[AG-TECH] Running AG from CVS doesn't work
Michael Braitmaier
braitmaier at hlrs.de
Tue May 17 07:21:31 CDT 2005
Hi Eric!
Sorry, I didn't answer on your last e-mail, but I was instantly trying to
checkout the last AG2.3 version.
Indeed I got it running with the AG2.3 CVS checkout and managed to merge my
code changes into the CVS code.
Though I am still interested to try the AG3 CVS.
Yet I am wondering what might possibly the best way to integrate my changes
to? AG2.3 or AG3?
Michael
----- Original Message -----
To: "Michael Braitmaier" <braitmaier at hlrs.de>
Cc: <ag-tech at mcs.anl.gov>
Sent: Friday, May 13, 2005 8:01 PM
Subject: Re: [AG-TECH] Running AG from CVS doesn't work
> Hi Michael,
> I'm not sure if the suggestions in my last e-mail were what you needed,
> but the Access Grid code in the trunk is now in a minimally working state
> if you are interested in trying what's currently being developed. Of
> course, not everything is working yet.
> The zsi code you need is in the serialize-dome-scheme branch. You should
> be able to check it out from cvs (-r serialize-dom-scheme). You'll also
> need to checkout wstools from the same project and put it in the ZSI
> directory. If you've installed another version of zsi, be sure to
> uninstall/remove those files first, since they don't always get
> overwritten.
> Besides installing zsi, I don't believe you need to do anything extra --
> just the standard things in README-developers like running CvsSetup. If
> you run into problems just ask. Fixes and suggestions are also always
> welcome.
> Eric
> On Mon, 2 May 2005, Michael Braitmaier wrote:
>> I tried to start AG from CVS today, following the procedure through
>> CvsSetup.py as well as env-init.bat
>> Furthermore I downloaded ZSI-1.6. and installed it by first building the
>> windows-installer from the source package.
>> pyXML has been installed as well.
>> I got an error when executing the VenueClient.py:
>> from AccessGrid.interfaces.AccessGrid_Types import
>> www_accessgrid_org_v3_0 a
>> s AGTypes
>> ImportError: No module named interfaces.AccessGrid_Types
>> I assumed it to be caused by not having the required type definitions
>> which
>> possibly are made out of the wsdl files.
>> So I executed the generate.bat file in the AccessGrid/wsdl directory,
>> which
>> didn't work in the first place as it couldn't find wsdl2py and
>> wsdldispatch
>> I found similar programs in the ZSI site-package directory called
>> wsdl2python.py and dispatcher.py and assumed them to be the right
>> programs
>> to generate the stubs.
>> Still I get the error as described above when executing the VenueClient.
>> So now I am a bit clueless. What could be the reason for this?
>> Any help would be greatly appreciated.
>> Michael
>> Dipl.-Inf. Michael Braitmaier
>> HLRS - Visualization / Video Conferencing
>> University of Stuttgart
>> Germany
>> Website: http://www.hlrs.de/organization/vis/people/braitmaier/
