[AG-TECH] AGtk 3 beta1: venue server troubleshooting under Windows XP
Thomas D. Uram
turam at mcs.anl.gov
Thu Feb 16 08:10:45 CST 2006
I'm not sure why it didn't get forwarded, but will check. Meanwhile,
you can put them in web space and point at them with a url.
Tom
On 2/16/06 7:57 AM, Fabrizio.Berdondini at prototipo.it wrote:
> It seems I'm no more able to send messages to the mailing list... or
> maybe I cannot send it with an attachment. How can I post my server logs
> with a message on the ml? Is there some restriction?
> Thanx for suggestions
> Faber B.
> owner-ag-tech at mcs.anl.gov scritti il 15/02/2006 16.29.18
> > Helllo Fabrizio:
> > Can you send more of your logfile? (Send to me personally if it's
> very big.)
> > This error should not be happening, and I suspect it is somehow
> related to
> > server initialization that would be reflected earlier in the logfile.
> > Since you also had trouble with VenueManagement, you could also include
> > that logfile.
> > Grazie,
> > Tom
> > On 2/15/06 9:15 AM, Fabrizio.Berdondini at prototipo.it wrote:
> > > Hello all,
> > > I'm trying to configure venueserver and client on a WinXP machine in
> > > order to have a look to the new release of AGtk (for future
> migration of
> > > our current server/clients). I installed all the packages indicated on
> > > the download link but I'm not able to connect my client to the local
> > > venueserver: the server rejects the connection with the following
> message:
> > > 02/15/06 16:11:51 3576 Security authorizationmanager.py:216 DEBUG
> > > Rejecting access from unidentified user as part of Everybody role
> > > 02/15/06 16:11:51 3576 Hosting servicecontainer.py:16 ERROR Not
> > > authorized None
> > > 02/15/06 16:12:01 3572 VenueServer venue.py:235 DEBUG Client
> Timeout
> > > Check: 1140016326 vs 1140016321
> > > I tried to modify the default venue settings/permissions, but I wasn't
> > > able to connect to the venueserver via the VenueManagementTool: it
> > > simply tells me that it cannot connect to the venueserver located at
> > > https://localhost:8000/VenueServer (the address is correct and if I
> try
> > > to reference the venueserver with its IP or its full network name the
> > > VenueManagementTools hangs).
> > > Any suggestion?
> > > Thanx,
> > > Faber B.
