[AG-TECH] Re: AGVCR
Derek Piper
dcpiper at indiana.edu
Thu Apr 20 14:40:15 CDT 2006
Hi Phillip,
I was able to recreate the problem on a windows machine (AGVCR appeared
to lock up after 16 minutes), and it was running GTK 2.6.10 as a
runtime. I then removed GTK 2.6 and installed GTK 2.8.9 (the latest
available Windows installer) and re-tried the test in the same venue
(Venue Client didn't even get shut down between tests) and AGVCR has
been running fine for over 45 minutes and still going as I write this
email, so I would suggest trying GTK 2.8.9 to see if it helps you too.
I think I will need to update the Windows GTK runtime to 2.8 and
possibly put a note on the website. Given the apparent GTK bug with
AGVCR running on GTK 2.6 I may even move to compiling the Windows build
against 2.8 to make it 'compulsory' to use 2.8.
Derek
Phillips, Joseph wrote:
> We've been attempting to use AGVCR 1.5.9 for video feedback in our
> medical simulation center, but the application window seems to go blank
> and lock up after letting it run for more than 10 minutes or so.
> Invariably, the file that was being recorded when the application
> crashed can't be played back later, even after restarting. We're using a
> WindowsXP (formerly InSors) machine with a Videum capture card and four
> cameras.
> If we can get it working, we'd like to use it for recording our sim
> debriefings as well, including the playback or the earlier recording.
> Has anyone tried using AGVCR to record playback streams from AGVCR on
> another machine? It seems like it should work, right? Any help or advice
> is greatly appreciated- thanks!
> Joe Phillips
> Center for Simulation and Safety in Healthcare
> University of Chicago
> jphillips at dacc.uchicago.edu <mailto:jphillips at dacc.uchicago.edu>
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
