[AG-TECH] RAT volume slider problem
    Andrew Sharpe
    andrew.sharpe1 at jcu.edu.au
    Wed Nov 30 17:03:43 CST 2005
John, set the OSS_IS_AC97 option to ON to remove this problem.  If you
don't have this option when you configure your AudioService, edit
~/.AccessGrid/local_services/AudioService/rat and add the following line
just before 'exec rat...'
export OSS_IS_AC97=1
That should do the trick.
HTH, Andrew
John Hodrien wrote:
> Anyone else had a problem where the rat mic volume slider affects
> bother the
> recording volume and the feedback volume (in other words the volume of
> the
> audio pumped straight from mic -> line out for people who actually
> want that)?
> I suspect it's not helped by the fact that both controls are named
> Mic, such
> that amixer sset Mic 0 actually affects both of them.  I've come up
> with a
> *nasty* hack (that doesn't deserve to be repeated) to mitigate the
> effect of
> this, but it's not ideal.
> jh
Andrew Sharpe
APAC Project Officer
James Cook University Townsville
ph: +61 7 4781 4084
