[AG-TECH] RE: AGVCR
    Phillips, Joseph
    JPhillips at dacc.uchicago.edu
    Thu Apr 20 20:12:43 CDT 2006
Thanks for the quick help Derek- it worked! It seems to be working fine now. The program has still crashed twice during playback since I made the switch to GTK 2.8.9, but it doesn't seem to be a regular thing like before.
Thanks again- looking forward to more of your additions in the future!
Joe
Joseph Phillips
Center for Simulation and Safety in Healthcare
University of Chicago
jphillips at dacc.uchicago.edu <mailto:jphillips at dacc.uchicago.edu>
Sent: Thu 4/20/2006 2:40 PM
To: Phillips, Joseph
Cc: ag-tech at mcs.anl.gov
Subject: Re: AGVCR
        Hi Phillip,
        I was able to recreate the problem on a windows machine (AGVCR appeared
to lock up after 16 minutes), and it was running GTK 2.6.10 as a
runtime. I then removed GTK 2.6 and installed GTK 2.8.9 (the latest
available Windows installer) and re-tried the test in the same venue
(Venue Client didn't even get shut down between tests) and AGVCR has
been running fine for over 45 minutes and still going as I write this
email, so I would suggest trying GTK 2.8.9 to see if it helps you too.
        I think I will need to update the Windows GTK runtime to 2.8 and
possibly put a note on the website. Given the apparent GTK bug with
AGVCR running on GTK 2.6 I may even move to compiling the Windows build
against 2.8 to make it 'compulsory' to use 2.8.
        Derek
Phillips, Joseph wrote:
> We've been attempting to use AGVCR 1.5.9 for video feedback in our
> medical simulation center, but the application window seems to go blank
> and lock up after letting it run for more than 10 minutes or so.
> Invariably, the file that was being recorded when the application
> crashed can't be played back later, even after restarting. We're using a
> WindowsXP (formerly InSors) machine with a Videum capture card and four
> cameras.
>    If we can get it working, we'd like to use it for recording our sim
> debriefings as well, including the playback or the earlier recording.
> Has anyone tried using AGVCR to record playback streams from AGVCR on
> another machine? It seems like it should work, right? Any help or advice
> is greatly appreciated- thanks!
> Joe Phillips
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060420/0f9012e3/attachment.htm>
