[AG-TECH] Winnov Videum Quattro
Fred Dech
fdech at uchicago.edu
Fri Sep 2 09:59:26 CDT 2005
Chris.
i've run into similar problems multiple times with the 4400 VO. it usually
happens when i switch to a different style of VideoProducerService
(e.g., JPEG, MPEG4), but it sometimes occures for other reasons.
one potential fix is to right-click the VideoProducerServics from within
the same menu that you added them to your configuration. select configure
and make sure that they are properly set. sometimes they aren't.
if that doesn't fix it:
if you are using a windows box for transmission,
here's what you might try. it's worked for me in the past, to a point...
open the configure option in the vics that are blank.
on the first "options" dropdown on the left of the GUI, select
configure on transmit. then go select 'release' at the top followed by
re-selecting 'transmit'. this get's you into some lower-level GUIs. by
selecting the video stream in this menu, i've often been able to get the
VIC to transmit correctly. the upside-down issue is because, for
some reason that i don't understand, your VIC transmission is not set
to h.261. in this same menu, if you re-set it to h.261 it will not only
get rid of the boarder, but it will transmit the image rightsideup.
saving these configuration options is another story.... good luck on that
one.
--fred
On Thu, Sep 01, 2005 at 06:39PM, Chris Rosenthal said:
> Tom & anyone else who is interested,
> Our lab bought a Winnov Videum Quattro (not the 4400 VO) because we
> wanted to be able to capture 4 s-video sources, instead of just 4 BNC.
> After a long hassle with Winnov, I finally got the card working with
> some old VFW drivers. By working I mean that I can run the incluced
> videum capture program and see the different video streams if I change
> the source.
> However, I have not been able to get this card to work with the AG.
> With AGTk 2.4, I am seeing 4 winnov videum options when I add a
> VideoProducerService and these options all correspond to devices in
> the vic menu. This is good, because this wasn't always the case in
> 2.3, even with the patch. The resource names are:
> Videum Video Capture
> WnvVid32.dll 1_Videum_AVX_AV_(PCI)
> WnvVid32.dll 2_Videum_AVX_AV_(PCI)
> WnvVid32.dll 3_Videum_AVX_AV_(PCI)
> The one labeled Videum Video Capture works (although the image is
> upside down). The other three do not work. Vic starts and the
> correct devices are selected, but the video is just a black screen. I
> know the other cameras are working properly, because I can switch
> which cable goes to the one that works and see the other cameras.
> So then I started looking at the log files and I can see where all of
> the resources are assigned in the venue client log. In the
> VideoProducer log, I'm getting an exception mapping the device.
> Tom, I'll send the log files along to you in a separate email if you
> wouldn't mind taking a look. I thought I would send this one to the
> list in case anyone else was dealing with the same problem and might
> benefit from the solution.
> Any help is appreciated.
> Thanks,
> Chris
> PS: Here's an excerpt from the log of the exception:
> 09/01/05 17:55:22 3604 Toolkit agservice.py:136 INFO
> ConfigureStream: video 224.2.177.155 55524
> 09/01/05 17:55:22 3604 Toolkit videoproducerservice.py:170 INFO
> Mapping windows device: WnvVid32.dll 1_Videum_AVX_AV_(PCI)
> 09/01/05 17:55:22 3604 Toolkit videoproducerservice.py:172 INFO - videum
> 09/01/05 17:55:22 3604 Toolkit videoproducerservice.py:217 ERROR
> Exception mapping device
> Traceback (most recent call last):
> File "C:\Documents and Settings\agtech\Application
> Data\AccessGrid\local_services\VideoProducerService\VideoProducerService.py",
> line 215, in Start
> self.MapWinDevice(self.resource.resource)
> line 174, in MapWinDevice
> videum_re = re.compile(".*(\d)_Videum.*")
> NameError: global name 're' is not defined
> 09/01/05 17:55:22 3604 Toolkit videoproducerservice.py:291 INFO
> Starting VideoProducerService
> 09/01/05 17:55:22 3604 Toolkit videoproducerservice.py:292 INFO
> executable = C:\Documents and Settings\agtech\Application
> Data\AccessGrid\local_services\VideoProducerService\vic.exe
> 09/01/05 17:55:22 3604 Toolkit videoproducerservice.py:293 INFO
> options = ['-u',
> 'C:/DOCUME~1/agtech/LOCALS~1/Temp/VideoProducerService_2104.vic',
> '-C', '"dll1"', '-t', '127', '224.2.177.155/55524']
> 09/01/05 17:55:22 3604 ProcessManager processmanager.py:59 DEBUG
> Creating process: C:\Documents and Settings\agtech\Application
> Data\AccessGrid\local_services\VideoProducerService\vic.exe -u
> C:/DOCUME~1/agtech/LOCALS~1/Temp/VideoProducerService_2104.vic -C
> "dll1" -t 127 224.2.177.155/55524
> 09/01/05 17:55:22 3604 ProcessManager processmanager.py:72 DEBUG
> Create process returns: (<PyHANDLE object at 0x0129971C>, <PyHANDLE
> object at 0x0129DD94>, 1108, 1084)
> Chris Rosenthal
> Electronic Visualization Laboratory
> University of Illinois - Chicago
> Phone: 312.996.3002
Fred Dech fdech at uchicago.edu
University of Chicago Dept. of Surgery
Ph: (773) 834-8359, Fax: (773) 834-8140
