[AG-TECH] Ag 2.4 Build for Suse 10
Jeremy Mann
jeremy at biochem.uthscsa.edu
Tue Apr 11 13:51:38 CDT 2006
Great! Thanks Douglas. Is there a proper order to compile these in?
Douglas Kosovic said:
> Hi Jeremy,
>> I'm trying to build the toolkit from SRPMS for Suse 10 x86_64. gpt
>> compiled fine, however globus-accessgrid errors with:
>> rpmbuild -ba globus-accessgrid.spec
>> + echo 'Error: AGBUILDROOT environment variable must be set'
>> + exit 1
>> error: Bad exit status from /var/tmp/rpm-tmp.47086 (%prep)
>> Where and what do I set this variable to?
> Regarding the AGBUILDROOT environment variable, see building from source
> code:
> http://www.vislab.uq.edu.au/research/accessgrid/software/suse/
> anyway that's the old approach, where the globus-accessgrid and
> AccessGrid-2.4 RPMs need to be built with the BuildSnapshot.py script,
> instead of using rpmbuild.
> I now use real SRPMs to build everything and the SRPMs can be found here:
> http://www.vislab.uq.edu.au/accessgrid3/fedora/
> The AccessGrid-2.4 RPM is now obsoleted by compat-AccessGrid-2.4 which is
> no
> longer a monolythic RPM containing everything and the commands under
> /usr/bin have the .py suffixes replaced with 24 so as not to collide with
> the AccessGrid-3.0 commands.
> if you want to build compat-AccessGrid-2.4 on Suse, grab the folllowing
> SRPMs:
> AccessGrid-rat
> AccessGrid-vic
> QuickBridge
> globus-accessgrid
> pyOpenSSL_AG
> python-SOAPpy
> python-fpconst
> then rpmbuild --rebuild them.
> Doug
Jeremy Mann
University of Texas Health Science Center
Bioinformatics Core Facility
http://www.bioinformatics.uthscsa.edu
Phone: (210) 567-2672
