[AG-TECH] Libeay32.dll error installing AG
Fabrizio.Berdondini at prototipo.it
Mon Feb 20 02:45:26 CST 2006
Hello,
I tried to install AccessGrid onto a fellow notebook, running Windows XP
Pro SP2, and I got the following error "The ordinal number 3212 could not
be found in LIBEAY32.DLL". I saw he had a "wrong" versionof that dll under
the folder windows\system32 so I replaced it with the version I found
installed on my notebook (which runs AG correctly) but no luck. I also
tried to see if there was other instances of that dll on his PC: I found
three other different version of it, due to other installed programs using
the openSSL. I tried to rename all instances of libeay32.dll on his PC
about the one under system32, I also checked/removed locations of the
other libeay32.dll from the system path but no luck: the error simply
changed ordinal: 968 instead of 3212. Unfortunately I cannot remove the
programs using the libeay32.dll (versions different from the one used by
AG) because my fellow uses them for working at customer's home (they are
VPN applications). Is there some trick/workaround for installing AG on his
PC without "tampering" those applications?
Thank you for support,
Faber B.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060220/0dc66287/attachment.htm>
