[AG-TECH] AG2 and AG3 venue servers on one machine
Michael Miller
mimiller at ncsa.uiuc.edu
Mon Aug 7 12:08:17 CDT 2006
Derek,
I run AG2 on port 900x and AG3 on 800x. I specify the text, event and
data ports for AG2 in VenueServer.cfg and everything seems to work
fine. Are you specifying the text,event and data ports for AG3?
myk
Derek Piper wrote:
> Hi,
> I've installed AG2 and AG3 venue servers on one machine, with the
> idea of having them co-exist but running on different ports. I noticed
> that even if I specify a port of 9000 to the AG3 venue server, it
> still wants to listen on 8002 etc. That seems a bit unhelpful. I've
> been able to get both of them running by having a VenueServer.cfg file
> but, but the AG3 VenueServer isn't listening for its text chat port of
> 9004. Does the AG3 VenueServer have to listen on port 8000? I don't
> really want to have yet another box just to run the venue server, but
> is that the only recommended way of setting them up?
> Another question related to this is about keeping the two venue
> servers synchronized. For the time being, it's going to be likely to
> have to run both side by side. It would be nice if the configuration
> from one could be mirrored from another and synchronized either by a
> manual or automatic operation without having to perform the same edits
> in each.
> Hints are appreciated. Thanks,
> Derek
Thanx,
Michael Miller
System Engineer
Video Technology Services
Persistent Infrastructure Directorate
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
