[AG-TECH] Vic runtime error with WinTV-PVR 150 capture card
    Nagykaldi, Zsolt F. (HSC)
    Zsolt-Nagykaldi at ouhsc.edu
    Wed Nov  2 19:20:55 CST 2005
I narrowed this problem down to the Hauppauge WinTV card driver. If I disable the device, vic works fine with a webcam or runs without a resource (not transmitting). When I enable the capture card again and select the card as a resource in vic's menu, vic crashes. However, it does not crash if I just enable the driver without selecting the WinTV card as a resource. The moment I do that vic will crash in any situation until I disable the WinTV card driver again. It looks like AGTk 2.4 has a serious issue with this particular driver. It is a shame, because most setup descriptions on the Net recommend this particular capture card.
If anybody out there has a good idea, I would appreciate that!!!
Zsolt
_ _ _
Zsolt Nagykaldi, PhD
Research Associate, Clinical IT Specialist
University Of Oklahoma Health Sciences Center
Department Of Family And Preventive Medicine
Oklahoma Center For Family Medicine Research
900 NE 10th Street
Oklahoma City, OK 73104
Phone: (405) 271-8000 Ext.:1-32212
Fax:     (405) 271-1682
Sent: Wed 11/2/2005 9:17 AM
To: Nagykaldi, Zsolt F. (HSC)
Subject: Re: [AG-TECH]Runtime Error
        Yea, the WinTV cards of any age are BT878 based, and so work great.
        Derek
Nagykaldi, Zsolt F. (HSC) wrote:
> Thanks Derek, I will try this today. I know for a fact that it can be
> done, because another setup on campus is using the same setup, I just
> did not have the chance to catch their IT guy, he seems to be extremely
> busy. They have installed a WinTV card successfully 2 years ago. If I
> figure this out, I will let you know.
> Zsolt
> _ _ _
> 900 NE 10th Street
> Fax:     (405) 271-1682
> *From:* Derek Piper [mailto:dcpiper at indiana.edu]
> *Sent:* Wed 11/2/2005 7:31 AM
> *To:* Nagykaldi, Zsolt F. (HSC)
> *Cc:* ag-tech
> *Subject:* Re: [AG-TECH]Runtime Error
>         Hi,
>         I never had a lot of luck getting a WinTV PVR-150 card working,
> also in
> a Dell, also with XP2. I gave up in the end and bought an Osprey 100
> (since they use BT878 chips and not the CX26881). The node that had it
> now has a Spectra8 board (also BT878). Looking back I seem to remember
> some help from Andrew Rowley about the WinTV-PVR150:
> http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2005/05/msg00035.html
>         Derek
>  > I am getting the same error on one of our XP Pro SP2 that uses a Sony
>  > EVI-100 camera with a Hauppauge WinTV-PVR-150. This is a Dell machine.
>  > Another machine running the same AGTk 2.4 system in our department is
> fine.
>  > Please, help.
>  > Zsolt
>  > _ _ _
>  > 900 NE 10th Street
>  > Fax:     (405) 271-1682
>  > *From:* owner-ag-tech at mcs.anl.gov on behalf of John Langkals
>  > *Sent:* Tue 11/1/2005 7:07 PM
>  > *To:* 'ag-tech'
>  > *Subject:* [AG-TECH]Runtime Error
>  > Hello AGTech,
>  > On a WinXP PIG running AGtk 2.4, I am getting a Microsoft Visual C++
>  > runtime Library error. The error follows as Program:...tion
>  > Data\AccessGrid\local_services\VideoService\vic.exe
>  > Note this is a IBM thinkpad.  I did remove python 2.2 python....= 1 in the
>  > path variables and reinstalled the AGtk 2.4.  The PIG worked great
>  > afterwards.  Now I am getting this error shown above.  I reinstalled the
>  > AGtk and I am still getting this error.  Any ideas?
>  > Thank you,
>  > John
>  > John Langkals
>  > Systems Manager
>  > OCTS
>  > M2021 Physics Research Building
>  > 191 West Woodruff Avenue
>  > Columbus, Ohio 43210
>  > 614.292.6957 Office
>  > 614.327.3732 Cell
>  > 614.292.7557 FAX
>  > www.octs.osu.edu
> <file:///C:\Documents%20and%20Settings\john\Application%20Data\Microsoft\Signatures\www.octs.osu.edu>
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> IRI 323, School of Informatics
> Indiana University, Bloomington, Indiana
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20051102/01d53caa/attachment.htm>
