[AG-TECH] Running AG from CVS doesn't work
Eric Olson
eolson at mcs.anl.gov
Thu May 19 11:53:40 CDT 2005
Hi Michael,
I think it would be best to use AG2.3 until an AG3 alpha or beta release.
That way you won't have to spend extra time figuring out if problems you
run into are due to our code being under development.
Eric
On Tue, 17 May 2005, Michael Braitmaier wrote:
> Hi Eric!
> Sorry, I didn't answer on your last e-mail, but I was instantly trying to
> checkout the last AG2.3 version.
> Indeed I got it running with the AG2.3 CVS checkout and managed to merge my
> code changes into the CVS code.
> Though I am still interested to try the AG3 CVS.
> Yet I am wondering what might possibly the best way to integrate my changes
> to? AG2.3 or AG3?
> Michael
> From: "Eric Olson" <eolson at mcs.anl.gov>
> To: "Michael Braitmaier" <braitmaier at hlrs.de>
> Cc: <ag-tech at mcs.anl.gov>
> Sent: Friday, May 13, 2005 8:01 PM
> Subject: Re: [AG-TECH] Running AG from CVS doesn't work
> > Hi Michael,
> > I'm not sure if the suggestions in my last e-mail were what you needed,
> > but the Access Grid code in the trunk is now in a minimally working state
> > if you are interested in trying what's currently being developed. Of
> > course, not everything is working yet.
> > The zsi code you need is in the serialize-dome-scheme branch. You should
> > be able to check it out from cvs (-r serialize-dom-scheme). You'll also
> > need to checkout wstools from the same project and put it in the ZSI
> > directory. If you've installed another version of zsi, be sure to
> > uninstall/remove those files first, since they don't always get
> > overwritten.
> > Besides installing zsi, I don't believe you need to do anything extra --
> > just the standard things in README-developers like running CvsSetup. If
> > you run into problems just ask. Fixes and suggestions are also always
> > welcome.
> > Eric
> > On Mon, 2 May 2005, Michael Braitmaier wrote:
> >> I tried to start AG from CVS today, following the procedure through
> >> CvsSetup.py as well as env-init.bat
> >> Furthermore I downloaded ZSI-1.6. and installed it by first building the
> >> windows-installer from the source package.
> >> pyXML has been installed as well.
> >> I got an error when executing the VenueClient.py:
> >> from AccessGrid.interfaces.AccessGrid_Types import
> >> www_accessgrid_org_v3_0 a
> >> s AGTypes
> >> ImportError: No module named interfaces.AccessGrid_Types
> >> I assumed it to be caused by not having the required type definitions
> >> which
> >> possibly are made out of the wsdl files.
> >> So I executed the generate.bat file in the AccessGrid/wsdl directory,
> >> which
> >> didn't work in the first place as it couldn't find wsdl2py and
> >> wsdldispatch
> >> I found similar programs in the ZSI site-package directory called
> >> wsdl2python.py and dispatcher.py and assumed them to be the right
> >> programs
> >> to generate the stubs.
> >> Still I get the error as described above when executing the VenueClient.
> >> So now I am a bit clueless. What could be the reason for this?
> >> Any help would be greatly appreciated.
> >> Michael
> >> Dipl.-Inf. Michael Braitmaier
> >> HLRS - Visualization / Video Conferencing
> >> University of Stuttgart
> >> Germany
> >> Website: http://www.hlrs.de/organization/vis/people/braitmaier/
