[AG-TECH] AGtk 3 beta1: venue server troubleshooting under Windows XP
    Fabrizio.Berdondini at prototipo.it
    Thu Feb 16 07:57:06 CST 2006
It seems I'm no more able to send messages to the mailing list... or maybe
I cannot send it with an attachment. How can I post my server logs with a
message on the ml? Is there some restriction?
Thanx for suggestions
Faber B.
owner-ag-tech at mcs.anl.gov scritti il 15/02/2006 16.29.18
> Helllo Fabrizio:
> Can you send more of your logfile?  (Send to me personally if it's very
big.)
> This error should not be happening, and I suspect it is somehow related
to
> server initialization that would be reflected earlier in the logfile.
> Since you also had trouble with VenueManagement, you could also include
> that logfile.
> Grazie,
> Tom
> On 2/15/06 9:15 AM, Fabrizio.Berdondini at prototipo.it wrote:
> > Hello all,
> > I'm trying to configure venueserver and client on a WinXP machine in
> > order to have a look to the new release of AGtk (for future migration
of
> > our current server/clients). I installed all the packages indicated on
> > the download link but I'm not able to connect my client to the local
> > venueserver: the server rejects the connection with the following
message:
> > 02/15/06 16:11:51 3576 Security     authorizationmanager.py:216 DEBUG
> > Rejecting access from unidentified user as part of Everybody role
> > 02/15/06 16:11:51 3576 Hosting     servicecontainer.py:16 ERROR Not
> > authorized None
> > 02/15/06 16:12:01 3572 VenueServer     venue.py:235 DEBUG Client
Timeout
> > Check: 1140016326 vs 1140016321
> > I tried to modify the default venue settings/permissions, but I wasn't
> > able to connect to the venueserver via the VenueManagementTool: it
> > simply tells me that it cannot connect to the venueserver located at
> > https://localhost:8000/VenueServer (the address is correct and if I
try
> > to reference the venueserver with its IP or its full network name the
> > VenueManagementTools hangs).
> > Any suggestion?
> > Thanx,
> > Faber B.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060216/a3dd2f39/attachment.htm>
