[AG-TECH] Windows Capture Cards
    mimiller at ncsa.uiuc.edu
    Thu May 19 16:29:47 CDT 2005
Barry,
I'm guessing persistence of the settings depends on the driver for the
capture card.  you might check the OEM website to see if they have a tool
for testing the video input and see if that can set the defaults for you.
Hope this helps
MYK
At 04:03 PM 5/19/2005, Barry Gamblin wrote:
>I did this and it worked, but only for that session. Once I exited
>the venue and then entered it again, I had black video. I had to
>do the steps over again. I can not find anywhere an option to
>save the setup. On the menu dialog there is a "default" button,
>so I tried clicking that, but it does not do anything.
>Thanks for any help.
>Barry
>|> Barry,
>|> Try this:
>|> Once your video vic is running and showing a black screen, click the
>menu
>|> button in that vic
>|> Then in the Encoder section click the Options button
>|> One of the choices is Configure on Transmit, click to make sure it's
>selected
>|> Then click the Release button in the Transmission section
>|> Then click Transmit
>|> This should bring up a set of dialogs for your video card driver that
>will
>|> allow you to set the port for the card as well as other settings like
>|> resolution, white balance hue, etc....
>|> Hope this helps
>|> MYK
>|> At 09:26 AM 5/13/2005, Barry Gamblin wrote:
>|> >|> I am using the winnov videum 4400 quad card and thanks to Tom it
>|> >|> is working nicely....
>|> >|> At 04:12 PM 5/12/2005, Darin Oman wrote:
>|> >|> >I know there are some people out there using a Windows box as
>|> >|> >their video capture machine. What capture cards are people
>having
>|> >|> >good luck with for
>|> >|> >capturing multiple video sources (s-video)?
>|> >|> >Thanks,
>|> >|> >Darin
>|> >|> Cindy Sievers           Los Alamos National Laboratory
>|> >|> sievers at lanl.gov        Group CCS-1 MS B287
>|> >|> tel:505.665.6602        Advanced Computing
>|> >|> fax:505.665.4939        Los Alamos, NM 87544
>|> >I am pretty sure this is the card I have on a Windows XP Dell. My
>|> >machine is transmitting black video. What was the fix?
>|> >BTW The video works fine with the INSORS software.
>|> >(Sorry if this has already been discussed. I just joined the list)
>|> >Barry
>|> >Barry S. Gamblin, UNIX Administrator III, bgamblin at ucar.edu
>|> >High Altitude Observatory - National Center for Atmospheric Research
>|> >P.O.Box 3000, Boulder CO 80307-3000
>|> >voice - 303-497-1509  fax - 303-497-1589
