[AG-TECH] AGtk 3 beta1: venue server troubleshooting under Windows XP
    Fabrizio.Berdondini at prototipo.it
    Thu Feb 16 08:45:18 CST 2006
By the way, it seems that something's started "moving" on my AGtk 3
server: I removed my certificated user (globus Identity Certificate) and
installed a "service" certificate. Now I can finally reach my VenueServer
via the VenueManagementTool. However there's still something strange: I
went to the "manage security" tag of my default lobby venue in order to
check the status of allowed and disallowed people/actions: in fact the
section is empty, there's only a "Registered people" entry which contains
nothing (no ppl, no actions). I tried to add some persons but no luck: I
can only add roles but cannot fill them and so I cannot configure any
people/action... maybe this is the reason why I cannot enter the venue
with my client...
I'll try to "reset" the server configuration and restart the service...
stay tuned ;-)
Thanx again for your attention and support,
Faber B.
"Thomas D. Uram" <turam at mcs.anl.gov> scritti il 16/02/2006 15.10.45
> I'm not sure why it didn't get forwarded, but will check.  Meanwhile,
> you can put them in web space and point at them with a url.
> Tom
> On 2/16/06 7:57 AM, Fabrizio.Berdondini at prototipo.it wrote:
> > It seems I'm no more able to send messages to the mailing list... or
> > maybe I cannot send it with an attachment. How can I post my server
logs
> > with a message on the ml? Is there some restriction?
> > Thanx for suggestions
> > Faber B.
> > owner-ag-tech at mcs.anl.gov scritti il 15/02/2006 16.29.18
> >  > Helllo Fabrizio:
> >  > Can you send more of your logfile?  (Send to me personally if it's
> > very big.)
> >  > This error should not be happening, and I suspect it is somehow
> > related to
> >  > server initialization that would be reflected earlier in the
logfile.
> >  > Since you also had trouble with VenueManagement, you could also
include
> >  > that logfile.
> >  > Grazie,
> >  > Tom
> >  > On 2/15/06 9:15 AM, Fabrizio.Berdondini at prototipo.it wrote:
> >  > > Hello all,
> >  > > I'm trying to configure venueserver and client on a WinXP machine
in
> >  > > order to have a look to the new release of AGtk (for future
> > migration of
> >  > > our current server/clients). I installed all the packages
indicated on
> >  > > the download link but I'm not able to connect my client to the
local
> >  > > venueserver: the server rejects the connection with the following
> > message:
> >  > > 02/15/06 16:11:51 3576 Security     authorizationmanager.py:216
DEBUG
> >  > > Rejecting access from unidentified user as part of Everybody role
> >  > > 02/15/06 16:11:51 3576 Hosting     servicecontainer.py:16 ERROR
Not
> >  > > authorized None
> >  > > 02/15/06 16:12:01 3572 VenueServer     venue.py:235 DEBUG Client
> > Timeout
> >  > > Check: 1140016326 vs 1140016321
> >  > > I tried to modify the default venue settings/permissions, but I
wasn't
> >  > > able to connect to the venueserver via the VenueManagementTool:
it
> >  > > simply tells me that it cannot connect to the venueserver located
at
> >  > > https://localhost:8000/VenueServer (the address is correct and if
I
> > try
> >  > > to reference the venueserver with its IP or its full network name
the
> >  > > VenueManagementTools hangs).
> >  > > Any suggestion?
> >  > > Thanx,
> >  > > Faber B.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060216/e4954758/attachment.htm>
