[AG-TECH] AGtk 3 beta1: venue server troubleshooting under Windows XP
Thomas D. Uram
turam at mcs.anl.gov
Wed Feb 15 09:29:18 CST 2006
Helllo Fabrizio:
Can you send more of your logfile? (Send to me personally if it's very big.)
This error should not be happening, and I suspect it is somehow related to
server initialization that would be reflected earlier in the logfile.
Since you also had trouble with VenueManagement, you could also include
that logfile.
Grazie,
Tom
On 2/15/06 9:15 AM, Fabrizio.Berdondini at prototipo.it wrote:
> Hello all,
> I'm trying to configure venueserver and client on a WinXP machine in
> order to have a look to the new release of AGtk (for future migration of
> our current server/clients). I installed all the packages indicated on
> the download link but I'm not able to connect my client to the local
> venueserver: the server rejects the connection with the following message:
> 02/15/06 16:11:51 3576 Security authorizationmanager.py:216 DEBUG
> Rejecting access from unidentified user as part of Everybody role
> 02/15/06 16:11:51 3576 Hosting servicecontainer.py:16 ERROR Not
> authorized None
> 02/15/06 16:12:01 3572 VenueServer venue.py:235 DEBUG Client Timeout
> Check: 1140016326 vs 1140016321
> I tried to modify the default venue settings/permissions, but I wasn't
> able to connect to the venueserver via the VenueManagementTool: it
> simply tells me that it cannot connect to the venueserver located at
> https://localhost:8000/VenueServer (the address is correct and if I try
> to reference the venueserver with its IP or its full network name the
> VenueManagementTools hangs).
> Any suggestion?
> Thanx,
> Faber B.
