[AG-TECH] Error installing AG2.4
    Andrew A Rowley
    Andrew.Rowley at manchester.ac.uk
    Mon Feb  6 03:17:45 CST 2006
You often need to run a separate vic instance and then select "Configure on Transmit" from the "Options" button (under the encoder) in the "Menu".  Then click on the "Transmit" tick box and then you should be presented with options for your camera.  Make sure it is not using a resolution higher than 352x288 and you should be fine.  The next time you start vic, this *should* be remembered.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of d.bowler at sheffield.ac.uk
> Sent: 03 February 2006 22:32
> To: AG-TECH mailing list
> Subject: RE: [AG-TECH] Error installing AG2.4
> On 3 Feb 2006 at 14:55, Nagykaldi, Zsolt F. (HSC) wrote:
> > Make sure your video device is properly installed. VIC does that if
> > you have video service enabled, but no camera to connect to (or VIC
> > does not recognize the capture card/camera).
> The camera that I am using is a USB camera, Creative, and I have got
> it installed and it is enabled in Services. In Scanner and Cameras in
> the Control Panel in WindowsXP it is recognised and tests OK there
> but it seems when Vic starts, a grey panel appears then that is where I
> get the Microsoft C++ error concerning the video services. I will be
> back at work on Monday and try reinstalling the camera drivers again,
> thanks for all the help
> No virus found in this outgoing message.
> Checked by AVG Free Edition.
> Version: 7.1.375 / Virus Database: 267.15.1/250 - Release Date: 03/02/2006
> Version: 7.1.375 / Virus Database: 267.15.2/251 - Release Date: 04/02/2006
