[AG-TECH] Firewall ports
    Nagykaldi, Zsolt F. (HSC)
    Zsolt-Nagykaldi at ouhsc.edu
    Tue Nov 29 13:00:12 CST 2005
Active Ports (for Windows):
http://www.snapfiles.com/get/activeports.html
_ _ _
Zsolt Nagykaldi, PhD
Research Associate, Clinical IT Specialist
University Of Oklahoma Health Sciences Center
Department Of Family And Preventive Medicine
Oklahoma Center For Family Medicine Research
900 NE 10th Street
Oklahoma City, OK 73104
Phone: (405) 271-8000 Ext.:1-32212
Fax:     (405) 271-1682
Sent: Tue 11/29/2005 12:14 PM
To: Nagykaldi, Zsolt F. (HSC)
Subject: RE: [AG-TECH] Firewall ports
Zsolt -
Where do I get "Active Ports"?  Is this the name of software?
Alan Kraft
> David,
> This is probably the most important problem with AG Technology from the
"simple" user's point of view. The free AG Toolkit uses a bunch of ports (in
fact more than the inSORS product), including a couple of TCP and a lot of UDP
ports locally when connecting to a venue server. A month ago we had the same
problem and I run a number of tests. Yes, the document here:
http://www.accessgrid.org/agdp/guide/ports.html is informative but will not help
you know what's going on in an actual connection to an actual venue server,
since each "Room" has it's own set of ports that it uses. It was helpful for me
to download and run "Active Ports" (this is for Windows) and monitor what TCP
and UDP ports are actually open when entering a particular venue and room. This
will give you a better idea.
> In Microsoft networks you can assign the computer(s) where VIC and RAT are
running to the "video device pool", which will hopefully set the proper firewall
settings. This actually helped us receive incoming video in Unicast, which we
could not get before.
> Zsolt
> _ _ _
> 900 NE 10th Street
> Fax:     (405) 271-1682
> ________________________________
> From: owner-ag-tech at mcs.anl.gov on behalf of West, David F.
> Sent: Tue 11/29/2005 9:46 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Firewall ports
> I might be missing the obvious but did not find any documentation on
> Access Grid port# usage for Unicast and Multicast. Problem is we can
> transmit but not receive inbound. Know the equipment is good since I can
> use it offsite with out problem.
> Does any one know the required inbound and outbound ports for Unicast
> and Multicast under the AG?
> Thank you for any information!
> David West
> Saint Augustine's College
> dfwest at st-aug.edu
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20051129/0e5264f1/attachment.htm>
