[AG-TECH] Windows Capture Cards
Chris Rosenthal
cmr.evl at gmail.com
Mon May 16 09:39:52 CDT 2005
Darin,
I'm currently running a 3-machine all Windows node with Osprey 100's.
Like Mike said, just running the service manager on the video machine
works out just fine.
Chris
On 5/13/05, mimiller at ncsa.uiuc.edu <mimiller at ncsa.uiuc.edu> wrote:
> Darin,
> Yeah, most of our windows only nodes are single machine nodes. Having
> multiple cards has not been a problem for those machines. for a multiple
> node setup, all you need to do is make sure that the AGServiceManager is
> running on the remote machines and connect to them with the Node Manager.
> Did I hit on the right thing or are there other questions in your mind?
> MYK
> At 11:14 AM 5/13/2005, Darin Oman wrote:
> >Thanks, Mike. That does help. I got a couple different responses saying
> >basically the same thing. However, nobody has mentioned if they're using a
> >multi-windows-machine node. I'm digging through the archives now, so far
> >with no luck finding any info on windows-only multi-machine nodes. Do you
> >have any insight?
> >Darin
> >On May 13, 2005, at 10:06 AM, mimiller at ncsa.uiuc.edu wrote:
> >>Darin,
> >>We use Osprey cards in all our nodes. Be careful of those that have
> >>audio on-board, they can sometimes get switched around and then RAT is
> >>looking at the wrong jack... We use the 100 and 200 cards with some
> >>older drivers that are more stable.
> >>Hope this helps
> >>MYK
> >>At 10:38 AM 5/13/2005, you wrote:
> >>>Unfortunately, what I really need is something that will capture using
> >>>s-video. The Winnov cards use BNC. Has anybody had success in setting up
> >>>multiple capture cards on an XP machine? If so, which cards did you use?
> >>>Thanks again,
> >>>Darin
> >>>On May 13, 2005, at 8:05 AM, Cindy Sievers wrote:
> >>>>I am using the winnov videum 4400 quad card and thanks to Tom it is
> >>>>working nicely....
> >>>>At 04:12 PM 5/12/2005, Darin Oman wrote:
> >>>>>I know there are some people out there using a Windows box as their
> >>>>>video capture machine. What capture cards are people having good luck
> >>>>>with for capturing multiple video sources (s-video)?
> >>>>>Thanks,
> >>>>>Darin
> >>>>Cindy Sievers Los Alamos National Laboratory
> >>>>sievers at lanl.gov Group CCS-1 MS B287
> >>>>tel:505.665.6602 Advanced Computing
> >>>>fax:505.665.4939 Los Alamos, NM 87544
Chris Rosenthal
Electronic Visualization Laboratory
University of Illinois - Chicago
Phone: 312.996.3002
