[AG-TECH] RE: AGVCR
    Derek Piper
    dcpiper at indiana.edu
    Mon Apr 24 07:27:37 CDT 2006
	Hi Phillip,
	Still crashing though?.. that's not good. I'll try and work on that. It
runs for hours on Linux without problems (that's the machine I have with
the most disk space so it's where I record our meetings).
	Something about Windows or windows-specific code, or GTK under Windows ...
	Derek
Phillips, Joseph wrote:
> Thanks for the quick help Derek- it worked! It seems to be working fine
> now. The program has still crashed twice during playback since I made
> the switch to GTK 2.8.9, but it doesn't seem to be a regular thing like
> before.
> Thanks again- looking forward to more of your additions in the future!
> Joe
> Joseph Phillips
> Center for Simulation and Safety in Healthcare
> University of Chicago
> jphillips at dacc.uchicago.edu <mailto:jphillips at dacc.uchicago.edu>
> *From:* Derek Piper [mailto:dcpiper at indiana.edu]
> *Sent:* Thu 4/20/2006 2:40 PM
> *To:* Phillips, Joseph
> *Cc:* ag-tech at mcs.anl.gov
> *Subject:* Re: AGVCR
>         Hi Phillip,
>         I was able to recreate the problem on a windows machine (AGVCR
> appeared
> to lock up after 16 minutes), and it was running GTK 2.6.10 as a
> runtime. I then removed GTK 2.6 and installed GTK 2.8.9 (the latest
> available Windows installer) and re-tried the test in the same venue
> (Venue Client didn't even get shut down between tests) and AGVCR has
> been running fine for over 45 minutes and still going as I write this
> email, so I would suggest trying GTK 2.8.9 to see if it helps you too.
>         I think I will need to update the Windows GTK runtime to 2.8 and
> possibly put a note on the website. Given the apparent GTK bug with
> AGVCR running on GTK 2.6 I may even move to compiling the Windows build
> against 2.8 to make it 'compulsory' to use 2.8.
>         Derek
>  > We've been attempting to use AGVCR 1.5.9 for video feedback in our
>  > medical simulation center, but the application window seems to go blank
>  > and lock up after letting it run for more than 10 minutes or so.
>  > Invariably, the file that was being recorded when the application
>  > crashed can't be played back later, even after restarting. We're using a
>  > WindowsXP (formerly InSors) machine with a Videum capture card and four
>  > cameras.
>  >    If we can get it working, we'd like to use it for recording our sim
>  > debriefings as well, including the playback or the earlier recording.
>  > Has anyone tried using AGVCR to record playback streams from AGVCR on
>  > another machine? It seems like it should work, right? Any help or advice
>  > is greatly appreciated- thanks!
>  > Joe Phillips
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> IRI 323, School of Informatics
> Indiana University, Bloomington, Indiana
