[AG-TECH] Windows Capture Cards
mimiller at ncsa.uiuc.edu
Fri May 13 12:15:13 CDT 2005
Darin,
Yeah, most of our windows only nodes are single machine nodes. Having
multiple cards has not been a problem for those machines. for a multiple
node setup, all you need to do is make sure that the AGServiceManager is
running on the remote machines and connect to them with the Node Manager.
Did I hit on the right thing or are there other questions in your mind?
MYK
At 11:14 AM 5/13/2005, Darin Oman wrote:
>Thanks, Mike. That does help. I got a couple different responses saying
>basically the same thing. However, nobody has mentioned if they're using a
>multi-windows-machine node. I'm digging through the archives now, so far
>with no luck finding any info on windows-only multi-machine nodes. Do you
>have any insight?
>Darin
>On May 13, 2005, at 10:06 AM, mimiller at ncsa.uiuc.edu wrote:
>>Darin,
>>We use Osprey cards in all our nodes. Be careful of those that have
>>audio on-board, they can sometimes get switched around and then RAT is
>>looking at the wrong jack... We use the 100 and 200 cards with some
>>older drivers that are more stable.
>>Hope this helps
>>MYK
>>At 10:38 AM 5/13/2005, you wrote:
>>>Unfortunately, what I really need is something that will capture using
>>>s-video. The Winnov cards use BNC. Has anybody had success in setting up
>>>multiple capture cards on an XP machine? If so, which cards did you use?
>>>Thanks again,
>>>Darin
>>>On May 13, 2005, at 8:05 AM, Cindy Sievers wrote:
>>>>I am using the winnov videum 4400 quad card and thanks to Tom it is
>>>>working nicely....
>>>>At 04:12 PM 5/12/2005, Darin Oman wrote:
>>>>>I know there are some people out there using a Windows box as their
>>>>>video capture machine. What capture cards are people having good luck
>>>>>with for capturing multiple video sources (s-video)?
>>>>>Thanks,
>>>>>Darin
>>>>Cindy Sievers Los Alamos National Laboratory
>>>>sievers at lanl.gov Group CCS-1 MS B287
>>>>tel:505.665.6602 Advanced Computing
>>>>fax:505.665.4939 Los Alamos, NM 87544
