1GB ram
> > * 160gb disk
> > * nvidia quatro 1400 dual dvi card
> > * osprey 300 video capture card
> > Software running on each machine is windows xp SP2
> > Access grid toolkit 2.4
> > I setup the first 2 clients and everything worked fine.
> > When setting up the second 2 clients however I ran into
> > some difficulties. The vic capture process crashes with a
> > runtime error.
> > The only difference between the setup procedures was that
> > on the 2 clients that do work the capture card drivers
> > were simply installed using the windows add/remove devices
> > utility. However on the 2 clients that are having the
> > problems the capture card drivers were installed using the
> > setup utility that came on the cd. There was a dialog
> > during the install to set the format of the video ( i.e.
> > NTSC, PAL ... ). PAL was choosen here.
> > So far I uninstalled the driver and reinstalled the way
> > that worked previously. Downloaded the latest osprey
> > drivers from the net and installed them using both
> > methods. None of this has made any difference.
> > On the 2 machines that do not work. All other software
> > that accesses the capture card works perfectly, VLC,
> > windows movie maker and the utilities that came with the
> > capture card.
> > Has anyone come accross anything similar or know of any
> > where to go from here? I would greatly appreciate any
> > help.
> > Cheers,
> > Niall.
> > | Niall Moran
> > [Attachment: niall.moran at ichec.ie.sig]
> Monika Rabarison
> Jackson State University
> Office: (601)979-5933
> SciVis Lab: (601)979-1061
> http://vislab.jsums.edu
> "Computers are incredibly fast, accurate and stupid; humans
> are incredibly slow, inaccurate and brilliant; together they
> are powerful" Albert Einstein
Name: not available
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060227/b29ade1a/attachment.pgp>
