[AG-TECH] AGtk 3 beta1: venue server troubleshooting under Windows XP
    Fabrizio.Berdondini at prototipo.it
    Thu Feb 16 10:42:47 CST 2006
I completely removed a previuous installation of AGtk-2.4 from the machine
(win2k) that hosted the venueserver, then installed AGtk 3 beta1. When I
launched the Venue Server and the Venue Management Tool it showed the same
venues configuration I had under AG 2.4... Where is this information
stored? How can I remove it?
owner-ag-tech at mcs.anl.gov scritti il 16/02/2006 15.45.18
> By the way, it seems that something's started "moving" on my AGtk 3
> server: I removed my certificated user (globus Identity Certificate)
> and installed a "service" certificate. Now I can finally reach my
> VenueServer via the VenueManagementTool. However there's still
> something strange: I went to the "manage security" tag of my default
> lobby venue in order to check the status of allowed and disallowed
> people/actions: in fact the section is empty, there's only a
> "Registered people" entry which contains nothing (no ppl, no
> actions). I tried to add some persons but no luck: I can only add
> roles but cannot fill them and so I cannot configure any
> people/action... maybe this is the reason why I cannot enter the
> venue with my client...
> I'll try to "reset" the server configuration and restart the
> service... stay tuned ;-)
> Thanx again for your attention and support,
> Faber B.
> "Thomas D. Uram" <turam at mcs.anl.gov> scritti il 16/02/2006 15.10.45
> > I'm not sure why it didn't get forwarded, but will check.  Meanwhile,
> > you can put them in web space and point at them with a url.
> > Tom
> > On 2/16/06 7:57 AM, Fabrizio.Berdondini at prototipo.it wrote:
> > > It seems I'm no more able to send messages to the mailing list... or
> > > maybe I cannot send it with an attachment. How can I post my server
logs
> > > with a message on the ml? Is there some restriction?
> > > Thanx for suggestions
> > > Faber B.
> > > owner-ag-tech at mcs.anl.gov scritti il 15/02/2006 16.29.18
> > >  > Helllo Fabrizio:
> > >  > Can you send more of your logfile?  (Send to me personally if
it's
> > > very big.)
> > >  > This error should not be happening, and I suspect it is somehow
> > > related to
> > >  > server initialization that would be reflected earlier in the
logfile.
> > >  > Since you also had trouble with VenueManagement, you could also
include
> > >  > that logfile.
> > >  > Grazie,
> > >  > Tom
> > >  > On 2/15/06 9:15 AM, Fabrizio.Berdondini at prototipo.it wrote:
> > >  > > Hello all,
> > >  > > I'm trying to configure venueserver and client on a WinXP
machine in
> > >  > > order to have a look to the new release of AGtk (for future
> > > migration of
> > >  > > our current server/clients). I installed all the packages
> indicated on
> > >  > > the download link but I'm not able to connect my client to the
local
> > >  > > venueserver: the server rejects the connection with the
following
> > > message:
> > >  > > 02/15/06 16:11:51 3576 Security     authorizationmanager.py:216
DEBUG
> > >  > > Rejecting access from unidentified user as part of Everybody
role
> > >  > > 02/15/06 16:11:51 3576 Hosting     servicecontainer.py:16 ERROR
Not
> > >  > > authorized None
> > >  > > 02/15/06 16:12:01 3572 VenueServer     venue.py:235 DEBUG
Client
> > > Timeout
> > >  > > Check: 1140016326 vs 1140016321
> > >  > > I tried to modify the default venue settings/permissions,
> but I wasn't
> > >  > > able to connect to the venueserver via the VenueManagementTool:
it
> > >  > > simply tells me that it cannot connect to the venueserver
located at
> > >  > > https://localhost:8000/VenueServer (the address is correct and
if I
> > > try
> > >  > > to reference the venueserver with its IP or its full network
name the
> > >  > > VenueManagementTools hangs).
> > >  > > Any suggestion?
> > >  > > Thanx,
> > >  > > Faber B.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060216/79ede905/attachment.htm>
