[AG-TECH] Bridge Server problmes?
    Thomas D. Uram
    turam at mcs.anl.gov
    Mon Feb  6 09:44:29 CST 2006
After how long did the bridge stop appearing in the venue client?
If you're using an identity certificate to run it, a proxy cert will be
generated at startup and will eventually time out, producing the
behavior you describe.
I'd recommend looking in the BridgeServer.log file for an indication
of this or other problems.  If you don't see anything clearly indicated
in the logfile, you can send it for me to review.
Tom
On 2/6/06 4:50 AM, G.T. Chiang wrote:
> Dear Tom
>   it seems the bridge server is running, however, it is actng weird
> sometimes. i did not stop the bridge server for the weekend, it disapear
> from the bridge list if choosing unicast form the venue clinet. i check
> the the process at bridge server, it is still running. if i restart it,
> it shows again. how this kind situation happen?
> thank you very much!!
>         mike
> On Jan 30 2006, Thomas D. Uram wrote:
>> Hi Mike:
>> If your CA and certs from CA are being used on the venue server you're
>> trying to bridge, you should not have a problem. Can you post the
>> bridge.conf file ?
>> Tom
>> On 1/30/06 7:52 AM, G.T. Chiang wrote:
>>> Dear All
>>>   we are trying to set our bridge server. we are running venues
>>> server at same mahcines for testing. however, when we start the
>>> bridge server using BridgeServer.py -c bridge.conf
>>> it is hanging there, i fi chekc the log it stop at 01/30/06 12:13:07
>>> -1208039744 Toolkit BridgeServer.py:720 INFO - Send stop message to
>>> queue processor 01/30/06 12:13:07 -1208039744 Toolkit
>>> BridgeServer.py:726 INFO Shutdown exiting 01/30/06 12:13:07 95853488
>>> Toolkit BridgeServer.py:623 INFO RunQueueThread exiting (END)
>>> we had a notehr machines using the same environment, same AG version
>>> and OS. it works there. is it due to the host certificate? at this
>>> moment, we still not get the AG host cert, just send requet. however,
>>> we are using our CA and signing policy and issue cert to this machine
>>> using ourself CA. will that be a problme without using AG issued cert?
>>> or there is anothter part we have to check for running bridge server?
>>> thakn you so much for any suggestion!
>>> Best regard!
>>>               mike
