[AG-TECH] AG2 and AG3 venue servers on one machine
Derek Piper
dcpiper at indiana.edu
Mon Aug 7 12:58:19 CDT 2006
Yes, I originally had my 2.x server at port 8000, apparently the
default. So.. now we have two incompatible venue servers that all want
to be the same default? That was a smart idea :>
Since I already have 2.x installations around that use the one on port
8000 as a default/home venue, I thought I'd just add AG3 on as port
9000. Now, I guess it's possible to try it the other way and just run to
all my installations and change them. In trying to run the AG2 venue
server on port 900x, it doesn't start its text chat thing on port 9004
either. Nothing's running on that port. And, just like it was with AG3,
a venue client can't connect to it.
I have the ports specified in VenueServer.cfg. All, but the 'textPort'
one seem to work. The text chat thing isn't even trying to bind to port
8004 either, so I'm not sure what's up with that. Do I have to redo my
venue server from scratch if I change the port?
I was specifying the text, event and date ports for AG3, yes. I had
them set to the 900x equivalants and a venue client couldn't connect to it.
Derek
Michael Miller wrote:
> Derek,
> I run AG2 on port 900x and AG3 on 800x. I specify the text, event and
> data ports for AG2 in VenueServer.cfg and everything seems to work
> fine. Are you specifying the text,event and data ports for AG3?
> myk
> Derek Piper wrote:
>> Hi,
>> I've installed AG2 and AG3 venue servers on one machine, with the
>> idea of having them co-exist but running on different ports. I noticed
>> that even if I specify a port of 9000 to the AG3 venue server, it
>> still wants to listen on 8002 etc. That seems a bit unhelpful. I've
>> been able to get both of them running by having a VenueServer.cfg file
>> but, but the AG3 VenueServer isn't listening for its text chat port of
>> 9004. Does the AG3 VenueServer have to listen on port 8000? I don't
>> really want to have yet another box just to run the venue server, but
>> is that the only recommended way of setting them up?
>> Another question related to this is about keeping the two venue
>> servers synchronized. For the time being, it's going to be likely to
>> have to run both side by side. It would be nice if the configuration
>> from one could be mirrored from another and synchronized either by a
>> manual or automatic operation without having to perform the same edits
>> in each.
>> Hints are appreciated. Thanks,
>> Derek
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
